[OH3] Charts with Apache ECharts
Hey guys,
with the upgrade to openHAB 3 I experimented a little bit with the new charts.
I got a lot of information from apache echarts (Apache ECharts).
My example for inspiration.
Based on Influx DB.
In the example you can see the configruation of:
- markPoint
grafik
- chart-datazoom
grafik
- chart-tooltip
- Definition ,markLine’’
see in the yaml
- gradient Color of ,areaStyle’’
see in the yaml
- Definition of line-color with ,lineStyle’’
see in the yaml
and so on
Yaml Example
  label: Klima Wohnzimmer
  sidebar: true
  period: W
slots:
  grid:
    - component: oh-chart-grid
        show: true
        left: 50
        right: 50
        height: 35%
        show: true
        left: 50
        right: 50
        top: 50%
        height: 35%
  xAxis:
    - component: oh-time-axis
        gridIndex: 0
        boundaryGap: false
        axisLine:
          onZero: true
        show: false
        gridIndex: 1
        boundaryGap: false
        position: top
        axisLine:
          onZero: true
  yAxis:
    - component: oh-value-axis
        gridIndex: 0
        min: "17"
        max: "25"
        axisLabel:
          formatter: "{value} °C"
        gridIndex: 0
        show: false
        min: "0"
        max: "5"
        nameLocation: center
        splitLine:
          show: false
        gridIndex: 1
        inverse: true
        min: "0"
        max: "100"
        splitLine:
          show: false
  series:
    - component: oh-time-series
        name: Ist Temp. Indoor
        gridIndex: 0
        xAxisIndex: 0
        yAxisIndex: 0
        type: line
        lineStyle:
          color: rgb(226, 170, 14)
        item: act_temp_WZ
        smooth: true
        markPoint:
          itemStyle:
          data:
            - type: max
            - type: min
        markLine:
          data:
            - type: average
        name: Soll Temp. Indoor
        gridIndex: 0
        xAxisIndex: 0
        yAxisIndex: 0
        type: line
        lineStyle:
          color: rgb(70, 123, 168)
        item: set_temp_WZ
        gridIndex: 0
        xAxisIndex: 0
        yAxisIndex: 1
        type: line
        lineStyle:
          color: rgb(98, 217, 81)
        step: end
        areaStyle: {}
        item: state_ventil_WZ
        gridIndex: 1
        xAxisIndex: 1
        yAxisIndex: 2
        type: line
        lineStyle:
        areaStyle:
          color:
            type: linear
            x: 0
            y: 0
            x2: 0
            y2: 1
            colorStops:
              - offset: 0
                color: rgb(70, 123, 168, 0.0)
              - offset: 0.5
                color: rgb(70, 123, 168, 0.5)
              - offset: 1
                color: rgb(70, 123, 168, 1.0)
        item: hum_WZ
        smooth: true
  title:
    - component: oh-chart-title
        show: true
        text: Klima Test
  tooltip:
    - component: oh-chart-tooltip
        show: true
        orient: vertical
        trigger: axis
        axisPointer:
          type: cross
  legend:
    - component: oh-chart-legend
        show: true
        orient: horizontal
  dataZoom:
    - component: oh-chart-datazoom
        show: true
        type: slider
        orient: horizontal
        start: 30
        end: 70
        xAxisIndex:
          - 0
          - 1
if you’d share the YAML code, maybe this could be useful for others, too! :slight_smile:
All the best,
Bob
Hi @BobMiles ,
i’ve updated my post with the yaml.
Have fun :wink:
best,
Nico
Thanks a lot! :slight_smile:
Good stuff!
Little trick, you can define raw ECharts options in the options parameter on the chart itself, at the root level. They will be merged with the components’ options.
For instance, since you have multiple grids with similar charts in them, you might want to link the axis pointers:
  options:
    axisPointer:
      link:
        xAxisIndex: all
Example here: demo
(login first with demo/demo and try again if it doesn’t work)
Docs: Documentation - Apache ECharts
Nice trick! :wink:
Thanks a lot @ysc !
