I have a bunch of rules that send an email to me.
However, I want to make this more manageable, so that it can b changed in one location.
My idea was to create an string item Const_Email_Admin with the email address, and then use a global value on top of the respective rules, like so:
val String EMAIL_ADMIN = Const_Email_Admin.state.toString()
However, I get an error:
Cannot reference the field 'Const_Email_Admin' before it is defined
… and am a loss what this means, more so why it says that.
Any hints appreciated.
This seems to imply that this does not work as a matter of principle.
Is the solution then having to put it into the respective rules which send email?
Is that it?
Maybe I was too smart for myself
This works:
mailActions.sendMail
Const_Email_Admin.state.toString(),
"Alert: " + DEVICE_NAME + " weirdly switched OFF",
"This plug seemingly switched OFF while supposed to be always ON."
In case one wonders why that weird message is there…
I have SmartPlugs which seem to occasionally switch themselves OFF. I have a switch item which forces a plug state. If this is ON, a change of the plug to OFF will check against the ‘forced’ state and corrects it. Seems to work so far (for ten months.)
not sure if i got you completely… so maybe you can post your complete rule?
but this should work…:
rule "Send Notification when Text changed"
Item Notification received update
if(!Notification.state.toString().isEmpty() && (now.getHour() >= 8 && now.getHour() <= 22) )
sendNotification(Receivers.state.toString(), Notification.state.toString())
rule "SYSTEM_START_RULE"
System started
postUpdate(Receivers, "foo@bar.com")
I was initially assigning an item state to a global constant.
That produced an error.
I then created a string item, which holds an email address.
This string item’s state was then used to as the first parameter for the mailAction.
This is the solution to the initial problem. The rule snippet shown works.
I think that there is no item definition like this
String Const_Email_Admin "E-Mail address of the admin"
and if so you have fill the item with the initial E-Mail address, after that you can use it with your global constant. If you use an item you should persist it.
For my understanding it is easier to set the global value direct with
Drat, I list my long reply. Here’s a shortened one.
Global variables only get populated when the. rules file is loaded. At this time:
Items are still being loaded so the Item may not yet exist
restoreOnStartup is still processing so if the Item exists it may not have a usable state
Changes in the Item’s state that happen after the .rules file is loaded won’t change the name of the global variable.
For all these reasons you should never use the state of an Item to populate a global variable in a .rules file.
In this case it just saves a few characters anyway. It doesn’t make your rules logically any simpler.
You have three choices:
Just use the Item in your rules. That will pull the Item’s state on demand and will always return the latest state.
Create a global lambda that returns the Item’s state on demand.
Centralize your email code in a Rules DSL Script called using callScript or using /design-pattern-separation-of-behaviors (just rewritten for OH 4) and then your email address will only be used in one place anyway and this whole problem goes away. This has the added benefit that you can change to Telegram or add logic to send different ways based on the time of day and presence, for example.
Frankly, for something like this 2 is kind of asinine and I don’t recommend it. 1 and 3 though are good options.
In the other rules languages you have a fourth option to put the email variable into a personal library and import it into your roles instead of using an Item.
