Hi All
Wondering if there is a way to access a THING via a Widget somehow?
I would like to access the settings of a THING used in the Paradox Binding.
I can see the details via the Rest API as follows:
https://10.163.199.252:8443/rest/things/paradoxalarm%3Aip150%3AParadoxIP150
Which gives:
"channels": [
"linkedItems": [],
"uid": "paradoxalarm:ip150:ParadoxIP150:communicationCommand",
"id": "communicationCommand",
"channelTypeUID": "paradoxalarm:command",
"itemType": "String",
"kind": "STATE",
"label": "Communicator Command",
"description": "Send Command",
"defaultTags": [],
"properties": {},
"configuration": {}
"linkedItems": [
"ParadoxIP150ModuleConnector_BridgeCommunicationState"
"uid": "paradoxalarm:ip150:ParadoxIP150:communicationState",
"id": "communicationState",
"channelTypeUID": "paradoxalarm:communicationState",
"kind": "STATE",
"label": "Bridge Communication State",
"description": "Status of connection to Paradox system",
"defaultTags": [],
"properties": {},
"configuration": {}
"statusInfo": {
"status": "ONLINE",
"statusDetail": "NONE"
"editable": true,
"label": "Paradox IP150 Module Connector",
"configuration": {
"pcPassword": "<REDACT>",
"maxPartitions": 4,
"port": 10000,
"encrypt": false,
"ipAddress": "10.163.199.226",
"ip150Password": "<REDACT>",
"maxZones": 24,
"refresh": 5,
"reconnectWaitTime": 30,
"panelType": "EVO192"
"properties": {},
"UID": "paradoxalarm:ip150:ParadoxIP150",
"thingTypeUID": "paradoxalarm:ip150"
What I specifically would like to access are the two settings:
"maxPartitions": 4,
"maxZones": 24,
These would make my widget a bit more self contained if they were accessible.
Any advise would as usual be appreciated.
Mark
