i’m trying to migrate my openHAB v2.5 into v3 and having problems to get my old configuration work on new behavior.
I’m editing my configurations (. items, .things, .sitemap) via Visual Source Code and load it up to my Raspberry Pi 4B via WinSCP.
With OH2.5 no problem.
I downloaded the actual image for OH3 and started a complete new installation.
After uploading my config i’m in a endless loop:
2020-12-26 20:09:41.899 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to ‘Europe/Berlin’.
2020-12-26 20:09:41.962 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to ‘48.96182459785863,8.914723992347719’.
2020-12-26 20:09:41.967 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to ‘de_DE’.
2020-12-26 20:09:56.685 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘Alex23.items’
2020-12-26 20:10:01.833 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘Alex23.sitemap’
2020-12-26 20:10:03.304 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘Alex23.things’
2020-12-26 20:10:08.698 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2020-12-26 20:10:16.435 [INFO ] [org.openhab.ui.internal.UIService ] - Started UI on port 8080
2020-12-26 20:10:17.564 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2020-12-26 20:10:23.763 [ERROR] [d4j.internal.RRD4jPersistenceService] - Could not create rrd4j database file ‘/var/lib/openhab/persistence/rrd4j/Licht_EG_Flur_Abwesend.rrd’: Invalid file header. File [/var/lib/openhab/persistence/rrd4j/Licht_EG_Flur_Abwesend.rrd] is not a RRD4J RRD file
2020-12-26 20:10:23.792 [ERROR] [d4j.internal.RRD4jPersistenceService] - Could not create rrd4j database file ‘/var/lib/openhab/persistence/rrd4j/Druckaufbau_An.rrd’: Invalid file header. File [/var/lib/openhab/persistence/rrd4j/Druckaufbau_An.rrd] is not a RRD4J RRD file
2020-12-26 20:10:23.804 [ERROR] [d4j.internal.RRD4jPersistenceService] - Could not create rrd4j database file ‘/var/lib/openhab/persistence/rrd4j/Aktion_Oskar_wach.rrd’: Invalid file header. File [/var/lib/openhab/persistence/rrd4j/Aktion_Oskar_wach.rrd] is not a RRD4J RRD file
2020-12-26 20:10:48.955 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to ‘Europe/Berlin’.
2020-12-26 20:10:49.016 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to ‘48.96182459785863,8.914723992347719’.
2020-12-26 20:10:49.021 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to ‘de_DE’.
2020-12-26 20:11:03.541 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘Alex23.items’
2020-12-26 20:11:08.634 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘Alex23.sitemap’
2020-12-26 20:11:10.096 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘Alex23.things’
2020-12-26 20:11:15.464 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2020-12-26 20:11:23.043 [INFO ] [org.openhab.ui.internal.UIService ] - Started UI on port 8080
2020-12-26 20:11:24.472 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
I’ve tried a lot by removing my rules, shortening my items files but nothing happens.
If i don’t find a solution, i’ll go back to OH2.
Thanks a lot for your help.
Chris
