- Platform information:
- Hardware: Oracle Virtual Machine (2xCPU/2GB RAM)
- OS: Kali Linux
- Java Runtime Environment: JDK 11.0.14
- openHAB version: 3.2 (Docker)
- Issue of the topic:
I want to use Pico TTS to get OH audio feedback.
- I installed Pico on the HOST following the documentation:
sudo apt-get install libttspico-utils
- On host I have the pico2wave binary available and executable.
- I installed the Pico Text-to-Speech bundle via BASIC UI. Afterwards I could select the Pico TTS in the voice settings of administarstion panel.
- I created a rule which should execute
say("Lautstärke wurde erhöht");
QUESTION: Do I need to link the Pico into the docker? Or do I need to install the Pico inside the docker? But doing this, it won’t be persistent.
Any recommendation or advise from you guys is appreciated!
- Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
I get this exeception in my openhab.log:
2022-02-24 15:47:58.670 [WARN ] [core.voice.internal.VoiceManagerImpl] - Error saying 'Lautstärke wurde erhöht': org.openhab.core.audio.AudioException: Error while executing '[Ljava.lang.String;@7102ba6c' org.openhab.core.voice.TTSException: org.openhab.core.audio.AudioException: Error while executing '[Ljava.lang.String;@7102ba6c' at org.openhab.voice.picotts.internal.PicoTTSService.synthesize(PicoTTSService.java:76) ~[?:?] at org.openhab.core.voice.internal.VoiceManagerImpl.say(VoiceManagerImpl.java:223) ~[?:?] at org.openhab.core.model.script.actions.Voice.say(Voice.java:121) ~[?:?] at org.openhab.core.model.script.actions.Voice.say(Voice.java:39) ~[?:?] at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?] at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?] at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?] at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1192) ~[?:?] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1167) ~[?:?] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1153) ~[?:?] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:1098) ~[?:?] at org.openhab.core.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:1008) ~[?:?] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:971) ~[?:?] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:247) ~[?:?] at org.openhab.core.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:227) ~[?:?] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:475) ~[?:?] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:251) ~[?:?] at org.openhab.core.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:227) ~[?:?] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:213) ~[?:?] at org.openhab.core.model.script.runtime.internal.engine.ScriptImpl.execute(ScriptImpl.java:80) ~[?:?] at org.openhab.core.model.script.runtime.internal.engine.DSLScriptEngine.eval(DSLScriptEngine.java:131) ~[?:?] at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.lambda$0(ScriptActionHandler.java:62) ~[?:?] at java.util.Optional.ifPresent(Optional.java:183) [?:?] at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.execute(ScriptActionHandler.java:59) [bundleFile:?] at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1180) [bundleFile:?] at org.openhab.core.automation.internal.RuleEngineImpl.runRule(RuleEngineImpl.java:988) [bundleFile:?] at org.openhab.core.automation.internal.TriggerHandlerCallbackImpl$TriggerData.run(TriggerHandlerCallbackImpl.java:89) [bundleFile:?] at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) [?:?] at java.util.concurrent.FutureTask.run(FutureTask.java:264) [?:?] at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) [?:?] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) [?:?] at java.lang.Thread.run(Thread.java:829) [?:?] Caused by: org.openhab.core.audio.AudioException: Error while executing '[Ljava.lang.String;@7102ba6c' at org.openhab.voice.picotts.internal.PicoTTSAudioStream.createInputStream(PicoTTSAudioStream.java:68) ~[?:?] at org.openhab.voice.picotts.internal.PicoTTSAudioStream.<init>(PicoTTSAudioStream.java:48) ~[?:?] at org.openhab.voice.picotts.internal.PicoTTSService.synthesize(PicoTTSService.java:74) ~[?:?] ... 36 more Caused by: java.io.IOException: Cannot run program "pico2wave": error=2, No such file or directory at java.lang.ProcessBuilder.start(ProcessBuilder.java:1128) ~[?:?] at java.lang.ProcessBuilder.start(ProcessBuilder.java:1071) ~[?:?] at java.lang.Runtime.exec(Runtime.java:592) ~[?:?] at java.lang.Runtime.exec(Runtime.java:451) ~[?:?] at org.openhab.voice.picotts.internal.PicoTTSAudioStream.createInputStream(PicoTTSAudioStream.java:61) ~[?:?] at org.openhab.voice.picotts.internal.PicoTTSAudioStream.<init>(PicoTTSAudioStream.java:48) ~[?:?] at org.openhab.voice.picotts.internal.PicoTTSService.synthesize(PicoTTSService.java:74) ~[?:?] ... 36 more Caused by: java.io.IOException: error=2, No such file or directory at java.lang.ProcessImpl.forkAndExec(Native Method) ~[?:?] at java.lang.ProcessImpl.<init>(ProcessImpl.java:340) ~[?:?] at java.lang.ProcessImpl.start(ProcessImpl.java:271) ~[?:?] at java.lang.ProcessBuilder.start(ProcessBuilder.java:1107) ~[?:?] at java.lang.ProcessBuilder.start(ProcessBuilder.java:1071) ~[?:?] at java.lang.Runtime.exec(Runtime.java:592) ~[?:?] at java.lang.Runtime.exec(Runtime.java:451) ~[?:?] at org.openhab.voice.picotts.internal.PicoTTSAudioStream.createInputStream(PicoTTSAudioStream.java:61) ~[?:?] at org.openhab.voice.picotts.internal.PicoTTSAudioStream.<init>(PicoTTSAudioStream.java:48) ~[?:?] at org.openhab.voice.picotts.internal.PicoTTSService.synthesize(PicoTTSService.java:74) ~[?:?] ... 36 more
=> Caused by: java.io.IOException: Cannot run program “pico2wave”: error=2, No such file or directory
