What is the correct way to either specify the proper startOfDay, or this line: ZevaTempMin.postUpdate(ZevaTemperature.minimumSince(startOfDay).state) in OH3 speak.
Also, I have added these two lines to the rule file:
The error comes from VSCode editor.
VSC too needs to understand the differences between OH2 and OH3. Is it still connecting to an OH2 instance or something? Failing to connect to OH3 LISP service? This influences how it tries to validate your code, and the autocomplete options it offers you (which are helpful for this datetime stuff)
But that does means you can try out your modified rule in OH3, and look for “real” problems in OH3’s openhab.log
2022-11-01 22:33:46.206 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'zeva-5' failed: 2022-11-01T22:33:46.203180+10:00[Australia/Brisbane] is not in a valid format. in zeva
the second one says:
2022-11-01 22:40:46.207 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'zeva-5' failed: An error occurred during the script execution: Could not invoke method: org.openhab.core.model.script.actions.BusEvent.postUpdate(org.openhab.core.items.Item,org.openhab.core.types.State) on instance: null in zeva
What about ZevaLastUpdate.postUpdate(new DateTimeType())? When it’s not given anything, the constructor will assume now.
I would have expected the now.toString version to work though.
For the second one, what about ZevaLastUpdate.postUpdate(now.toString)? I know that DateTimeType’s toString will return an ISO8601 and Java’s ZonedDateTime returns a slightly different formatting standard. Maybe postUpdate only supports the latter.
When I switched to OH 3 I also switched languages so I am not sure about these problems. I suspect that the following will work too: ZevaLastUpdate.postUpdate(now.toLocalDateTime.toString). That will strip the timezone from the String which is usually the part that causes problems. It will assume the system timezone.
Note, if all that this rule is doing is updating a DateTime Item with now when an Item linked to a Channel updates or changes, you can achieve this with the timestamp profile and avoid the rule.
I don’t know what I was reading; probably too much
I copied the rule over and started changing things I thought I need changing, and didn’t even try what I had, which was ZevaLastUpdate.postUpdate(new DateTimeType()).
I will have a crack at the timestamp profile (later today).
JS Scripting. Of all the currently supported rules languages it meets all my requirements:
Requirement
Rules DSL
ECMAScript 5.1
Blockly
Jython
Java
jRuby
JS Scripting (ECMAScript 11)
Groovy
Well known outside of OH
X
X
X
X
X
X
X
Supports third party libraries
X
X
X
X
X
Comes with a helper library by default
NA
NA
NA?
X
NA?
Modern version of the language
X
X
X
X
X
X
Good support for UI rules/rule templates
Lacks “global vars”
X
X
Not supported in UI at all
Support getting better
X
For me, support for third party libs and UI support were the most important because I want to support and promote the use of rule templates which can only be written through the UI.
While the syntax and approach is a little different, the helper library for JS Scripting makes coding rules as easy as it is in Rules DSL. There are somethings that just work, and others that cause consternation, just like Rules DSL.
My second choice, given my requirements, would be Blockly, but I’ve long since grown out of graphically programming using blocks. But if you are not a programmer, I highly recommend it.
Hi, i have a similar problem since update from oh2.5 to oh3:
rule "Update Sole-VL Temperatur Min-Werte"
Item HeatPump_Temperature_6 received update
var Number Min
var String tmp
var SimpleDateFormat df = new SimpleDateFormat( "dd.MM., HH:mm" )
if (HeatPump_Temperature_6.state instanceof DecimalType) {
Min = (HeatPump_Temperature_6.minimumSince(now.minusDays(5), "rrd4j").state as DecimalType)
tmp = (Math::round(Min.floatValue*10.0)/10.0) + " °C (" + df.format(HeatPump_Temperature_6.minimumSince(now.minusDays(5), "rrd4j").timestamp) + " )"
HeatPump_Sole_VL_Min.postUpdate(tmp)
Gives me following error:
2022-12-20 11:26:56.591 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'heizung_anzeigen_usw-11' failed: Cannot format given Object as a Date in heizung_anzeigen_usw
Any idea which of the rule lines is the problem and has to be changed?
if (!(HeatPump_Temperature_6.state instanceof DecimalType)) {
return
val df = java.time.format.DateTimeFormatter.ofPattern("dd.MM., HH:mm")
val minimum = HeatPump_Temperature_6.minimumSince(now.minusDays(5), "rrd4j")
val value = minimum.state as DecimalType
val displayString = value.format("%.1f") + " °C (" + minimum.timestamp.format(df) + ")"
HeatPump_Sole_VL_Min.postUpdate(displayString)
And now hopefully my last problem with date and time…
errors from log: i think the came from the same rule
2022-12-20 13:48:00.431 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'temperatur_anzeigen-5' failed: Could not cast NULL to org.openhab.core.library.types.DateTimeType; line 99, column 24, length 30 in temperatur_anzeigen
2022-12-20 13:48:48.924 [WARN ] [b.core.model.script.actions.BusEvent] - Cannot convert '2022-12-20T13:48:48.923887+01:00[Europe/Berlin]' to a state type which item 'Xiaomi_Temp_7_last_connection' accepts: [DateTimeType, UnDefType].
Error from vscode
The method toInstant() is undefined for the type DateTimeItem
rule
rule "Update Xiaomi Temp time since"
Time cron "0 * * * * ?"
if(SystemStarting.state == OFF) {
gXiaomiZeit.members.forEach[ DateTimeItem lastTime |
//val lastMillis = (lastTime.state as DateTimeType).getZonedDateTime.toInstant.toEpochMilli
val lastMillis = lastTime.toInstant().toEpochMilli()
val mins = (now.toInstant().toEpochMilli() - lastMillis) / 60000
//val split = lastTime.split("_") // so we can reconstruct the time_since Item name
val split = lastTime.name.split('_')
(split.get(0)+"_"+split.get(1)+"_"+split.get(2)+"_time_since").postUpdate(mins.toString)
That was my change… You can see my old rule commented with //
Problem was the missing () because now it is the rule like before my changes - only with added ()
Thanks again!
But this error in the openhab-logs is still there:
2022-12-20 14:00:01.268 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'temperatur_anzeigen-5' failed: Could not cast NULL to org.openhab.core.library.types.DateTimeType; line 99, column 21, length 30 in temperatur_anzeigen
You’d also need to check to see if state is DateTimeType before casting it, because it can be UnDefType (NULL/UNDEF).
I know it is tedious! That’s why I don’t like rulesdsl / javascript
In jruby you’d do it like this:
rule "Update Xiaomi Temp time since" do
every :minute
only_if { SystemStarting.state.off? }
run do
gXiaomiZeit.members.select(&:state?).each do |last_time|
age = Time.now - last_time.state # You get a Java Duration here
name_parts = last_time.name.split("_")[0..2] + ["time_since"]
items[name_parts.join("_")].update(age.to_minutes.to_s)
In fact you shouldn’t do it using a cron rule. Just do it when the member items updated, like this:
updated gXiaomiZeit.members
run do |event|
age = Time.now - event.state # You get a Java Duration here
name_parts = event.item.name.split("_")[0..2] + ["time_since"]
I think i had it with change on every update, but then i didn´t get the right values inside my sitemap.
When value changes every hour, i will not get “last change 5 minutes before”, it will still be 0 minutes until the next update. So i used cron to renew the values every minute.
Next time, open a separate topic…we’ve gone way off topic here I think.
I am feeling a bit lost because I don’t really understand what your items are and what they’re supposed to do. I’m only responding to some syntax errors here and there. If you want to ask about the overall logic design, we’d need to understand and know a lot more background info.
