NCO
(E. Gerland)
July 25, 2021, 6:57am
1
I am running OH3.1 on a NUC and use DSL rules.
My km200 (buderus heating) temperatures are setup as temperature:
Number:Temperature Heat_HzSollDay "Wunsch-Temperatur" <temperature> (G_Num,G_Heat,gLivingHeating) ["Setpoint", "Temperature"] {channel="km200:heatingCircuit:659200271:hc1:temperatureLevels_day", alexa="ThermostatController.targetSetpoint" [scale="Celsius"]}
I used to control it in my rules:
Heat_HzSollDay.sendCommand(20)
However, I get:
2021-07-25 07:27:20.480 [WARN ] [0.internal.handler.KM200ThingHandler] - Unsupported Command: 20 °C Class: class org.openhab.core.library.types.QuantityType
First I thought it’s related to this issue, but it’s obviously about basicUI only:
opened 07:31PM - 06 Jan 21 UTC
closed 09:50PM - 30 Jan 21 UTC
bug
basic ui
It appears that "number:temperature" items can't be contolled using setpoints in… basicUI or MainUI. When the setpoint is clicked, no change is observed in the item. If the item is changed to "number", it can be controlled with setpoint in BasicUI.
https://community.openhab.org/t/solved-knx-binding-issues-with-thermostat-oh3/112724
https://community.openhab.org/t/openhab-3-setpoint/112801
https://community.openhab.org/t/oh3-set-temperature-on-homematic/112902/2
In the second thread, it's noted that number-with-setpoint doesn't work in MainUI. However, that may be a separate issue.
Please let me know if there's anything more I can do to help solve this problem.
Thanks!
original here: https://github.com/openhab/openhab-core/issues/2067
I can control the temperature using Karaf:
openhab:update Heat_HzSollDay 20
EDIT:
These do not work in DSL rules:
Heat_HzSollDay.sendCommand(22 as Number)
Heat_HzSollDay.sendCommand(22|"°C")
Heat_HzSollDay.sendCommand(22.0)
Heat_HzSollDay.sendCommand(22 °C)
Heat_HzSollDay.sendCommand(22°C)
the first two return:
Unsupported Command: 22 °C Class: class org.openhab.core.library.types.QuantityType
the other two won’t load:
Configuration model 'heating.rules' has errors, therefore ignoring it: [96,29]: no viable alternative at input '°C'
rossko57
(Rossko57)
July 25, 2021, 10:14am
2
You’ve managed to guess just about every combination that won’t work.
Try these -
myItem.sendCommand("22.5 °C")
x = 22.5
myItem.sendCommand( x.toString + " °C" )
q = 22.5 | °C
myItem.sendCommand( q )
NCO
(E. Gerland)
July 25, 2021, 11:06am
3
Thank you!
Unfortunately none of these work:
Unsupported Command: 22.5 °C Class: class org.openhab.core.library.types.QuantityType
So it’s complaining, that in any case it’s not QuantityType (Number?) but a string!?
rossko57
(Rossko57)
July 25, 2021, 11:48am
4
I think we’re overlooking the important part of the message
It’s not the Number:Temperature Item complaining, that likes to be commanded “20 °C” and will pass it along to the binding.
Does KM200 binding actually support quantities, or have you linked a quantity Item to a regular number type channel? Docs are skimpy but no mention of quantities.
NCO
(E. Gerland)
July 25, 2021, 12:12pm
5
You are absolutely right.
I obviously did not see the wood from the trees…
I need to check this…
powerpolly
(Matthias P)
January 12, 2022, 7:41pm
6
same problem here. if I remove UoM from the item (Number:Temperature ) then it`s possible to control the temperature setpoint.
it seems the km200 binding needs to deal with regular numbers.
as a workaround I changed those items to Number items…
