openHAB 3.2.0 - Release Build
Platform = Raspberry Pi 3 Model B Rev 1.2
Release = Raspbian GNU/Linux 11 (bullseye)
Kernel = Linux 5.15.30-v7+
Memory = Free: 0.24GB (25%), Used: 0.70GB (75%), Total: 0.95GB
Swap = Free: 2.29GB (100%), Used: 0.00GB (0%), Total: 2.29GB
Root = Free: 9.26GB (67%), Used: 4.43GB (33%), Total: 14.32GB
I have several HomeSeer HS-MS100+ motion sensors that were working on 2.5 but are no longer working on OpenHAB 3.2. They did configure and the Items are able to be setup, or re-setup. But when they are triggered nothing seems to happen.
These are the older models from several years ago. I think HomeSeer has released a new version in the last couple of years.
- zwave_class_basic = BASIC_TYPE_ROUTING_SLAVE
- zwave_class_generic = GENERIC_TYPE_SENSOR_NOTIFICATION
- zwave_frequent = false
- zwave_lastwakeup = 2022-04-16T18:51:41Z
- modelId = HS-MS100+
- zwave_listening = false
- zwave_plus_devicetype = NODE_TYPE_ZWAVEPLUS_NODE
- zwave_version = 1.1
- manufacturerId = 000C
- manufacturerRef = 0201:0009
- dbReference = 802
- zwave_deviceid = 9
- zwave_nodeid = 22
- defaultAssociations = 1
- vendor = HomeSeer Technologies
- zwave_routing = true
- zwave_plus_roletype = ROLE_TYPE_SLAVE_SLEEPING_REPORTING
- zwave_beaming = true
- zwave_secure = false
- zwave_class_specific = SPECIFIC_TYPE_NOTIFICATION_SENSOR
- zwave_devicetype = 513
- zwave_manufacturer = 12
Debug log when Motion is triggered shows the following, But I don’t know what it means.
2022-04-16 15:27:33.971 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 6: Application Command Request (ALIVE:DONE)
2022-04-16 15:27:33.973 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 6: resetResendCount initComplete=true isDead=false
2022-04-16 15:27:33.977 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 6: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2022-04-16 15:27:33.979 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 6: SECURITY not supported
2022-04-16 15:27:33.982 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 6: Received COMMAND_CLASS_ALARM V5 NOTIFICATION_REPORT
2022-04-16 15:27:33.985 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 6: NOTIFICATION report - 0 = 0, event=8, status=255, plen=0
2022-04-16 15:27:33.988 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 6: Alarm Type = BURGLAR (0)
2022-04-16 15:27:33.991 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2022-04-16 15:27:33.994 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2022-04-16 15:27:33.997 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 6: Commands processed 1.
2022-04-16 15:27:34.000 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 6: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@12181ec.
