Hi there,
I’m a well versed OH user in versions 1.x.
I’m migrating to OH an a parallel set up Pi.
All my bindings are working with all their items, even homematic.
But I don’t get the systemvariables working.
Setting TRACE for the homematic binding give me this:
foreach (sys_var_id, dom.GetObject(ID_SYSTEM_VARIABLES).EnumUsedIDs()) {
object var_obj = dom.GetObject(sys_var_id);
if (var_obj.Visible() == true) {
Write(" <entry");
Write(" name='"); WriteXML(var_obj.Name());
Write("' description='"); WriteXML(var_obj.DPInfo());
Write("' info='"); WriteXML(var_obj.Name());
Write("' value='"); WriteXML(var_obj.Value());
var var_type = "UNKNOWN";
if (var_obj.ValueType() == 2 ) { var_type = "BOOL"; }
if (var_obj.ValueType() == 16 ) { var_type = "ENUM"; }
if (var_obj.ValueType() == 4 ) { var_type = "FLOAT"; }
if (var_obj.ValueType() == 6 ) { var_type = "FLOAT"; }
if (var_obj.ValueType() == 8 ) { var_type = "INTEGER"; }
if (var_obj.ValueType() == 20 ) { var_type = "STRING"; }
Write("' valueType='"); WriteXML(var_type);
if (var_type == "ENUM") {
Write("' options='"); WriteXML(var_obj.ValueList());
if ((var_type == "FLOAT") || (var_type == "INTEGER")) {
Write("' min='"); WriteXML(var_obj.ValueMin());
Write("' max='"); WriteXML(var_obj.ValueMax());
Write("' unit='"); WriteXML(var_obj.ValueUnit());
Write("' readOnly='false'");
Write(" />\n");
Write("</list>");
2017-02-18 18:11:50.857 [TRACE] [tic.internal.communicator.CcuGateway] - Result TclRegaScript: <?xml version="1.0" encoding="ISO-8859-1" standalone="yes"?>
<list>
<entry name='Anwesenheit' description='Anwesenheit' info='Anwesenheit' value='true' valueType='BOOL' unit='' readOnly='false' />
<entry name='Gaszaehler' description='Gaszaehler' info='Gaszaehler' value='109713.000000' valueType='FLOAT' min='0' max='1.700000000000001e+308' unit='dl' readOnly='false' />
<entry name='Leistung' description='Leistung' info='Leistung' value='307.000000' valueType='FLOAT' min='0' max='1.700000000000001e+308' unit='W' readOnly='false' />
<entry name='Stromzaehler' description='Stromzaehler' info='Stromzaehler' value='223281.199951' valueType='FLOAT' min='0' max='1.700000000000001e+308' unit='Wh' readOnly='false' />
<entry name='TVSanja' description='TVSanja' info='TVSanja' value='false' valueType='BOOL' unit='' readOnly='false' />
<entry name='Wasserzaehler' description='Wasserzaehler' info='Wasserzaehler' value='4972.000000' valueType='FLOAT' min='0' max='1.700000000000001e+308' unit='l' readOnly='false' />
<entry name='WWHysterese' description='WW Hysterese' info='WWHysterese' value='5.000000' valueType='FLOAT' min='5' max='20' unit='°C' readOnly='false' />
<entry name='WWSolltemperatur' description='WW Solltemperatur' info='WWSolltemperatur' value='0.000000' valueType='FLOAT' min='0' max='75' unit='°C' readOnly='false' />
</list>
2017-02-18 18:11:50.884 [ERROR] [very.HomematicDeviceDiscoveryService] - java.lang.String cannot be cast to java.lang.Number
java.lang.ClassCastException: java.lang.String cannot be cast to java.lang.Number
at org.openhab.binding.homematic.internal.communicator.parser.CcuVariablesAndScriptsParser.parse(CcuVariablesAndScriptsParser.java:46)[200:org.openhab.binding.homematic:2.1.0.201702180650]
at org.openhab.binding.homematic.internal.communicator.CcuGateway.loadVariables(CcuGateway.java:107)[200:org.openhab.binding.homematic:2.1.0.201702180650]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.loadChannelValues(AbstractHomematicGateway.java:464)[200:org.openhab.binding.homematic:2.1.0.201702180650]
at org.openhab.binding.homematic.internal.communicator.CcuGateway.loadChannelValues(CcuGateway.java:134)[200:org.openhab.binding.homematic:2.1.0.201702180650]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.loadAllDeviceMetadata(AbstractHomematicGateway.java:383)[200:org.openhab.binding.homematic:2.1.0.201702180650]
at org.openhab.binding.homematic.discovery.HomematicDeviceDiscoveryService$1.run(HomematicDeviceDiscoveryService.java:108)[200:org.openhab.binding.homematic:2.1.0.201702180650]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_65]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_65]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)[:1.8.0_65]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)[:1.8.0_65]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_65]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_65]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_65]
2017-02-18 18:11:50.926 [DEBUG] [very.HomematicDeviceDiscoveryService] - Homematic device discovery scan finished
2017-02-18 18:11:50.931 [TRACE] [nal.communicator.client.BinRpcClient] - Client BinRpcRequest:
rssiInfo()
All my variables come in the list, but after that nothing from GATEWAY EXTRAS is there.
After
nothing useful is in the log.
The thing is shown as “undefined” if I configure it.
I tried all variants: manual configuration via *.things and *.item files, minimal conf and auto discovery, all with the same result.
Please help, what am I doing wrong here?
Thanks, Thomas
