Hello my “Items Group Equipment from Files” does not load at startup, to load them I have to remove them, save the file via vscode and then replace them and save the file, then via “the frondtail” it tells me File loaded , strange isn’t it? and I have this with each “Group Equipment files”, and eatch reboot, what’s going on?
Thanks for your help :
here an example of these Group :
Group Eq_Aquara1 "Eq_Agara1 " <temp> (Salon) ["Equipment"]
Number Aqara1_Humidity "Aqara1 Humidity[%.0f %%]" <hum> (Eq_Aquara1) ["Measurement", "Humidity"] {channel="deconz:humiditysensor:00212E051EC1:00158d00044a22f1010405:humidity"}
Number:Temperature Aqara1_Temperature "Aqara1 temperature [%.1f %unit%]" <temperature> (Eq_Aquara1) ["Measurement", "Temperature"] {channel="deconz:temperaturesensor:00212E051EC1:00158d00044a22f1010402:temperature", listWidget="widget:temperature_list" [title="Aqara1 temp"]}
Number:Pressure Aqara1_Pressure "Aqara1 Pressure[%.1f %unit%]" <pressure> (Eq_Aquara1) ["Measurement", "Pressure"] {channel="deconz:pressuresensor:00212E051EC1:00158d00044a22f1010403:pressure"}
DateTime Aqara1_LastUpdated "Aqara1 Last updated[le %1$td du %1$tm à %1$tHh%1$tM]"<calendar>(Eq_Aquara1) ["Point","Timestamp"] {channel="deconz:temperaturesensor:00212E051EC1:00158d00044a22f1010402:last_updated"}
To load the equipment I have to delete the referance to (Salon), then save, then “crtl + z” and re-record
