[OH3] Cant get data via HTTP + JSON
Good day,
i am in the middle of a OH2->OH3-Migration and struggeling with some HTTP-Get-Commands.
In OH2.5.6 i made a item like this:
String HueMotionSensor001_Name { http=“<[http://IP-ADRESS/api/USERNAME/sensors/3:60000:JS(getHueName.js)]” }
and could resolve the Clear-Name of a Hue Device from my Hue Bridge.
This is just for an example. I have several items like this.
Since OH3.0.0 i am not able to get this working.
Bindings installed: HTTP, JSONPath Transform, HUE
Unfortunately i cant see any errors in the logs or something. Its just receiving nothing and doing nothing.
Content of GetHueName.js:
(function(i) {
var json = JSON.parse(i);
return ((json[‘name’]));
})(input)
Do you have any hints for me?
Why not use the JSONPATH transformation directly in your Thing Channel?
And just to check: you’re aware that your syntax that you showed is for the V1 binding, but openHAB 3 has a V3 binding which is no longer compatible with v1 configurations?
The short answer is: It worked like a charm before and i am not sure how to do this in text-file-format.
Can you give me an example?
I am using Text-file-Format only for backup- and migrations-purposes, since it seems more complicated for me to backup/export your data from “GUI-created” things/items/… Would you agree?
Yes, i am aware of the canceled v1-bindings, but since i am not sure how to improve my code in v3 i landed here.
I read the Binding-manuals before, but it seems not to solve my problem.
I would be very thankful for help :slight_smile:
Can you show us what the JSON string looks like as sent by your Hue Bridge? I can then provide an example text file configuration.
Well, the item shown in my first post is everything which was needed in OH2.5.6 to receive a name like “Badezimmer” from my HUE Bridge, where are several things/items/sensors located.
So for example HueMotionSensor001_Name gets its name every xx seconds (sure, a name isn’t changing often, but just for example).
No rule, no thing or something more was needed.
I am thankful for you reply, but unfortunately i can’t serve with more details :frowning:
Right, but your old Item used a JS transform to extract some information from a JSON string which was sent by your Hue Bridge. Can you show me what this JSON string looks like so I can be certain of the correct transformation to apply?
Ah ok, i hope this helps:
URL: http://192.168.2.XX/api/USERNAME-WITHOUT-A-PW/sensors/3
I am searching for “name”.
  • state: {
    • presence: false,
    • lastupdated: “2021-01-05T14:58:14”},
  • swupdate: {
    • state: “noupdates”,
    • lastinstall: “2019-12-23T14:05:54”},
  • config: {
    • on: true,
    • battery: 79,
    • reachable: true,
    • alert: “none”,
    • ledindication: false,
    • usertest: false,
    • sensitivity: 2,
    • sensitivitymax: 2,
    • pending: },
  • name: “Sensor Flur”,
  • type: “ZLLPresence”,
  • modelid: “SML001”,
  • manufacturername: “Signify Netherlands B.V.”,
  • productname: “Hue motion sensor”,
  • swversion: “6.1.1.27575”,
  • uniqueid: “00:17:88:01:03:29:f2:xx-xx-xxxx”,
  • capabilities: {
    • certified: true,
    • primary: true}
OK, so that’s
   "state":{
      "presence":false,
      "lastupdated":"2021-01-05T14:58:14"
   "swupdate":{
      "state":"noupdates",
      "lastinstall":"2019-12-23T14:05:54"
   "config":{
      "on":true,
      "battery":79,
      "reachable":true,
      "alert":"none",
      "ledindication":false,
      "usertest":false,
      "sensitivity":2,
      "sensitivitymax":2,
      "pending":[
   "name":"SensorFlur",
   "type":"ZLLPresence",
   "modelid":"SML001",
   "manufacturername":"SignifyNetherlandsB.V.",
   "productname":"Huemotionsensor",
   "swversion":"6.1.1.27575",
   "uniqueid":"00:17:88:01:03:29:f2:xx-xx-xxxx",
   "capabilities":{
      "certified":true,
      "primary":true
Thing
Save the following in a file called hue.things inside your things folder. You can actually call it anything you like, as long as it has .things on the end.
Thing http:url:hue "Hue" [
	baseURL = "http://192.168.2.xx/api/USERNAME-WITHOUT-A-PW",
	refresh = "60000",
	ignoreSSLErrors = "true"
	Channels:
		Type string: name3 "Sensor 3 Name" [
			mode = "READONLY",
			stateExtension = "/sensors/3",
			stateTransformation = "JSONPATH:$.name"
Item
Reconfigure your Item to look like:
String HueMotionSensor001_Name { channel="http:url:hue:name3" }
Further
If you wanted to get your battery state, for example, your transformation becomes:
"JSONPATH:$.config.battery"
which you could configure into a Number Channel, and a Number Item.
Many thanks !!
First it was not able to fill in the name to the item and nothing appeared in the logs.
After i added some additional and non-optional stuff (according to HTTP - Bindings | openHAB) like
timeout = “3000”,
buffersize = “2048”,
delay = “0”,
authMode = “BASIC”,
commandMethod = “GET”
it suddently pulls the name inside the item :smiley:
2021-01-05 21:11:33.812 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘HueMotionSensor001_Name’ changed from NULL to Sensor Flur
Again: Many thanks, marked as Solution and stay healthy :slight_smile:
That’s strange - you shouldn’t need those. Whilst it says they are non-optional, they are also provided with default values by the binding so if they’re not specified the Thing should still work. I suspect either you didn’t wait long enough for data to come in, or you’re hitting the age-old issue where openHAB doesn’t always properly load a Things file after it has been saved. You can restart openHAB if this happens, or do this.
Either way, doesn’t really matter - glad you’ve got it working!
