I copied a DSL-Rule from my OH2-Setup to OH3-M5.
When I start OH3-M5 I get the following Error-Message in the Log:
2020-12-06 22:27:45.745 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'astro-1' failed: a != java.lang.String in astro
But after that the Rule triggers normal, as I can see in the Log:
2020-12-06 22:27:50.531 [INFO ] [hab.core.model.script.astro-rules_99] - Moondistance updated every 5 Minutes by "astro.things " 2020-12-06T22:27:50.285+0100 / 1 Log every 2 hours
The Rule is:
var Number count=1
var Number mooncount=0
rule "moondistances"
// Item Dummy4x changed to ON or
Item Date_distance changed // Item defined in astro.items and changed every five minutes(300 sec.) by astro.things
Date_Kilometer_actual.postUpdate(Date_distance.state.format("%1$ta, %1$td.%1$tb. ") + " / " + Kilometer_distance.state.format("%,.0f km").toString)
Date_Kilometer_perigee.postUpdate(Date_perigee.state.format("%1$ta, %1$td.%1$tb. ") + " / " + Kilometer_perigee.state.format("%,.0f km").toString)
Date_Kilometer_apogee.postUpdate(Date_apogee.state.format("%1$ta, %1$td.%1$tb. ") + " / " + Kilometer_apogee.state.format("%,.0f km").toString)
mooncount = mooncount + 1
if (mooncount == 1 ) { //Log every 2 hours - just to inform that rule is still alive
logInfo("astro-rules" + '_99'," Moondistance updated every 5 Minutes by \"astro.things \" " + Date_distance.state + " / " + mooncount + " Log every 2 hours")
if (mooncount >= 24) { //refresh counter
mooncount = 0
and the OH3-Code looks:
triggers:
- id: "0"
configuration:
itemName: Date_distance
conditions: []
actions:
- inputs: {}
configuration:
type: application/vnd.openhab.dsl.rule
script: >
// context: astro-1
mooncount = 0
type: script.ScriptAction
I think that the Declaration and Initialization of the global variables is the problem. But I don’t know how to solve.
