maggu2810
(maggu2810)
November 30, 2020, 3:11pm
1
Should the demo app bndrun be able to resolve if no local modifications has been done?
For me the resolution failed:
Resolution failed. Capabilities satisfying the following requirements could not be found:
[<<INITIAL>>]
⇒ osgi.identity: (osgi.identity=org.openhab.core.model.rule.runtime)
⇒ [org.openhab.core.model.rule.runtime version=3.0.0.202011301110]
⇒ osgi.wiring.package: (&(osgi.wiring.package=org.openhab.core.model.script)(version>=3.0.0)(!(version>=4.0.0)))
⇒ [org.openhab.core.model.script version=3.0.0.202011301109]
⇒ osgi.wiring.package: (&(osgi.wiring.package=org.openhab.core.audio)(version>=3.0.0)(!(version>=4.0.0)))
⇒ [org.openhab.core.audio version=3.0.0.202011301109]
⇒ osgi.wiring.package: (osgi.wiring.package=javazoom.jl.decoder)
bndrun shows “javazoom:jlayer” as “not a bundle”
maggu2810
(maggu2810)
November 30, 2020, 3:20pm
2
It seems the javazoom class files are bundled into the core.audio bundle only if it is built on console.
Should this work in the IDE, too?
maggu2810
(maggu2810)
November 30, 2020, 3:35pm
3
@wborn Is this solved by m2e-maven-dependency-plugin?
wborn
(Wouter Born)
November 30, 2020, 6:44pm
4
It should but after some testing it apparently only unpacks the dependencies if the dir /bundles/org.openhab.core.audio/target/classes already exists. So the first time you run it in Eclipse with an empty dir bnd adds those package imports… the second time when target/classes exists the dependency is properly unpacked and bnd doesn’t add those package imports.
ssalonen
(Ssalonen)
December 6, 2020, 10:24am
5
I had similar issues with bluetooth bundle and its libraries. Documented steps to resolve these issues: demo app issue with bluetooth.ruuvitag · Issue #1191 · openhab/openhab-distro · GitHub
system
(system)
Closed
January 17, 2021, 2:24am
6
