I am trying to monitor the status of the DSL connection by using the WAN subdevice channel dslStatus. According to the documentation it is a switch. When I create a link, with the UI, to an existing switch item such an item remains NULL.
If, instead, I create a link to a String item, the status is updated to the value Up.
I am facing a communication error on the bridge and I have no clue why. The error says
“could not get device definitions from https://XXXXX.myfritz.net”
Openhab Log Viewer says: “… [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘tr064:subdeviceLan:1fe96d71d750c88e:LAN’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)”
Openhab 3.2.0 is running on a Raspberry Pi 3B+ which is using the guestnet of a Fritzbox 7590 v07.29. The guestnet is where all Smarthome Things are located. Needless to say that the setup for everything else is working fine. But because of the guestnet I have to use an external access with a dynamic IP in order to enter the Fritzbox in the main network. This is currently realized in this case through a myFritz IP because it does not throw a certificate error (thanks to a letsencrypt.org certificate).
External browser access to the fritzbox is working. As well I am successfully able to performe the tr64desc.xml test (https://XXXXXX.myfritz.net:#####/tr064/tr64desc.xml) with these credentials through a browser. So IP and credentials seem to work fine.
What I did try with the Binding/Bridge configuration so far was:
entering the myFritz given IP with the port used by myFritz. As well I tried without port.
trying as well the regular dynamic IP which I usually use. With and without port.
setting up the bridge by the given automatic/supported setup routine. As well I tried to define the Things manually/textually.
Nothing worked so far and at this point I really need and would appreciate some help. Does anyone have an idea what the reason could be? What am I doing wrong? And as a sidenote I have to admit that I do not have any programming skills nor deeper technical knowledge So you might have to be a little patient with me when things seem to be clear to you but I am just not getting it.
I know this is an old post and probably you have already found a solution. In my transition to OH 3.4 I encountered this very same error and it turned out to be an error in the ip address of the fritzbox (some strange character in the string? I do not know). I deleted all the characters in the ip address field and re-entered it from scratch. It then worked.
This error is not only in the documentation, but also in the channel definition. I am installing from scratch in OH 3.4, using only the UI, but through the user UI I cannot link the channel to a string item (I am only offered a choice of available switch items). I still have to import from textual definitions.
