RPi 4
openjdk version “11.0.10” 2021-01-19 LTS
OpenJDK Runtime Environment Zulu11.45+27-CA (build 11.0.10+9-LTS)
OpenJDK Client VM Zulu11.45+27-CA (build 11.0.10+9-LTS, mixed mode)
Decided to build a Staging system so I could test without disturbing the Production system
Clean install using 3.1.0-M2
System initially came up fine so I configured a minimal Model. Then when I started installing Bindings I got errors.
[ERROR] [.core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-monopriceaudio, openhab-persistence-mapdb, openhab-persistence-rrd4j, openhab-ui-basic, openhab-binding-astro, openhab-ui-habpanel, openhab-binding-zwave': Error:
Error downloading mvn:org.openhab.ui.bundles/org.openhab.ui.iconset.classic/3.0.0
I see others have had similar problems in OH2, so I tried numerous restarts and cleaned cache with no effect.
Tried reverting to 3.0.0 but also no effect.
Any ideas on where to look next?
