I want to read data from my CUL stick (via serial port), but somehow it doesn’t seem to work.
When I do submit the following command on command line level…
cat < /dev/ttyACM0
…I can see the desired data. Means: The CUL stick sends data to the raspberry and I can read them visually.
But when I try to incorporate this output in openhab2, then I get the following errors:
21:53:39.522 [DEBUG] [org.openhab.binding.serial ] - BundleEvent STARTING - org.openhab.binding.serial
21:53:39.528 [DEBUG] [ding.serial.internal.SerialActivator] - Serial binding has been started.
21:53:39.569 [DEBUG] [org.openhab.binding.serial ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.osgi.service.event.EventHandler}={event.topics=openhab/command/*, component.name=org.openhab.binding.serial, TransformationService.target=(openhab.transform=REGEX), component.id=203, service.id=354, service.bundleid=220, service.scope=bundle} - org.openhab.binding.serial
21:53:39.701 [DEBUG] [binding.serial.internal.SerialDevice] - Serial port '/dev/ttyACM0' has been found.
21:53:39.733 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type 'serial' of item 'CULResult' could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: Could not open serial port /dev/ttyACM0: gnu.io.UnsupportedCommOperationException: Invalid Parameter
at org.openhab.core.binding.internal.BindingConfigReaderDelegate.processBindingConfiguration(BindingConfigReaderDelegate.java:50)
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:312)
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.dispatchBindingsPerType(GenericItemProvider.java:268)
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.addBindingConfigReader(GenericItemProvider.java:102)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_65]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0_65]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_65]
at java.lang.reflect.Method.invoke(Method.java:497)[:1.8.0_65]
at org.apache.felix.scr.impl.helper.BaseMethod.invokeMethod(BaseMethod.java:222)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.helper.BaseMethod.access$500(BaseMethod.java:37)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.helper.BaseMethod$Resolved.invoke(BaseMethod.java:615)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.helper.BaseMethod.invoke(BaseMethod.java:499)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.helper.BindMethod.invoke(BindMethod.java:41)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1660)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1636)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:370)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:319)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:295)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:120)[33:org.apache.felix.scr:2.0.2]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:914)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:482)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:998)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.openhab.core.binding.internal.BindingConfigReaderFactory.registerDelegateService(BindingConfigReaderFactory.java:69)
at org.openhab.core.binding.internal.BindingConfigReaderFactory.addBindingConfigReader(BindingConfigReaderFactory.java:52)
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:869)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:857)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:915)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:715)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:399)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.config.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:676)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:360)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.Activator.access$000(Activator.java:53)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:260)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:259)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:232)[33:org.apache.felix.scr:2.0.2]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444)[org.osgi.core-6.0.0.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:902)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:165)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:75)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:67)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:102)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:466)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.Module.start(Module.java:457)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
21:53:39.788 [DEBUG] [org.openhab.binding.serial ] - BundleEvent STARTED - org.openhab.binding.serial
21:53:39.792 [DEBUG] [org.openhab.io.transport.serial ] - BundleEvent STARTING - org.openhab.io.transport.serial
21:53:39.797 [DEBUG] [org.openhab.io.transport.serial ] - BundleEvent STARTED - org.openhab.io.transport.serial
So, first it says, verything is fine - and then OH2 comes up with a bunch of errors:
My item is as simple as possible:
String CULResult "CULResult: [%s]" { serial="/dev/ttyACM0@38400" }
I don’t have a “serial.cfg” - and only a “binding = serial” in the addon.cfg.
What I did also:
export EXTRA_JAVA_OPTS=-Dgnu.io.rxtx.SerialPorts=/dev/ttyACM0
sudo usermod -a -G dialout openhab
Where’s my mistake? Any other ideas?
Thanks,
Boby
