OH3: How to convert text file based elements?
I just migrated from OH2.5 to OH3 (RC2) using openhabian and I was surprised that more or less everything was taken over during the migration. But now I’m a little bit lost - and I didn’t find an answer during my research (or I read over it).
I can see e.g. all my text-based item, but they have a lock which seems to mean: Those are text-file based, you can’t change them in the GUI
So: What’s the correct way to migrate these items away from textual definition into the database? Is there a easy way or do I have to double all the items and create them new from the scratch?
Thanks,
Boby
I assume, I have to have a look at the dev tools :wink:
But to avoid double names, I have to delete the item definition in the textual files, right?
Oh man, that was too easy. Sorry for being blind :man_facepalming:
For the records: Commenting them out is sufficient
Hi Im looking to do the same thing but the image in the solution no longer displays! Also looking to move all my text rules across to the ui - so help on how to do this as well gratefully appreciated!
