OH3 - Addons section suddenly dissapeared
Hello everybody,
I have been running OH3 on raspberry pi for a few days without issues. I had setup a couple of lights, motion & temperature sensors (aqara) and so on. For that, i had to install a few bindings (e.g HUE, network, Xiaomi, etc)
The other day I wanted to add more functionalities to OH3, and when I was going to add a new binding, i found out that the ADDONS section completly dissapeared! Therefore, i cannot add new bindings.
I do not know when this happened, or what caused the issue as I have NOT been doing any configuration or maintenance on OH3.
Any ideas of what could be the issue here? my things & items still work (with the previously installed bindings)
Thanks in advance
did your admin login session expire? You may need to log out and log back in.
I did that already. I signed out & signed in, close all open sessions… but same issue.
All I can recommend is to file an issue. I’ve not see anyone report this behavior so far.
Thank you,
just did it
https://github.com/openhab/openhab-webui/issues/802
Just a wild guess, did you change the Add-on Management setting from Access Remote Repository ON to OFF?
Hi !
I did not change anything there. but cleaning the cache solved the issue!
