OH3: influx 2.0 errors
  • Platform information:
    • OS: Ubuntu 20.04
    • Java Runtime Environment: Zulu 11.0.9
    • openHAB version: 3.0.0.M1
    • influxDB version: InfluxDB 2.0.0-rc.0
I have issues with influxdb 2.0 and openHAB 3.0 when I turn off any zwave dimmer/switch…
Im try delete autogen bucket and recreate it but do not help.
Any idea how to fix issue?
Error:
2020-10-26 07:54:19.193 [ERROR] [.client.write.events.WriteErrorEvent] - The error occurred during writing of data
com.influxdb.exceptions.InternalServerErrorException: unexpected error writing points to database: partial write: field type conflict: input field “value” on measurement “ZWave_Floor1_Office_Dimmer_TableLight_Electricmeterwatts” is type integer, already exists as type float dropped=1
at com.influxdb.internal.AbstractRestClient.responseToError(AbstractRestClient.java:118) ~[bundleFile:?]
at com.influxdb.client.internal.AbstractWriteClient.toInfluxException(AbstractWriteClient.java:574) [bundleFile:?]
at com.influxdb.client.internal.AbstractWriteClient.lambda$new$12(AbstractWriteClient.java:181) [bundleFile:?]
at io.reactivex.internal.subscribers.LambdaSubscriber.onNext(LambdaSubscriber.java:65) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableDoFinally$DoFinallySubscriber.onNext(FlowableDoFinally.java:84) [bundleFile:?]
at io.reactivex.internal.operators.mixed.FlowableConcatMapMaybe$ConcatMapMaybeSubscriber.drain(FlowableConcatMapMaybe.java:284) [bundleFile:?]
at io.reactivex.internal.operators.mixed.FlowableConcatMapMaybe$ConcatMapMaybeSubscriber.onNext(FlowableConcatMapMaybe.java:137) [bundleFile:?]
at io.reactivex.internal.operators.mixed.FlowableConcatMapSingle$ConcatMapSingleSubscriber.drain(FlowableConcatMapSingle.java:279) [bundleFile:?]
at io.reactivex.internal.operators.mixed.FlowableConcatMapSingle$ConcatMapSingleSubscriber.innerSuccess(FlowableConcatMapSingle.java:179) [bundleFile:?]
at io.reactivex.internal.operators.mixed.FlowableConcatMapSingle$ConcatMapSingleSubscriber$ConcatMapSingleObserver.onSuccess(FlowableConcatMapSingle.java:317) [bundleFile:?]
at io.reactivex.internal.operators.single.SingleMap$MapSingleObserver.onSuccess(SingleMap.java:64) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableCollectSingle$CollectSubscriber.onComplete(FlowableCollectSingle.java:119) [bundleFile:?]
at io.reactivex.internal.subscribers.BasicFuseableSubscriber.onComplete(BasicFuseableSubscriber.java:120) [bundleFile:?]
at io.reactivex.internal.subscribers.BasicFuseableConditionalSubscriber.onComplete(BasicFuseableConditionalSubscriber.java:119) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableGroupBy$State.checkTerminated(FlowableGroupBy.java:686) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableGroupBy$State.drainNormal(FlowableGroupBy.java:626) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableGroupBy$State.drain(FlowableGroupBy.java:558) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableGroupBy$State.onComplete(FlowableGroupBy.java:548) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableGroupBy$GroupedUnicast.onComplete(FlowableGroupBy.java:474) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableGroupBy$GroupBySubscriber.onComplete(FlowableGroupBy.java:213) [bundleFile:?]
at io.reactivex.processors.UnicastProcessor.checkTerminated(UnicastProcessor.java:430) [bundleFile:?]
at io.reactivex.processors.UnicastProcessor.drainRegular(UnicastProcessor.java:314) [bundleFile:?]
at io.reactivex.processors.UnicastProcessor.drain(UnicastProcessor.java:397) [bundleFile:?]
at io.reactivex.processors.UnicastProcessor.onComplete(UnicastProcessor.java:487) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableWindowBoundarySupplier$WindowBoundaryMainSubscriber.drain(FlowableWindowBoundarySupplier.java:254) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableWindowBoundarySupplier$WindowBoundaryMainSubscriber.innerNext(FlowableWindowBoundarySupplier.java:166) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableWindowBoundarySupplier$WindowBoundaryInnerSubscriber.onNext(FlowableWindowBoundarySupplier.java:316) [bundleFile:?]
at io.reactivex.processors.PublishProcessor$PublishSubscription.onNext(PublishProcessor.java:360) [bundleFile:?]
at io.reactivex.processors.PublishProcessor.onNext(PublishProcessor.java:243) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableFlatMap$MergeSubscriber.tryEmit(FlowableFlatMap.java:282) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableFlatMap$InnerSubscriber.onNext(FlowableFlatMap.java:668) [bundleFile:?]
at io.reactivex.subscribers.SerializedSubscriber.onNext(SerializedSubscriber.java:100) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableWindowTimed$WindowExactBoundedSubscriber.drainLoop(FlowableWindowTimed.java:498) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableWindowTimed$WindowExactBoundedSubscriber$ConsumerIndexHolder.run(FlowableWindowTimed.java:579) [bundleFile:?]
at io.reactivex.Scheduler$Worker$PeriodicTask.run(Scheduler.java:479) [bundleFile:?]
at io.reactivex.internal.schedulers.ScheduledRunnable.run(ScheduledRunnable.java:66) [bundleFile:?]
at io.reactivex.internal.schedulers.ScheduledRunnable.call(ScheduledRunnable.java:57) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
Probably related to this.
EDIT: Also mentioned openHAB 3.0 Milestone 1 discussion
Thanks for that info.
Looks like Im fix issue with:
1.) Uninstalling influxdb persistence addon
2.) Copy SNAPSHOT jar file for influxdb persistence into “/usr/share/openhab/addons”
3.) Restart openhab (Looks like restart is needed to install jar addon from folder)
4.) Recreate autogen bucket
5.) Restart openhab
Strange thing is that search function on “forum” do not work and didn’t find anything when I search with influxdb keyword… Right now also fond only my thread…!
influxdb search|688x500
Guys today i found an new error in influx 2.0 that i could not interpret.
2020-11-02 21:23:22.643 [ERROR] [.client.write.events.WriteErrorEvent] - The error occurred during writing of data
com.influxdb.exceptions.NotFoundException: bucket "autogen" not found
Why does the binding try to access a bucket that i have not specified?
Im found same thing but is not big deal for me because use Fluxdb only for one openhab instance…
I solved the autogen bucket error. I checked the influx config profile and found that the correspondig entry “retentionProfile” /euqals bucket in influx 2.0) is missing. Based on this the default value “autogen” is used. Adding the entry saves immideately entries to the database.
I will open an issue on that, but i am not sure if this is an ui thing or a binding thing.
@ysc Please gibe me a hint
I have the same problem.
Tell us in more detail what exactly and where to register.
Here?
/var/lib/openhab/config/org/openhab/influxdb.config
What exactly do you need to write?
Thanks!
I have like this:
:org.apache.felix.configadmin.revision:=L"3"
url="http://127.0.0.1:8086"
user="openhab"
password="YOUR_PASSWORD"
service.pid="org.openhab.influxdb"
token="YOUR_INFLUXDB_TOKEN_IF_YOU HAVE_IT"
version="V2"
db="openhab"
retentionPolicy="openhab"
Thank you, I did the same, there is no more error, I’ll see if the data will be recorded.
First I did as above, but it didn’t work.
I was the retentionPolicy not Profile. Sorry for that
