I have configured a widget to switch light on and off but also to select light scenes.
uid: LightWithScenes
tags: []
props:
parameters:
- description: The name of the Room
label: Description
required: true
type: TEXT
- description: Can be oh:icon or f7:icon
label: Icon
required: true
type: TEXT
- context: item
description: The Switch Item
label: The Switch Item
required: true
type: TEXT
- description: The Name of the Scene
label: Name
required: false
type: TEXT
groupName: sceneOne
- description: The color of the icon and text
label: Color
required: false
type: TEXT
groupName: sceneOne
- description: The f7-icon of the scene (set to something to make button visible)
label: Icon
required: false
type: TEXT
groupName: sceneOne
label: Name
required: false
type: TEXT
groupName: sceneTwo
label: Color
required: false
type: TEXT
groupName: sceneTwo
label: Icon
required: false
type: TEXT
groupName: sceneTwo
label: Name
required: false
type: TEXT
groupName: sceneThree
label: Color
required: false
type: TEXT
label: Icon
required: false
type: TEXT
label: Name
required: false
type: TEXT
groupName: sceneFour
label: Color
required: false
type: TEXT
label: Icon
required: false
type: TEXT
parameterGroups:
- name: sceneOne
context: action
label: Scene one
- name: sceneTwo
context: action
label: Scene two
- name: sceneThree
context: action
label: Scene three
- name: sceneFour
context: action
label: Scene four
timestamp: Mar 15, 2021, 6:42:20 PM
component: f7-card
outline: false
noBorder: false
padding: true
noShadow: false
style:
--f7-card-margin-horizontal: 5px
--f7-card-content-padding-vertical: 0px
--f7-card-content-padding-horizontal: 16px
--f7-card-border-radius: 15px
--f7-card-box-shadow: 0px 5px 10px rgba(0,0,0,0.15)
--f7-card-header-font-size: 14px
--f7-card-header-font-weight: 600
slots:
content:
- component: oh-label-card
noShadow: true
title: =(props.title)
action: toggle
actionItem: =(props.item)
trendItem: =(props.item)
actionCommand: ON
actionCommandAlt: OFF
item: =(props.item)
background: '=(items[props.switchItem].state > 0) ? "#f5e628" : ""'
footer: Oben an/aus - unten Szenen
icon: =(props.icon)
vertical: false
- component: f7-row
class:
- padding-bottom
- padding-right
slots:
default:
- component: f7-col
slots:
default:
- component: oh-button
actionPropsParameterGroup: sceneOne
title: =(props.nameSceneOne)
iconF7: =(props.iconSceneOne)
text: =(props.nameSceneOne)
iconColor: =(props.colorSceneOne)
textColor: =(props.colorSceneOne)
visible: "=props.iconSceneOne ? true : false"
- component: f7-col
slots:
default:
actionPropsParameterGroup: sceneTwo
title: =(props.nameSceneTwo)
iconF7: =(props.iconSceneTwo)
text: =(props.nameSceneTwo)
iconColor: =(props.colorSceneTwo)
textColor: =(props.colorSceneTwo)
visible: "=props.iconSceneTwo ? true : false"
- component: f7-col
slots:
default:
actionPropsParameterGroup: sceneThree
title: =(props.nameSceneThree)
iconF7: =(props.iconSceneThree)
text: =(props.nameSceneThree)
iconColor: =(props.colorSceneThree)
textColor: =(props.colorSceneThree)
visible: "=props.iconSceneThree ? true : false"
- component: f7-col
slots:
default:
actionPropsParameterGroup: sceneFour
title: =(props.nameSceneFour)
iconF7: =(props.iconSceneFour)
text: =(props.nameSceneFour)
iconColor: =(props.colorSceneFour)
textColor: =(props.colorSceneFour)
visible: "=props.iconSceneFour ? true : false"
I configured four buttons which are only visible if an icon is configured. I would prefer to choose visibility based on “if a item is configured or not”
Does someone know how I can access the item configured as e.g.
Thank you
Best regards
PeterK
[Edit 16.03.2021]
Access to the state of the item is possible when context:item is used.
The example above uses context: action. This is great, as the custom widget is much more flexible and it is very easy to implement but there is not much documentation as e.g. how to get to the state of the item (see post #3 and #5).
By if an item is configure you mean the props? Have you tried =props.Item !== undefined or something like that? I don’t know if you don’t enter a prop whether it remains undefined or gets some default. If undefined doesn’t work I suspect the default will be either null or "".
This works perfectly for the click event. The problem is, that I don’t know how to access the item to get information as I only have the name of the group.
I tried items[props.sceneOne].state and several other combinations, but this did not do the trick.
Except in the oh-repeater widget, all you have access to is the Item’s state and displayState. You can’t get the Groups it’s a member of, the Items label, if it’s a Group you can’t get it’s members, the tags, metadata or anything else. Just state which is the raw state and optionally displayState which is the state formatted based on the “State Description” Item metadata. displayState doesn’t exist when the State Description metadata is not defined.
In your own personal widgets (see below), you can define a parameter group with an action context to automatically define implicit props that you can pass “en masse” to built-in components that accept actions with the actionPropsParameterGroup property:
I just tried it and I am excited about the possibilities… but I run into problems when I want to access the state of the item configured in the action (or anything else configured in the action)
Basically, the property names will be: {groupName}_{actionPropName}
The list of actionPropNames can be found here (they’re always the same):
The other thing is that occurrences of the word “action” will be removed from groupName in the prefix (and the underscore will also be removed if you name the group “action” so there is no prefix anymore)!
Confusing, I know, but this is to avoid weird prop names like tapAction_action or _actionCommand.
Tip: You can dump the props object as JSON to figure out the prop names: =JSON.stringify(props)
tags: []
props:
parameters:
label: Description
required: true
type: TEXT
label: Icon
required: true
type: TEXT
- context: item
required: true
type: TEXT
label: Name
required: false
type: TEXT
groupName: sceneOne
label: Color
required: false
type: TEXT
groupName: sceneOne
label: Icon
required: false
type: TEXT
groupName: sceneOne
label: Name
required: false
type: TEXT
groupName: sceneTwo
label: Color
required: false
type: TEXT
groupName: sceneTwo
label: Icon
required: false
type: TEXT
groupName: sceneTwo
label: Name
required: false
type: TEXT
label: Color
required: false
type: TEXT
label: Icon
required: false
type: TEXT
label: Name
required: false
type: TEXT
label: Color
required: false
type: TEXT
label: Icon
required: false
type: TEXT
parameterGroups:
- name: sceneOne
context: action
label: Scene one
- name: sceneTwo
context: action
label: Scene two
- name: sceneThree
context: action
label: Scene three
- name: sceneFour
context: action
label: Scene four
timestamp: Mar 16, 2021, 8:34:03 PM
component: f7-card
outline: false
noBorder: false
padding: true
noShadow: false
style:
slots:
content:
noShadow: true
action: toggle
actionCommand: ON
item: =(props.item)
background: '=(items[props.item].state > 0) ? "#f5e628" : ""'
icon: =(props.icon)
vertical: false
- component: f7-row
class:
- padding-bottom
- padding-right
slots:
default:
- component: f7-col
slots:
default:
visible: "=props.sceneOne_actionItem ? true : false"
- component: f7-col
slots:
default:
visible: "=props.sceneTwo_actionItem ? true : false"
- component: f7-col
slots:
default:
visible: "=props.sceneThree_actionItem ? true : false"
- component: f7-col
slots:
default:
visible: "=props.sceneFour_actionItem ? true : false"
