OH3 dscAlarm binding error
Hello!
I’m working to migrate from v2.5.11 to 3.0.0. v2 has been running successfully for about a year.
The error I’m getting is:
Blockquote
2021-01-01 23:28:21.743 [WARN ] [ab.core.internal.events.EventHandler] - Creation of event failed, because one of the registered event factories has thrown an exception: Error invoking #valueOf(String) on class ‘org.openhab.core.library.types.DateTimeType’ with value ‘2-01-01T00:00:00.000-0700’.
java.lang.IllegalStateException: Error invoking #valueOf(String) on class ‘org.openhab.core.library.types.DateTimeType’ with value ‘2-01-01T00:00:00.000-0700’.
at org.openhab.core.items.events.ItemEventFactory.parseSimpleClassName(ItemEventFactory.java:188) ~[bundleFile:?]
at org.openhab.core.items.events.ItemEventFactory.parseType(ItemEventFactory.java:156) ~[bundleFile:?]
at org.openhab.core.items.events.ItemEventFactory.getState(ItemEventFactory.java:134) ~[bundleFile:?]
at org.openhab.core.items.events.ItemEventFactory.createStateEvent(ItemEventFactory.java:114) ~[bundleFile:?]
at org.openhab.core.items.events.ItemEventFactory.createEventByType(ItemEventFactory.java:78) ~[bundleFile:?]
at org.openhab.core.events.AbstractEventFactory.createEvent(AbstractEventFactory.java:53) ~[bundleFile:?]
at org.openhab.core.internal.events.EventHandler.createEvent(EventHandler.java:131) [bundleFile:?]
at org.openhab.core.internal.events.EventHandler.handleEvent(EventHandler.java:106) [bundleFile:?]
at org.openhab.core.internal.events.EventHandler.handleEvent(EventHandler.java:84) [bundleFile:?]
at org.openhab.core.internal.events.ThreadedEventHandler.lambda$0(ThreadedEventHandler.java:67) [bundleFile:?]
After a little digging, I think this was caused by removing the deprecated code in org.openhab.core/src/main/java/org/openhab/core/library/types/DateTimeType.java on June 13, 2020.
The issue appears to start in the binding org.openhab.binding.dscalarm/src/main/java/org/openhab/binding/dscalarm/internal/handler/PanelThingHandler.java at line 95
updateState(channelUID, new DateTimeType(systemTime));
Since the variable systemTime seems to contain ‘2-01-01T00:00:00.000-0700’ (a wayyy old bogus date), I’m guessing that it would work to change the binding code to DateTimeType() and allowed to take the new ‘now’ default:
public DateTimeType() {
this(ZonedDateTime.now());
I’m not setup to compile my own bindings (haven’t tried setting up a development environment) to test the fix, but I think everyone currently using the dscAlarm binding may be vulnerable to this error.?.?
Thank you for the help!
Gary
Blockquote
Static hostname: temp
Icon name: computer
Machine ID:
Boot ID:
Operating System: Raspbian GNU/Linux 10 (buster)
Kernel: Linux 5.4.79-v7+
Architecture: arm
Any chance this item made it onto the team’s to-be-fixed list?
I filed a bug here and referenced your post, I’m also having the same warning messages:
Doing an upgrade tonight and checking back to see if this made the fixed list.
Any updates?
Cross post this here too. This JAR (4.3.0) has added debug lines so it would be simpelr to reprodeuce and fix this issues:
