Hello everyone,
ever since I migrated to OH3 (now on OH3.1M2), I am no longer able to retrieve historical data from influxdb (1.8). OH3 does, however, persist all the data into the database.
My Testquery is just a simple query in a rule for testing:
item.historicState(now.minusMinutes(10),"influxdb")
With the binding in DEBUG, I only get:
19:19:18.280 [DEBUG] [e.influxdb.InfluxDBPersistenceService] - Got a query for historic points!
19:19:18.284 [ERROR] [.internal.handler.ScriptActionHandler] - Script execution of rule with UID 'influxtest-1' failed: error parsing query: found 1m, expected identifier at line 1, char 19 in influxtest
Nothing more. Line 1 char 19 does not exist in the rule.
I should mention that my default retention policy is called “1m_for_24h”, which is also defined as such in influxdb.cfg. So that is where that “1m” might be coming from. Could it be a missing escape for the underscores somewhere? The rule/binding worked flawlessly in OH2.x.
I was expecting that setting the binding to DEBUG would give me the actual query that OH3 sends to the database, but that does not seem to be the case…
Any ideas?
