Hi all
After OH2 is running without errors I’m getting out of memory errors:
19:30:29.915 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Office_Light_Top' received command ON
19:30:29.978 [ERROR] [ore.internal.events.OSGiEventManager] - Dispatching/filtering event for subscriber 'org.eclipse.smarthome.core.events.EventSubscriber' failed: java.lang.OutOfMemoryError: unable to create new native thread
java.util.concurrent.ExecutionException: java.lang.OutOfMemoryError: unable to create new native thread
at java.util.concurrent.FutureTask.report(FutureTask.java:122)[:1.8.0_131]
at java.util.concurrent.FutureTask.get(FutureTask.java:206)[:1.8.0_131]
at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:188)[98:org.eclipse.smarthome.core:0.9.0.b4]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:81)[98:org.eclipse.smarthome.core:0.9.0.b4]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:65)[98:org.eclipse.smarthome.core:0.9.0.b4]
at org.eclipse.smarthome.core.internal.events.OSGiEventManager.dispatchESHEvent(OSGiEventManager.java:188)[98:org.eclipse.smarthome.core:0.9.0.b4]
at org.eclipse.smarthome.core.internal.events.OSGiEventManager.handleEvent(OSGiEventManager.java:163)[98:org.eclipse.smarthome.core:0.9.0.b4]
at org.eclipse.smarthome.core.internal.events.OSGiEventManager.handleEvent(OSGiEventManager.java:146)[98:org.eclipse.smarthome.core:0.9.0.b4]
at org.apache.felix.eventadmin.impl.handler.EventHandlerProxy.sendEvent(EventHandlerProxy.java:415)[6:org.apache.karaf.services.eventadmin:4.0.8]
at org.apache.felix.eventadmin.impl.tasks.HandlerTask.run(HandlerTask.java:90)[6:org.apache.karaf.services.eventadmin:4.0.8]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_131]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_131]
at java.lang.Thread.run(Thread.java:748)[:1.8.0_131]
Caused by: java.lang.OutOfMemoryError: unable to create new native thread
at java.lang.Thread.start0(Native Method)[:1.8.0_131]
at java.lang.Thread.start(Thread.java:717)[:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor.addWorker(ThreadPoolExecutor.java:950)[:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor.execute(ThreadPoolExecutor.java:1368)[:1.8.0_131]
at org.eclipse.smarthome.core.common.QueueingThreadPoolExecutor.execute(QueueingThreadPoolExecutor.java:148)
at org.eclipse.smarthome.core.items.GenericItem.notifyListeners(GenericItem.java:235)
at org.eclipse.smarthome.core.items.GenericItem.applyState(GenericItem.java:213)
at org.eclipse.smarthome.core.items.GenericItem.setState(GenericItem.java:199)
at org.eclipse.smarthome.core.internal.items.ItemUpdater.receiveUpdate(ItemUpdater.java:70)
at org.eclipse.smarthome.core.items.events.AbstractItemEventSubscriber.receive(AbstractItemEventSubscriber.java:44)
at org.eclipse.smarthome.core.internal.events.OSGiEventManager$1.call(OSGiEventManager.java:192)
at org.eclipse.smarthome.core.internal.events.OSGiEventManager$1.call(OSGiEventManager.java:1)
at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:179)
... 4 more
I’m using OH 2.0.0 with knx, Astro and Plex binding on Rasp PI 3.
Has any body an idea how to fix this? Looks like the Java garbage collector is not able to free the memory for cerated threads by executing a rule.
After restarted OH2 everything is good again because the memory was freed.
The error happened, when I turn the light on which triggers a rule to activate / deactivate a LED after approx 6 days.
Thanks in advance for any hint how to solve the issues.
