Hello Forum,
I programmed a ESP01 with Arduino IDE (no Tamota, connected to my WLAN) to blink in a Lighthouse Sequence .
Now I want to turn the Sequence on and off whit a OH3 Http Binding Switch.
When I manually type 192.168.0.23/whvon in a Browser the Seqence starts and /whvoff it stops.
Hi Jan,
I tried to set the Loglevel to TRACE with this command in a Terminal:
sudo log:set TRACE org.openhab.binding.http
It said that the command was not found. Writing mistake?
From the “normal log” in Openhab I found this:
2021-04-05 08:21:21.389 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘LskTest_Whv’ received command OFF
2021-04-05 08:21:21.404 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘LskTest_Whv’ predicted to become OFF
2021-04-05 08:21:21.413 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘LskTest_Whv’ changed from ON to OFF
2021-04-05 08:22:09.405 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘LskTest_Whv’ received command ON
2021-04-05 08:22:09.410 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘LskTest_Whv’ predicted to become ON
2021-04-05 08:22:09.414 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘LskTest_Whv’ changed from OFF to ON
2021-04-05 08:23:00.621 [WARN ] [ttp.internal.http.RefreshingUrlCache] - Creating request for ‘192.168.0.23/’ failed: Invalid URI host: null (authority: null)
2021-04-05 08:23:08.700 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to ‘localhost’. Next attempt in 60000ms
2021-04-05 08:23:08.708 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to ‘localhost’ with clientid 4d603307-ef57-466b-8538-cb6ddbb35d1e
2021-04-05 08:24:30.629 [WARN ] [ttp.internal.http.RefreshingUrlCache] - Creating request for ‘192.168.0.23/’ failed: Invalid URI host: null (authority: null)
Hmmm…it seems that OH sends the On and Off, but not in /whvon and /whv off? Why does the System start a Mqtt Broker when I’m on http?
I try to switch to TRACE, but wanted to report this to you first.
partial solution with http://192.168.0.23
I can turn it on and off but after 14 sek off the Sequence starts running again whitout that I do anything. Seems that by changing from OFF to UNDEF it starts again.
2021-04-05 09:29:00.117 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘LskTest_Whv’ received command OFF
2021-04-05 09:29:00.123 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘LskTest_Whv’ predicted to become OFF
2021-04-05 09:29:00.130 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘LskTest_Whv’ changed from ON to OFF
2021-04-05 09:29:14.572 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘LskTest_Whv’ changed from OFF to UNDEF
