I have read various contributions to the error message COMMUNICATION_ERROR The UPnP speaker RINCON_xxxxxxxx is not registered “. I could not find a solution, however. An account has been set up with Sonos and the player Play: 1 is registered. I was able to access the UDN at” http: / / ip-your-players: 1400 / status ". Port 1900 is also released, restart attempted, but the thing with the above message is always offline.
I ask the users again: have there been any new findings in the meantime?
I previously had some reliability issues with my sonos and my dockerized OH. These, however, were the same as all the other upnp issues that have been recently fixed, not a problem with docker. As long as your container is set to network “host” there’s no issue communicating with the speakers. As for improving the reliability, see the follow post:
I have had no sonos connection drops since modifying the the settings as per that post.
Thank you for your answers. I set up the Openhab container using a Docker Compose file. The “network_mode: default” instruction has specified the “Bridge” mode. How is a change made? Can I now delete the container and set it up again with network_mode: Host? What else do I have to consider besides a backup? I have not yet made such corrections.
If you have followed the other setup directions then your data is either in a persistent docker volume or external folders on the device running docker. In that case, yes, you should be able to just create a new container with the new network mode and it will use the same image and find the same data volumes.
That said, a backup is never a bad idea when trying something new.
Yes I did. I use the following settings for a sonos system that has 5 play1’s and a play3.
The change of the network mode brings an error message “docker.errors.InvalidArgument:” host "network_mode is incompatible with port_bindings
-sh: docker.errors.InvalidArgument :: command not found ". What else needs to be changed?
I have now changed the docker-compose as above. This is probably a kind of minimal configuration. Maybe she still have suggestions for improvement. It works like this at the moment, the Sonos binding is now online! But I still have to configure the services / runtime.cfg file and then contact me again later.
