I upgraded to OH3 and I’m moving all my rules from file based to the main UI.
For my in-wall dimmers I need to know if there was a command before an update. Flipping the (physical) switch triggers only an update. (the physical switch toggles between OFF and last state, I want to toggle between OFF and full brightness)
Currently I have two rules in one file with a shared variable (BedRoom2commandTime) :
rule "BedRoom2Light: state changed"
Item BedRoom2Light_Dimmer changed
if((now.toInstant().toEpochMilli() - BedRoom2commandTime) < 2000){
return;
if(newState as Number > 0){
BedRoom2Light_Dimmer.sendCommand(100)
}else{
BedRoom2Light_Dimmer.sendCommand(OFF)
rule "BedRoom2Light: state command"
Item BedRoom2Light_Dimmer received command
BedRoom2commandTime = now.toInstant().toEpochMilli()
In main UI there is (afaik) no way to share variables between rules without using proxy items.
So I’m trying to figure out a way to determine if a rule was triggered by a command or an update. (so I can set a variable if it was a command) I have the following test rule:
triggers:
- id: "1"
configuration:
itemName: BedRoom2Light_Dimmer
type: core.ItemCommandTrigger
- id: "2"
configuration:
type: core.ItemStateUpdateTrigger
conditions: []
actions:
- inputs: {}
configuration:
type: application/vnd.openhab.dsl.rule
script: |
logInfo("TEST","==========BEGIN============")
if(receivedCommand !== null){
logInfo("TEST","COMMAND {}", receivedCommand)
if(newState !== null){
logInfo("TEST","UPDATE {}", newState)
logInfo("TEST","==========END==============")
type: script.ScriptAction
And it works only once; receivedCommand is not reset to null if the rule was triggered by an update:
Flip switch ON
2020-12-30 17:34:42.018 [INFO ] [org.openhab.core.model.script.TEST ] - ==========BEGIN============
2020-12-30 17:34:42.021 [INFO ] [org.openhab.core.model.script.TEST ] - UPDATE 50
2020-12-30 17:34:42.023 [INFO ] [org.openhab.core.model.script.TEST ] - ==========END==============
Flip switch OFF
2020-12-30 17:34:47.837 [INFO ] [org.openhab.core.model.script.TEST ] - ==========BEGIN============
2020-12-30 17:34:47.840 [INFO ] [org.openhab.core.model.script.TEST ] - UPDATE 0
2020-12-30 17:34:47.842 [INFO ] [org.openhab.core.model.script.TEST ] - ==========END==============
“command” from Openhab app (50%)
2020-12-30 17:35:11.354 [INFO ] [org.openhab.core.model.script.TEST ] - ==========BEGIN============
2020-12-30 17:35:11.358 [INFO ] [org.openhab.core.model.script.TEST ] - COMMAND 50
2020-12-30 17:35:11.362 [INFO ] [org.openhab.core.model.script.TEST ] - UPDATE 0
2020-12-30 17:35:11.363 [INFO ] [org.openhab.core.model.script.TEST ] - ==========END==============
Flip switch OFF
2020-12-30 17:35:23.329 [INFO ] [org.openhab.core.model.script.TEST ] - ==========BEGIN============
2020-12-30 17:35:23.334 [INFO ] [org.openhab.core.model.script.TEST ] - COMMAND 50
2020-12-30 17:35:23.337 [INFO ] [org.openhab.core.model.script.TEST ] - UPDATE 0
2020-12-30 17:35:23.339 [INFO ] [org.openhab.core.model.script.TEST ] - ==========END==============
Flip switch ON
2020-12-30 17:35:28.738 [INFO ] [org.openhab.core.model.script.TEST ] - ==========BEGIN============
2020-12-30 17:35:28.741 [INFO ] [org.openhab.core.model.script.TEST ] - COMMAND 50
2020-12-30 17:35:28.745 [INFO ] [org.openhab.core.model.script.TEST ] - UPDATE 50
2020-12-30 17:35:28.747 [INFO ] [org.openhab.core.model.script.TEST ] - ==========END==============
as you can see “receivedCommand” stays at 50 and is only reset to null if I reload the rule.
Is there any way to determine if the rule was triggered by an update or a command?
