I see… Hopefully it will be fixed soon then.
I’ll try the normal item with linked channels approach, that will probably work.
As for the light’s they are GU10 bulbs RGBW with tasmota on. so need CT, H, S & B. B works on both modes, if you select CT, H & S mute, if you set H, then CT mutes. They work well. They are in a 3 bulb ceiling fitting. 90% they will be in CT mode (warm white) for normal use, all bulbs in sync. but sometimes they will be in color mode and some bulbs may be different colors.
Thanks for the help. I little more was learned
