I found different discussions about installing OH2 on a QNAP.
I want to find the best way to install OH2 on an Intel-QNAP. I tried a Linux-VM, but i can’t access the Z-WAVE-Stick or my Arduino to communicate with my 433 MHz-Devices.
What is the right way?
Linux-VM?
Docker-Solution?
OH2-QPKG?
I think the main-problem is accessing the USB-Devices?
I used it on a Linux-VM and QNAP TS-453a. You can connect the USB-Device to the virtual machine. The problem is sometimes the reconnect after restart the Nas. I bought an mytun-50a box to connect the usb-devices and it is working 100% stable with it.
Hi Frank,
i am using a TS-453mini with an Ubunut VM, but the Aeon Z-WAVE-Stick can not be found by the QNAP and consequently not found by the VM. I read about the mytun-50a box. It sounds good, but not inexpensive.
I’m running Ubuntu on a VM on my TVS-671, very happy with it. So far I have not connected anything to USB, but have a aeon zwave stick and a plugwise stick which need connection, i thought it should be easily possible ?
@kallecux, @frankz: what issues exactly were you facing with USB in the VM ?
ok, i just tried it myself - plugged both USB sticks into my QNAP and try to “mount” them to my VM, it seems only the plugwise stick is recognized by the QNAP while the Aeontec lacks kernel drivers, at least that is my understanding - Did you ever try to compile the drivers yourself or such ?
it is working fine for me (seems the plugwise stick was not recognized). Have you “connected” the zwave stick to your virtual machine like here under “USB”, 3-1-8 is my zwave stick ?
Sorry! My mistake! The stick MUST be connected to an USB 2.0 connector. I have overseen the 2 USB 2.0 slots. Now it works.
Thanks for your help!
Have a nice weekend.
