So this is more of an casual observation, of a potential change in behavior in OH3 with the Exec Binding (For clarity, I am not necessarily calling it an issue/bug).
I have multiple items defined which executed a C++ & python programs to read multiple values from various device via a number of serial port.
This worked pretty well under OH 1.x and OH 2.x, and read errors were extremely infrequent (almost non-existent), and never saw the port-locked/already open issue.
Following the migration to OH 3.x, I was forever getting errors thrown by the underlying program that the serial (tty) device was locked/already open. This error itself was not surprising, as the Exec binding was now trying to fire up multiple instances of the utility, for different items, as the exact same time.
An initial work-around was to carefully choose item refresh intervals which were not a product of each other. This significantly reduced the occurrence of the errors, but obviously there would be points where the item updates would still overlap.
The real question here, is if there was a change in behavior for the Exec binding in OH 3.x which could have contributed to this. The only 2 hypothesis I can envision are that the previous OH Exec bindings versions were “single-threaded” in that I never really saw this overlap occur, or that OH3 is very very precise, and all the item updates kick-off at the same exact millisecond, when the refresh interval comes due…
I have addressed my own immediate problem, by now creating new programs that run as a Linux Daemons, and update OpenHAB items via MQTT, but perhaps some others have been running into a similar behavior with the OH3 exec binding.
I thought an understanding of whether this is ‘by design’, or possible work-around(s) that may help them avoid going down the same route (writing external services) that I did to get items reliably updating in OH.
FYI - One of the above (MQTT) programs is for a Schneider Zelio Smart Relay (Via “SLOUT”), written in Python. I’ll eventually tidy it up, and share it on here, but happy to share the quick ‘n’ dirty version I created, if someone wants to get their hands on it sooner rather than later.
Cheers
