OH2 Squeezebox play action?
I used to play a stream using the action squeezeboxPlayUrl(String playerId, String url, int volume)
How can I achieve this in OH2?
Thx in advance, G.
I had the same question…
The only way I could work it out was to use a rule with the stream command
sendCommand (StudySqueezeStream, “http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/hls/uk/sbr_high/ak/bbc_radio_one.m3u8”)
To the following item
String StudySqueezeStream “Stream” { channel=“squeezebox:squeezeboxplayer:MyServer:Study:stream” }
Hope that helps!
Thanks a lot. Works like a charm!
