I just switched from manual install to apt-get (online not offline) but as I get into PaperUI to enable Zwave etc, I notice there is no HabAdmin UI Plugin to enable?
Is this just intended to be downloaded manually? Or am I missing something? Just making sure I’m following best practice. \
How recent is the apt build? Is it updated nightly? I would guess that it’s too old to have HABmin included (but that’s a guess). If it’s older than about the middle of last week, then it won’t be included yet.
@sihui - ('m actually good on the Zwave part - just curious about habmin really but that’s good stuff you posted up for reference, thank you!
@chris - I got it from the newly updated linux apt-get (“openhab2 beta”) not the snapshot one (so was ASSUMING it was nightly). I did download the manual install and it was there and that was snapshot from about last week.
I’m not familiar with the apt releases, however in general, if you’re using the beta version, then it’s a fixed snapshot. The last beta (beta3) was a few months ago from memory - it’s not updated until there’s a new release.
If you want a nightly update, then you need to use the snapshot version.
W: The repository 'https://openhab.ci.cloudbees.com/job/openHAB-Distribution/ws/distributions/openhab-offline/target/apt-repo Release' is not signed.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: The repository 'https://openhab.ci.cloudbees.com/job/openHAB-Distribution/ws/distributions/openhab-online/target/apt-repo Release' is not signed.
E: Failed to fetch https://openhab.ci.cloudbees.com/job/openHAB-Distribution/ws/distributions/openhab-offline/target/apt-repo/Release Unable to find expected entry 'Packages' in Release file (Wrong sources.list entry or malformed file)
E: Failed to fetch https://openhab.ci.cloudbees.com/job/openHAB-Distribution/ws/distributions/openhab-online/target/apt-repo/Release Unable to find expected entry 'Packages' in Release file (Wrong sources.list entry or malformed file)
Until I get it figured out (some sysadmin I am - I blame lack of time) I just did the manual install and added the systemd stuff manually per the manual and it’s working a treat.
Although in both versions HabMin seems to be the older style.. I’m still messing around with it.
Hi Branden,
What do you mean? How old, and what install did you do? A manual install on OH2 should just be a case of taking the JAR and dropping it into the addons folder. If you’ve grabbed the latest JAR, it shouldn’t be an ‘older style’.
Yup - I didn’t follow that in the end - I decided to go with the manual install. Which I’m okay with.
That isn’t an OH problem - it’s how Ubuntu is acting about non trusted sources - I’m sure there is a write up somewhere on that error
I would search on Data from such a repository can’t be authenticated and is therefore potentially dangerous to use.
Hello @m3ld0n, I didn’t encounter your problem but please follow the guide to install the snapshot release and try installing with apt --yes --force-yes install openhab2-offline.
Hello @ThomDietrich, thats the guide I have been using. Weird thing is, I can install the fixed beta release with the steps on that guide without issues. Ran the commands you mentioned and still having trouble:
E: The repository 'https://openhab.ci.cloudbees.com/job/openHAB-Distribution/ws/distributions/openhab-offline/target/apt-repo Release' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
E: The repository 'https://openhab.ci.cloudbees.com/job/openHAB-Distribution/ws/distributions/openhab-online/target/apt-repo Release' is not signed.
I did a purge of the previous installations but not sure if there may be some conflicting files/configuration left…
Yep I’m on 16.04. Already tried the –allow-unauthenticated option with the same result
Also removed the apt-key I added when installing the fixed beta, just in case. Same problem.
Tested myself on a Ubuntu 16.04 installation without success. Maybe this can be solved by an extra setup step, but this should better be solved on server side - if possible.
