what i did here:
Switched Lights on. Waited a minute. Changed the brigthness and waited for the timer to be fired.
this is the logfile for hat timespan:
2019-09-21 16:19:20.361 [INFO ] [eclipse.smarthome.model.script.hue_3] - 215,4,82
2019-09-21 16:19:20.369 [INFO ] [eclipse.smarthome.model.script.hue_4] - 232,3,0
2019-09-21 16:19:20.383 [INFO ] [eclipse.smarthome.model.script.hue_5] - 215,4,0
2019-09-21 16:19:20.392 [INFO ] [marthome.model.script.triggeringItem] - hue_0200_0017884dd999_3_color (Type=ColorItem, State=215,4,82, Label=Color, Category=null, Tags=[Lighting])
2019-09-21 16:19:20.417 [INFO ] [eclipse.smarthome.model.script.hue_3] - 215,4,82
2019-09-21 16:19:20.418 [INFO ] [lipse.smarthome.model.script.Bedroom] - Living Color Lamps state changed!
2019-09-21 16:19:20.420 [INFO ] [eclipse.smarthome.model.script.hue_3] - 215,4,82
2019-09-21 16:19:20.424 [INFO ] [eclipse.smarthome.model.script.hue_4] - 232,3,82
2019-09-21 16:19:20.427 [INFO ] [eclipse.smarthome.model.script.hue_4] - 232,3,82
2019-09-21 16:19:20.430 [INFO ] [eclipse.smarthome.model.script.hue_5] - 215,4,82
2019-09-21 16:19:20.431 [INFO ] [rthome.model.script.Bedroom 01 Timer] - Thereās no running timer. Creating oneā¦
2019-09-21 16:19:20.434 [INFO ] [eclipse.smarthome.model.script.hue_5] - 215,4,82
2019-09-21 16:19:20.435 [INFO ] [marthome.model.script.triggeringItem] - hue_0200_0017884dd999_4_color (Type=ColorItem, State=232,3,82, Label=Color, Category=null, Tags=[Lighting])
2019-09-21 16:19:20.439 [INFO ] [marthome.model.script.triggeringItem] - hue_0200_0017884dd999_5_color (Type=ColorItem, State=215,4,82, Label=Color, Category=null, Tags=[Lighting])
2019-09-21 16:19:20.449 [INFO ] [rthome.model.script.Bedroom 01 Timer] - Timer createdā¦
2019-09-21 16:19:20.457 [INFO ] [lipse.smarthome.model.script.Bedroom] - Living Color Lamps state changed!
2019-09-21 16:19:20.465 [INFO ] [rthome.model.script.Bedroom 01 Timer] - rescheduling Timerā¦
2019-09-21 16:19:20.472 [WARN ] [el.script.internal.actions.TimerImpl] - An error occurred while rescheduling the job āDEFAULT.2019-09-21T16:21:20.438+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@56e713
} ]ā: Unable to store Job : āDEFAULT.2019-09-21T16:21:20.438+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
} ]ā, because one already exists with this identification.
2019-09-21 16:19:20.473 [INFO ] [rthome.model.script.Bedroom 01 Timer] - Timer rescheduled.
2019-09-21 16:19:20.476 [INFO ] [rthome.model.script.Bedroom 01 Timer] - Timer rescheduled.
2019-09-21 16:20:20.664 [INFO ] [eclipse.smarthome.model.script.hue_3] - 215,4,49
2019-09-21 16:20:20.676 [INFO ] [eclipse.smarthome.model.script.hue_4] - 232,3,50
2019-09-21 16:20:20.684 [INFO ] [eclipse.smarthome.model.script.hue_5] - 215,4,48
2019-09-21 16:20:20.692 [INFO ] [marthome.model.script.triggeringItem] - hue_0200_0017884dd999_3_color (Type=ColorItem, State=215,4,49, Label=Color, Category=null, Tags=[Lighting])
2019-09-21 16:20:20.713 [INFO ] [eclipse.smarthome.model.script.hue_3] - 215,4,49
2019-09-21 16:20:20.714 [INFO ] [eclipse.smarthome.model.script.hue_3] - 215,4,49
2019-09-21 16:20:20.722 [INFO ] [eclipse.smarthome.model.script.hue_4] - 232,3,50
2019-09-21 16:20:20.722 [INFO ] [lipse.smarthome.model.script.Bedroom] - Living Color Lamps state changed!
2019-09-21 16:20:20.724 [INFO ] [eclipse.smarthome.model.script.hue_4] - 232,3,50
2019-09-21 16:20:20.731 [INFO ] [eclipse.smarthome.model.script.hue_5] - 215,4,48
2019-09-21 16:20:20.733 [INFO ] [eclipse.smarthome.model.script.hue_5] - 215,4,48
2019-09-21 16:20:20.735 [INFO ] [rthome.model.script.Bedroom 01 Timer] - rescheduling Timerā¦
2019-09-21 16:20:20.740 [INFO ] [marthome.model.script.triggeringItem] - hue_0200_0017884dd999_4_color (Type=ColorItem, State=232,3,50, Label=Color, Category=null, Tags=[Lighting])
2019-09-21 16:20:20.741 [INFO ] [marthome.model.script.triggeringItem] - hue_0200_0017884dd999_5_color (Type=ColorItem, State=215,4,48, Label=Color, Category=null, Tags=[Lighting])
2019-09-21 16:20:20.752 [INFO ] [rthome.model.script.Bedroom 01 Timer] - Timer rescheduled.
2019-09-21 16:20:20.759 [INFO ] [lipse.smarthome.model.script.Bedroom] - Living Color Lamps state changed!
2019-09-21 16:20:20.764 [INFO ] [lipse.smarthome.model.script.Bedroom] - Living Color Lamps state changed!
2019-09-21 16:20:20.765 [INFO ] [rthome.model.script.Bedroom 01 Timer] - rescheduling Timerā¦
2019-09-21 16:20:20.770 [INFO ] [rthome.model.script.Bedroom 01 Timer] - rescheduling Timerā¦
2019-09-21 16:20:20.773 [INFO ] [rthome.model.script.Bedroom 01 Timer] - Timer rescheduled.
2019-09-21 16:20:20.780 [INFO ] [rthome.model.script.Bedroom 01 Timer] - Timer rescheduled.
2019-09-21 16:20:30.668 [INFO ] [eclipse.smarthome.model.script.hue_3] - 215,4,48
2019-09-21 16:20:30.674 [INFO ] [eclipse.smarthome.model.script.hue_4] - 232,3,48
2019-09-21 16:20:30.681 [INFO ] [eclipse.smarthome.model.script.hue_5] - 215,4,48
2019-09-21 16:20:30.688 [INFO ] [marthome.model.script.triggeringItem] - hue_0200_0017884dd999_3_color (Type=ColorItem, State=215,4,48, Label=Color, Category=null, Tags=[Lighting])
2019-09-21 16:20:30.688 [INFO ] [eclipse.smarthome.model.script.hue_3] - 215,4,48
2019-09-21 16:20:30.695 [INFO ] [eclipse.smarthome.model.script.hue_4] - 232,3,48
2019-09-21 16:20:30.700 [INFO ] [eclipse.smarthome.model.script.hue_5] - 215,4,48
2019-09-21 16:20:30.704 [INFO ] [marthome.model.script.triggeringItem] - hue_0200_0017884dd999_4_color (Type=ColorItem, State=232,3,48, Label=Color, Category=null, Tags=[Lighting])
2019-09-21 16:20:30.710 [INFO ] [lipse.smarthome.model.script.Bedroom] - Living Color Lamps state changed!
2019-09-21 16:20:30.718 [INFO ] [rthome.model.script.Bedroom 01 Timer] - rescheduling Timerā¦
2019-09-21 16:20:30.724 [INFO ] [lipse.smarthome.model.script.Bedroom] - Living Color Lamps state changed!
2019-09-21 16:20:30.728 [INFO ] [rthome.model.script.Bedroom 01 Timer] - Timer rescheduled.
2019-09-21 16:20:30.730 [INFO ] [rthome.model.script.Bedroom 01 Timer] - rescheduling Timerā¦
2019-09-21 16:20:30.738 [INFO ] [rthome.model.script.Bedroom 01 Timer] - Timer rescheduled.
2019-09-21 16:21:09.962 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.2019-09-21T16:21:09.961+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@3a075f
} ] threw an unhandled Exception:
at org.eclipse.smarthome.model.script.engine.ScriptError.(ScriptError.java:66) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:140) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:902) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:865) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:224) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:204) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:768) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:220) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:1116) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1046) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:992) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:458) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:244) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:447) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:228) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:190) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
at com.sun.proxy.$Proxy167.apply(Unknown Source) ~[?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) ~[?:?]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
2019-09-21 16:21:09.962 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.2019-09-21T16:21:09.957+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
2019-09-21 16:21:10.093 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.2019-09-21T16:21:09.961+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
Caused by: java.lang.NullPointerException
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
⦠1 more
2019-09-21 16:21:10.179 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.2019-09-21T16:21:09.957+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
⦠1 more
2019-09-21 16:21:54.292 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.2019-09-21T16:21:54.233+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
2019-09-21 16:21:54.377 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.2019-09-21T16:21:54.233+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
⦠1 more
2019-09-21 16:22:30.739 [INFO ] [rthome.model.script.Bedroom 01 Timer] - Bedroom 01 Timer FIRED
2019-09-21 16:22:30.803 [INFO ] [eclipse.smarthome.model.script.hue_3] - 215,4,0
2019-09-21 16:22:30.808 [INFO ] [eclipse.smarthome.model.script.hue_4] - 232,3,48
2019-09-21 16:22:30.814 [INFO ] [eclipse.smarthome.model.script.hue_5] - 215,4,0
2019-09-21 16:22:30.818 [INFO ] [marthome.model.script.triggeringItem] - hue_0200_0017884dd999_3_color (Type=ColorItem, State=215,4,0, Label=Color, Category=null, Tags=[Lighting])
2019-09-21 16:22:30.819 [INFO ] [marthome.model.script.triggeringItem] - hue_0200_0017884dd999_5_color (Type=ColorItem, State=215,4,0, Label=Color, Category=null, Tags=[Lighting])
2019-09-21 16:22:30.863 [INFO ] [lipse.smarthome.model.script.Bedroom] - Living Color Lamps state changed!
2019-09-21 16:22:30.871 [INFO ] [lipse.smarthome.model.script.Bedroom] - Living Color Lamps state changed!
2019-09-21 16:22:30.875 [INFO ] [rthome.model.script.Bedroom 01 Timer] - Thereās no running timer. Creating oneā¦
2019-09-21 16:22:30.883 [INFO ] [rthome.model.script.Bedroom 01 Timer] - Thereās no running timer. Creating oneā¦
2019-09-21 16:22:30.893 [INFO ] [rthome.model.script.Bedroom 01 Timer] - Timer createdā¦
2019-09-21 16:22:30.905 [INFO ] [rthome.model.script.Bedroom 01 Timer] - Timer createdā¦
2019-09-21 16:22:31.704 [INFO ] [eclipse.smarthome.model.script.hue_3] - 215,4,0
2019-09-21 16:22:31.712 [INFO ] [eclipse.smarthome.model.script.hue_4] - 232,3,0
2019-09-21 16:22:31.718 [INFO ] [eclipse.smarthome.model.script.hue_5] - 215,4,0
2019-09-21 16:22:31.725 [INFO ] [marthome.model.script.triggeringItem] - hue_0200_0017884dd999_4_color (Type=ColorItem, State=232,3,0, Label=Color, Category=null, Tags=[Lighting])
2019-09-21 16:22:31.759 [INFO ] [lipse.smarthome.model.script.Bedroom] - all Living Color Lamps are switched OFF!
2019-09-21 16:22:31.762 [INFO ] [lipse.smarthome.model.script.Bedroom] - letās see, if thereās a running timerā¦
2019-09-21 16:22:31.768 [INFO ] [lipse.smarthome.model.script.Bedroom] - found a running timer. Cancellingā¦
2019-09-21 16:22:31.773 [INFO ] [lipse.smarthome.model.script.Bedroom] - set timer to nullā¦
