LukaNoah
(Heiko Hegewald)
December 29, 2020, 6:51pm
#1
Hi there,
I’m just slowly preparing for the update to OH3.
In this context, I am currently creating a widget for AVM thermostats. I’m already relatively far for my standards (see screenshot). But now I have no idea how I can implement a kind of shortlist. The thermostat has 2 modes, device and controller, each of which can and should assume different values.
Device can be AUTOMATIC, MANUAL, ON, OFF. The controller can be ECO, COMFORT, BOOST, ON, OFF. I would like to be able to select the mode from a kind of drop-down and assign it to the corresponding item. The current value should be displayed and this should be changeable. How do I do that??
The green AUTOMATIC and COMFORT on the screenshot are only for visualization at first. They should disappear later and make space for 2 additional items.
nepotu
(Geo Magadan)
December 30, 2020, 3:02pm
#2
Not sure this is what you’re expecting, but here is how I did something similar.
You need to edit the item Metadata and in the State Description in the Options textbox you should put what you want to see in the list. Example:
AUTO=Auto
OFF=Off
ON=On
On your widget the item that controls the operating modes should be like:
- component: oh-link
text: =items[props.itemMode].displayState || items[props.itemMode].state
action: options
actionItem: =[props.itemMode]
itemMode
should be replaced with the name of the variable you are using.
LukaNoah
(Heiko Hegewald)
December 30, 2020, 6:38pm
#3
Hi Geo,
many thanks. Point 2 achieved the desired result. openHAB offers the options known to the item in the selection list. Point 1 therefore did not have to be implemented.
If I have further refined the widget, I can gladly make it available.
Thank you again and stay healthy. I wish you a happy new year.
marc1310
(marc schlüter)
February 27, 2021, 9:21am
#4
can someone post a example of the item?
i dont understand how the item looks like with the options ?
PatHab
(Patrick)
April 20, 2021, 1:36pm
#5
Hi Heiko,
any Updates on your widget?
I upgraded to OH3 recently and was looking for any great widgets i could use.
Since I also use AVM thermostats, your widget would be just right for me.
Your version from last year looks promising in the picture. Even in case it is not 100% completed yet, it would be great if you could make your current version available.
Thank you very much.
LukaNoah
(Heiko Hegewald)
April 24, 2021, 5:37pm
#6
Hi Patrick,
this is my actual widget code:
uid: AVM_Thermostat
tags:
- Thermostat
- Temperatur
- SetPoint
props:
parameters:
- description: <b>Optional prefix</b> for item names.
label: Item prefix
required: false
type: TEXT
- description: <b>Optional</b> URL to background-image.
label: Hintergrundbild-URL
required: false
type: TEXT
- context: item
description: Aussentemperatur
label: Aussentemperatur
required: false
type: TEXT
- context: item
description: Fensterzustand
label: Fensterzustand
required: false
type: TEXT
- context: item
description: Raumtemperatur
label: Raumtemperatur
required: false
type: TEXT
- context: item
description: Solltemperatur
label: Solltemperatur
required: false
type: TEXT
- context: item
description: Batterie
label: Batterie
required: false
type: TEXT
- context: item
description: Geraet
label: Geraet
required: false
type: TEXT
- context: item
description: Regler
label: Regler
required: false
type: TEXT
- context: item
description: Naechster Sollwert
label: Naechster Sollwert
required: false
type: TEXT
- context: item
description: Naechste Temperatur
label: Naechster Temperatur
required: false
type: TEXT
parameterGroups: []
timestamp: Apr 16, 2021, 7:54:22 PM
component: f7-card
class:
- padding
style:
background-image: ='url(' + props.backgroundUrl + ')'
background-size: cover
background-repeat: no-repeat
background-position: 100% 100%
border-radius: 5px
overflow: hidden
-ms-user-select: none
-moz-user-select: none
-webkit-user-select: none
user-select: none
--card-color: 255,255,255
--card-text-color: rgba(var(--card-color),1)
slots:
default:
- component: f7-row
class:
- margin
slots:
default:
- component: f7-col
visible: "(props.itemWindow === undefined) ? false : true"
style:
text-align: center
slots:
default:
- component: f7-icon
f7: rectangle_badge_checkmark
color: '=(items[props.itemWindow].state === "OPEN") ? "pink" : "green"'
- component: Label
text: '=(items[props.itemWindow].state === "OPEN") ? "Fenster offen" : "Ok" '
style:
white-space: nowrap
overflow: hidden
text-overflow: elipsis
font-size: 18px
- component: f7-col
visible: "=(props.itemBattery === undefined) ? false : true"
style:
text-align: center
slots:
default:
f7: battery_100
color: green
- component: Label
text: =items[props.itemBattery].displayState
style:
white-space: nowrap
overflow: hidden
font-size: 18px
- component: f7-col
visible: "=(props.itemOutdoorTemp === undefined) ? false : true"
style:
text-align: center
slots:
default:
f7: tree
color: green
- component: Label
text: =items[props.itemOutdoorTemp].displayState
style:
white-space: nowrap
overflow: hidden
font-size: 22px
- component: f7-row
class:
- justify-content-center
slots:
default:
- component: oh-knob
min: 14
max: 30
stepSize: 0.5
item: =props.itemTargetTemp
primaryColor: green
strokeWidth: "15"
- component: f7-col
class:
style:
text-align: center
margin-top: auto
margin-bottom: auto
width: 30%
slots:
default:
f7: house
color: green
- component: Label
text: =items[props.itemAmbientTemp].displayState
style:
white-space: nowrap
overflow: hidden
font-size: 32px
min-height: 2em
- component: Label
text: =items[props.itemGeraet].state
style:
text-align: center
margin-top: auto
margin-bottom: auto
min-height: 2em
color: '=(items[props.itemGeraet].state === "AUTOMATIC") ? "green" : "pink"'
- component: Label
text: =items[props.itemRegler].state
class:
style:
text-align: center
margin-top: auto
margin-bottom: auto
min-height: 2em
color: '=(items[props.itemRegler].state === "ECO") ? "blue" : "green"'
- component: f7-row
class:
- margin
slots:
default:
- component: f7-col
style:
text-align: center
slots:
default:
f7: power
- component: Label
text: Power
style:
white-space: nowrap
overflow: hidden
color: green
text: =items[props.itemRegler].displayState || items[props.itemRegler].state
action: options
actionItem: =[props.itemRegler]
- component: f7-col
style:
text-align: center
slots:
default:
f7: minus_rectangle
- component: Label
text: Modus
style:
white-space: nowrap
overflow: hidden
color: green
text: =items[props.itemGeraet].displayState || items[props.itemGeraet].state
action: options
actionItem: =[props.itemGeraet]
- component: f7-col
style:
text-align: center
slots:
default:
f7: clock
- component: Label
text: n. Änderung
style:
white-space: nowrap
overflow: hidden
color: green
- component: Label
text: =items[props.itemNextSoll].displayState || items[props.itemNextSoll].state
style:
white-space: nowrap
overflow: hidden
- component: f7-col
style:
text-align: center
slots:
default:
f7: thermometer
- component: Label
text: n. Sollwert
style:
white-space: nowrap
overflow: hidden
color: green
- component: Label
text: =items[props.itemNextTemp].displayState || items[props.itemNextTemp].state
style:
white-space: nowrap
overflow: hidden
