OH3 fresh install on Debian 11 and MQTT Dimmer publishing 0.0 to 0.10 not 0/100
just done a fresh install of OH3 and went to add my first thing and item and noticed while testing that if i use the slider and pick a number from 1 to 100 say 85 it publishes 0.85 not 85. i tried setting the min and max to 100 and it has not made any difference. i never had this issue with OH2. Have i missed something in the OH3 setup ?
‘percentage value’ is this bindings mis-naming of a “dimmer” type channel. It was the same in OH2 and PaperUI. Fair enough I suppose, you might use it for fan speed control or whatever.
The UI has some odd restrictions, these can be worked around by going at it from the other end; linking an existing Item to a channel.
Note that there are no dimmer Things. You create an MQTT Thing, and may then create several channels of various types depending from it.
its strange if i make a channel and use percent it gets label as dimmer in the code but when i try link item it will only let me link items like switches and the dimmer items are not in the listed.
i have managed to get it to work but i had to create a item withing the ui not one from my items file
i used from OH2. guess i will just have add everything in one by one
