Here’s the log, hope it’s sufficient:
[15:53:02] root@openhab:~# openhabian-config
2021-02-18_15:53:07_CET [openHABian] Checking for root privileges... OK
+ export UNATTENDED SILENT DEBUGMAX INTERACTIVE
+ for shfile in "${BASEDIR:-/opt/openhabian}"/functions/*.bash
+ source /opt/openhabian/functions/auth.bash
+ source /opt/openhabian/functions/backup.bash
+ source /opt/openhabian/functions/config.bash
+ source /opt/openhabian/functions/ext-storage.bash
+ source /opt/openhabian/functions/find.bash
+ source /opt/openhabian/functions/habapp.bash
+ source /opt/openhabian/functions/helpers.bash
++ ESC='\033['
++ COL_DEF='\033[39;49;00m'
++ COL_RED='\033[31;01m'
++ COL_GREEN='\033[32;01m'
++ COL_YELLOW='\033[33;01m'
++ COL_BLUE='\033[34;01m'
++ COL_MAGENTA='\033[35;01m'
++ COL_CYAN='\033[36;01m'
++ COL_LGRAY='\033[37;01m'
++ COL_DGRAY='\033[90;01m'
++ export COL_DEF COL_RED COL_GREEN COL_YELLOW COL_BLUE COL_MAGENTA COL_CYAN COL_LGRAY COL_DGRAY
+ source /opt/openhabian/functions/influxdb+grafana.bash
+ source /opt/openhabian/functions/java-jre.bash
+ source /opt/openhabian/functions/menu.bash
+ source /opt/openhabian/functions/nodejs-apps.bash
+ source /opt/openhabian/functions/openhab.bash
+ source /opt/openhabian/functions/openhabian.bash
+ source /opt/openhabian/functions/packages.bash
+ source /opt/openhabian/functions/system.bash
+ source /opt/openhabian/functions/vpn.bash
+ source /opt/openhabian/functions/wifi.bash
+ source /opt/openhabian/functions/zram.bash
++ pwd
+ OLDWD=/root
+ cd /opt
+ update_openhabian_conf
+ local configFile=/etc/openhabian.conf
+ local referenceConfig=/opt/openhabian/openhabian.conf.dist
+ cp /etc/openhabian.conf /etc/openhabian.conf.BAK
+ read -r line
+ [[ # Modify your openHABian settings =~ ^(#)?[a-zA-Z] ]]
+ echo '# Modify your openHABian settings'
+ read -r line
+ [[ # Handle with care, only touch if you need to!! =~ ^(#)?[a-zA-Z] ]]
+ echo '# Handle with care, only touch if you need to!!'
+ read -r line
+ [[ # This file will only be used on unattended initial install. =~ ^(#)?[a-zA-Z] ]]
+ echo '# This file will only be used on unattended initial install.'
+ read -r line
+ [[ # If you want to change anything after unattended install completed, use menu in openhabian-config. =~ ^(#)?[a-zA-Z] ]]
+ echo '# If you want to change anything after unattended install completed, use menu in openhabian-config.'
+ read -r line
+ [[ '' =~ ^(#)?[a-zA-Z] ]]
+ echo ''
+ read -r line
+ [[ # Hostname to set this one to =~ ^(#)?[a-zA-Z] ]]
+ echo '# Hostname to set this one to'
+ read -r line
+ [[ hostname=openhabian =~ ^(#)?[a-zA-Z] ]]
+ parsed=hostname=openhabian
+ [[ hostname=openhabian =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo hostname=openhabian
+ param=hostname
+ [[ -v hostname ]]
+ [[ openhabian == *\ * ]]
+ read -r line
+ [[ # if it exists, the default user (with its working environment) will be renamed to this username given here ... =~ ^(#)?[a-zA-Z] ]]
+ echo '# if it exists, the default user (with its working environment) will be renamed to this username given here ...'
+ read -r line
+ [[ username=openhabian =~ ^(#)?[a-zA-Z] ]]
+ parsed=username=openhabian
+ [[ username=openhabian =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo username=openhabian
+ param=username
+ [[ -v username ]]
+ read -r line
+ [[ # and given this password. The password will be removed from this file after completion for security reasons. =~ ^(#)?[a-zA-Z] ]]
+ echo '# and given this password. The password will be removed from this file after completion for security reasons.'
+ read -r line
+ [[ userpw=openhabian =~ ^(#)?[a-zA-Z] ]]
+ parsed=userpw=openhabian
+ [[ userpw=openhabian =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo userpw=openhabian
+ param=userpw
+ [[ -v userpw ]]
+ read -r line
+ [[ # set this to download a SSH key and authorize the owner to login as the admin user =~ ^(#)?[a-zA-Z] ]]
+ echo '# set this to download a SSH key and authorize the owner to login as the admin user'
+ read -r line
+ [[ #adminkeyurl=https://github.com/openhab/openhabian/adminkey.pub =~ ^(#)?[a-zA-Z] ]]
+ parsed='#adminkeyurl=https://github.com/openhab/openhabian/adminkey.pub'
+ [[ #adminkeyurl=https://github.com/openhab/openhabian/adminkey.pub =~ ^#[a-zA-Z] ]]
+ parsed=adminkeyurl=https://github.com/openhab/openhabian/adminkey.pub
++ cut -d= -f1
++ echo adminkeyurl=https://github.com/openhab/openhabian/adminkey.pub
+ param=adminkeyurl
+ [[ -v adminkeyurl ]]
+ echo '#adminkeyurl=https://github.com/openhab/openhabian/adminkey.pub'
+ eval adminkeyurl=https://github.com/openhab/openhabian/adminkey.pub
++ adminkeyurl=https://github.com/openhab/openhabian/adminkey.pub
+ read -r line
+ echo ''
+ read -r line
+ [[ # Language and timezone. See Debian documentation for valid values. =~ ^(#)?[a-zA-Z] ]]
+ echo '# Language and timezone. See Debian documentation for valid values.'
+ read -r line
+ [[ timezone=Europe/Berlin =~ ^(#)?[a-zA-Z] ]]
+ parsed=timezone=Europe/Berlin
+ [[ timezone=Europe/Berlin =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo timezone=Europe/Berlin
+ param=timezone
+ [[ -v timezone ]]
+ [[ Europe/Berlin == *\ * ]]
+ read -r line
+ [[ locales="en_US.UTF-8 de_DE.UTF-8" =~ ^(#)?[a-zA-Z] ]]
+ parsed='locales="en_US.UTF-8 de_DE.UTF-8"'
+ [[ locales="en_US.UTF-8 de_DE.UTF-8" =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo 'locales="en_US.UTF-8 de_DE.UTF-8"'
+ param=locales
+ [[ -v locales ]]
+ [[ en_US.UTF-8 de_DE.UTF-8 == *\ * ]]
+ read -r line
+ [[ system_default_locale="en_US.UTF-8" =~ ^(#)?[a-zA-Z] ]]
+ parsed='system_default_locale="en_US.UTF-8"'
+ [[ system_default_locale="en_US.UTF-8" =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo 'system_default_locale="en_US.UTF-8"'
+ param=system_default_locale
+ [[ -v system_default_locale ]]
+ [[ en_US.UTF-8 == *\ * ]]
+ echo system_default_locale=en_US.UTF-8
+ read -r line
+ echo ''
+ read -r line
+ [[ # WiFi settings. An ethernet connection is recommended. =~ ^(#)?[a-zA-Z] ]]
+ echo '# WiFi settings. An ethernet connection is recommended.'
+ read -r line
+ [[ # If you have a RPi4, RPi3, RPi0W or a supported external WiFi dongle, the WiFi =~ ^(#)?[a-zA-Z] ]]
+ echo '# If you have a RPi4, RPi3, RPi0W or a supported external WiFi dongle, the WiFi'
+ read -r line
+ [[ # interface can be setup and used for the initial installation. =~ ^(#)?[a-zA-Z] ]]
+ echo '# interface can be setup and used for the initial installation.'
+ read -r line
+ [[ # Fill in your SSID and password below, leave empty or put comment in front to =~ ^(#)?[a-zA-Z] ]]
+ echo '# Fill in your SSID and password below, leave empty or put comment in front to'
+ read -r line
+ [[ # have your WiFi remain unchanged/uninitialized. Make sure your Ethernet works. =~ ^(#)?[a-zA-Z] ]]
+ echo '# have your WiFi remain unchanged/uninitialized. Make sure your Ethernet works.'
+ read -r line
+ [[ # ATTENTION: you need to escape these special characters: $, `, ", \, (newline) =~ ^(#)?[a-zA-Z] ]]
+ echo '# ATTENTION: you need to escape these special characters: $, `, ", \, (newline)'
+ read -r line
+ [[ # 'Escaping' means to put an additional \ in front of that character =~ ^(#)?[a-zA-Z] ]]
+ echo '# '\''Escaping'\'' means to put an additional \ in front of that character'
+ read -r line
+ [[ wifi_ssid="" =~ ^(#)?[a-zA-Z] ]]
+ parsed='wifi_ssid=""'
+ [[ wifi_ssid="" =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo 'wifi_ssid=""'
+ param=wifi_ssid
+ [[ -v wifi_ssid ]]
+ echo wifi_ssid=
+ read -r line
+ [[ wifi_psk="" =~ ^(#)?[a-zA-Z] ]]
+ parsed='wifi_psk=""'
+ [[ wifi_psk="" =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo 'wifi_psk=""'
+ param=wifi_psk
+ [[ -v wifi_psk ]]
+ echo wifi_psk=
+ read -r line
+ echo ''
+ read -r line
+ [[ # Wi-Fi setting. Select a two-letter country code suitable for your location =~ ^(#)?[a-zA-Z] ]]
+ echo '# Wi-Fi setting. Select a two-letter country code suitable for your location'
+ read -r line
+ [[ # E.g. US (default), DE, AU, NZ... =~ ^(#)?[a-zA-Z] ]]
+ echo '# E.g. US (default), DE, AU, NZ...'
+ read -r line
+ [[ # You may infringe on local legislature otherwise =~ ^(#)?[a-zA-Z] ]]
+ echo '# You may infringe on local legislature otherwise'
+ read -r line
+ [[ # See https://en.wikipedia.org/wiki/ISO_3166-1_alpha-2 or /usr/share/zoneinfo/zone.tab =~ ^(#)?[a-zA-Z] ]]
+ echo '# See https://en.wikipedia.org/wiki/ISO_3166-1_alpha-2 or /usr/share/zoneinfo/zone.tab'
+ read -r line
+ [[ wifi_country="" =~ ^(#)?[a-zA-Z] ]]
+ parsed='wifi_country=""'
+ [[ wifi_country="" =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo 'wifi_country=""'
+ param=wifi_country
+ [[ -v wifi_country ]]
+ echo wifi_country=
+ read -r line
+ echo ''
+ read -r line
+ [[ # Eventually disable all IPv6 e.g. on installation problems =~ ^(#)?[a-zA-Z] ]]
+ echo '# Eventually disable all IPv6 e.g. on installation problems'
+ read -r line
+ [[ # values: "enable", "disable" =~ ^(#)?[a-zA-Z] ]]
+ echo '# values: "enable", "disable"'
+ read -r line
+ [[ ipv6=enable =~ ^(#)?[a-zA-Z] ]]
+ parsed=ipv6=enable
+ [[ ipv6=enable =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo ipv6=enable
+ param=ipv6
+ [[ -v ipv6 ]]
+ [[ enable == *\ * ]]
+ echo ipv6=enable
+ read -r line
+ echo ''
+ read -r line
+ [[ # repo and branch to clone from =~ ^(#)?[a-zA-Z] ]]
+ echo '# repo and branch to clone from'
+ read -r line
+ [[ repositoryurl=https://github.com/openhab/openhabian.git =~ ^(#)?[a-zA-Z] ]]
+ parsed=repositoryurl=https://github.com/openhab/openhabian.git
+ [[ repositoryurl=https://github.com/openhab/openhabian.git =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo repositoryurl=https://github.com/openhab/openhabian.git
+ param=repositoryurl
+ [[ -v repositoryurl ]]
+ [[ https://github.com/openhab/openhabian.git == *\ * ]]
+ read -r line
+ [[ clonebranch=openHAB3 =~ ^(#)?[a-zA-Z] ]]
+ parsed=clonebranch=openHAB3
+ [[ clonebranch=openHAB3 =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo clonebranch=openHAB3
+ param=clonebranch
+ [[ -v clonebranch ]]
+ [[ openHAB3 == *\ * ]]
+ read -r line
+ echo ''
+ read -r line
+ [[ # debug verbosity mode =~ ^(#)?[a-zA-Z] ]]
+ echo '# debug verbosity mode'
+ read -r line
+ [[ # off, on (verbose output in log) or maximum (show every command) =~ ^(#)?[a-zA-Z] ]]
+ echo '# off, on (verbose output in log) or maximum (show every command)'
+ read -r line
+ [[ debugmode=off =~ ^(#)?[a-zA-Z] ]]
+ parsed=debugmode=off
+ [[ debugmode=off =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo debugmode=off
+ param=debugmode
+ [[ -v debugmode ]]
+ [[ maximum == *\ * ]]
+ echo debugmode=maximum
+ read -r line
+ echo ''
+ read -r line
+ [[ # fake hardware =~ ^(#)?[a-zA-Z] ]]
+ echo '# fake hardware'
+ read -r line
+ [[ # force treating your box as if it was a ... =~ ^(#)?[a-zA-Z] ]]
+ echo '# force treating your box as if it was a ...'
+ read -r line
+ [[ # pi4, pi4_8gb, cm4, pi400, pi3, cm3, pi3+, cm3+, pi2, pi1, cm1, pi0, pi0w =~ ^(#)?[a-zA-Z] ]]
+ echo '# pi4, pi4_8gb, cm4, pi400, pi3, cm3, pi3+, cm3+, pi2, pi1, cm1, pi0, pi0w'
+ read -r line
+ [[ #hw=pi4 =~ ^(#)?[a-zA-Z] ]]
+ parsed='#hw=pi4'
+ [[ #hw=pi4 =~ ^#[a-zA-Z] ]]
+ parsed=hw=pi4
++ cut -d= -f1
++ echo hw=pi4
+ param=hw
+ [[ -v hw ]]
+ echo '#hw=pi4'
+ eval hw=pi4
++ hw=pi4
+ read -r line
+ echo ''
+ read -r line
+ [[ # Hardware architecture =~ ^(#)?[a-zA-Z] ]]
+ echo '# Hardware architecture'
+ read -r line
+ [[ # x86_64, amd64, armv6l, armv7l, aarch64, arm64 =~ ^(#)?[a-zA-Z] ]]
+ echo '# x86_64, amd64, armv6l, armv7l, aarch64, arm64'
+ read -r line
+ [[ #hwarch=armv7l =~ ^(#)?[a-zA-Z] ]]
+ parsed='#hwarch=armv7l'
+ [[ #hwarch=armv7l =~ ^#[a-zA-Z] ]]
+ parsed=hwarch=armv7l
++ cut -d= -f1
++ echo hwarch=armv7l
+ param=hwarch
+ [[ -v hwarch ]]
+ [[ amd64 == *\ * ]]
+ echo hwarch=amd64
+ read -r line
+ echo ''
+ read -r line
+ [[ # OS distribution/release =~ ^(#)?[a-zA-Z] ]]
+ echo '# OS distribution/release'
+ read -r line
+ [[ # Valid arguments: raspios, raspbian, debian, ubuntu, stretch, buster, bionic, focal =~ ^(#)?[a-zA-Z] ]]
+ echo '# Valid arguments: raspios, raspbian, debian, ubuntu, stretch, buster, bionic, focal'
+ read -r line
+ [[ #osrelease=buster =~ ^(#)?[a-zA-Z] ]]
+ parsed='#osrelease=buster'
+ [[ #osrelease=buster =~ ^#[a-zA-Z] ]]
+ parsed=osrelease=buster
++ cut -d= -f1
++ echo osrelease=buster
+ param=osrelease
+ [[ -v osrelease ]]
+ echo '#osrelease=buster'
+ eval osrelease=buster
++ osrelease=buster
+ read -r line
+ echo ''
+ read -r line
+ [[ # Java architecture mode =~ ^(#)?[a-zA-Z] ]]
+ echo '# Java architecture mode'
+ read -r line
+ [[ # Valid arguments: "Adopt11", "Zulu8-32", "Zulu8-64", "Zulu11-32", or "Zulu11-64" =~ ^(#)?[a-zA-Z] ]]
+ echo '# Valid arguments: "Adopt11", "Zulu8-32", "Zulu8-64", "Zulu11-32", or "Zulu11-64"'
+ read -r line
+ [[ java_opt=Zulu11-32 =~ ^(#)?[a-zA-Z] ]]
+ parsed=java_opt=Zulu11-32
+ [[ java_opt=Zulu11-32 =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo java_opt=Zulu11-32
+ param=java_opt
+ [[ -v java_opt ]]
+ [[ Zulu11-64 == *\ * ]]
+ echo java_opt=Zulu11-64
+ read -r line
+ echo ''
+ read -r line
+ [[ # openHAB Log Viewer (frontail) theme =~ ^(#)?[a-zA-Z] ]]
+ echo '# openHAB Log Viewer (frontail) theme'
+ read -r line
+ [[ # Valid arguments: "light", "dark" =~ ^(#)?[a-zA-Z] ]]
+ echo '# Valid arguments: "light", "dark"'
+ read -r line
+ [[ frontailtheme=light =~ ^(#)?[a-zA-Z] ]]
+ parsed=frontailtheme=light
+ [[ frontailtheme=light =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo frontailtheme=light
+ param=frontailtheme
+ [[ -v frontailtheme ]]
+ [[ light == *\ * ]]
+ read -r line
+ echo ''
+ read -r line
+ [[ # install ZRAM per default, set to "disable" to skip installation =~ ^(#)?[a-zA-Z] ]]
+ echo '# install ZRAM per default, set to "disable" to skip installation'
+ read -r line
+ [[ zraminstall=enable =~ ^(#)?[a-zA-Z] ]]
+ parsed=zraminstall=enable
+ [[ zraminstall=enable =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo zraminstall=enable
+ param=zraminstall
+ [[ -v zraminstall ]]
+ read -r line
+ echo ''
+ read -r line
+ [[ # start comitup hotspot if internet is not reachable =~ ^(#)?[a-zA-Z] ]]
+ echo '# start comitup hotspot if internet is not reachable'
+ read -r line
+ [[ hotspot=enable =~ ^(#)?[a-zA-Z] ]]
+ parsed=hotspot=enable
+ [[ hotspot=enable =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo hotspot=enable
+ param=hotspot
+ [[ -v hotspot ]]
+ read -r line
+ echo ''
+ read -r line
+ [[ # external SD card device to backup and mirror the internal SD card to =~ ^(#)?[a-zA-Z] ]]
+ echo '# external SD card device to backup and mirror the internal SD card to'
+ read -r line
+ [[ #backupdrive=/dev/sda =~ ^(#)?[a-zA-Z] ]]
+ parsed='#backupdrive=/dev/sda'
+ [[ #backupdrive=/dev/sda =~ ^#[a-zA-Z] ]]
+ parsed=backupdrive=/dev/sda
++ cut -d= -f1
++ echo backupdrive=/dev/sda
+ param=backupdrive
+ [[ -v backupdrive ]]
+ echo '#backupdrive=/dev/sda'
+ eval backupdrive=/dev/sda
++ backupdrive=/dev/sda
+ read -r line
+ [[ storageconfig=openhab-dir =~ ^(#)?[a-zA-Z] ]]
+ parsed=storageconfig=openhab-dir
+ [[ storageconfig=openhab-dir =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo storageconfig=openhab-dir
+ param=storageconfig
+ [[ -v storageconfig ]]
+ [[ openhab-dir == *\ * ]]
+ read -r line
+ [[ storagedir=/storage =~ ^(#)?[a-zA-Z] ]]
+ parsed=storagedir=/storage
+ [[ storagedir=/storage =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo storagedir=/storage
+ param=storagedir
+ [[ -v storagedir ]]
+ [[ /storage == *\ * ]]
+ read -r line
+ [[ storagetapes=15 =~ ^(#)?[a-zA-Z] ]]
+ parsed=storagetapes=15
+ [[ storagetapes=15 =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo storagetapes=15
+ param=storagetapes
+ [[ -v storagetapes ]]
+ [[ 15 == *\ * ]]
+ read -r line
+ [[ storagecapacity=10240 =~ ^(#)?[a-zA-Z] ]]
+ parsed=storagecapacity=10240
+ [[ storagecapacity=10240 =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo storagecapacity=10240
+ param=storagecapacity
+ [[ -v storagecapacity ]]
+ [[ 10240 == *\ * ]]
+ read -r line
+ echo ''
+ read -r line
+ [[ # mail relay settings =~ ^(#)?[a-zA-Z] ]]
+ echo '# mail relay settings'
+ read -r line
+ [[ #adminmail=john.doe@foo.bar =~ ^(#)?[a-zA-Z] ]]
+ parsed='#adminmail=john.doe@foo.bar'
+ [[ #adminmail=john.doe@foo.bar =~ ^#[a-zA-Z] ]]
+ parsed=adminmail=john.doe@foo.bar
++ cut -d= -f1
++ echo adminmail=john.doe@foo.bar
+ param=adminmail
+ [[ -v adminmail ]]
+ echo '#adminmail=john.doe@foo.bar'
+ eval adminmail=john.doe@foo.bar
++ adminmail=john.doe@foo.bar
+ read -r line
+ [[ #relayuser=john.doe@foo.bar =~ ^(#)?[a-zA-Z] ]]
+ parsed='#relayuser=john.doe@foo.bar'
+ [[ #relayuser=john.doe@foo.bar =~ ^#[a-zA-Z] ]]
+ parsed=relayuser=john.doe@foo.bar
++ cut -d= -f1
++ echo relayuser=john.doe@foo.bar
+ param=relayuser
+ [[ -v relayuser ]]
+ echo '#relayuser=john.doe@foo.bar'
+ eval relayuser=john.doe@foo.bar
++ relayuser=john.doe@foo.bar
+ read -r line
+ [[ #relaypass=secret =~ ^(#)?[a-zA-Z] ]]
+ parsed='#relaypass=secret'
+ [[ #relaypass=secret =~ ^#[a-zA-Z] ]]
+ parsed=relaypass=secret
++ cut -d= -f1
++ echo relaypass=secret
+ param=relaypass
+ [[ -v relaypass ]]
+ echo '#relaypass=secret'
+ eval relaypass=secret
++ relaypass=secret
+ read -r line
+ [[ #smarthost=smtp.gmail.com =~ ^(#)?[a-zA-Z] ]]
+ parsed='#smarthost=smtp.gmail.com'
+ [[ #smarthost=smtp.gmail.com =~ ^#[a-zA-Z] ]]
+ parsed=smarthost=smtp.gmail.com
++ cut -d= -f1
++ echo smarthost=smtp.gmail.com
+ param=smarthost
+ [[ -v smarthost ]]
+ echo '#smarthost=smtp.gmail.com'
+ eval smarthost=smtp.gmail.com
++ smarthost=smtp.gmail.com
+ read -r line
+ [[ #smartport=587 =~ ^(#)?[a-zA-Z] ]]
+ parsed='#smartport=587'
+ [[ #smartport=587 =~ ^#[a-zA-Z] ]]
+ parsed=smartport=587
++ cut -d= -f1
++ echo smartport=587
+ param=smartport
+ [[ -v smartport ]]
+ echo '#smartport=587'
+ eval smartport=587
++ smartport=587
+ read -r line
+ echo ''
+ read -r line
+ [[ # Tailscale VPN =~ ^(#)?[a-zA-Z] ]]
+ echo '# Tailscale VPN'
+ read -r line
+ [[ #preauthkey=tskey-xxxxxxxxxxxxxxxxx =~ ^(#)?[a-zA-Z] ]]
+ parsed='#preauthkey=tskey-xxxxxxxxxxxxxxxxx'
+ [[ #preauthkey=tskey-xxxxxxxxxxxxxxxxx =~ ^#[a-zA-Z] ]]
+ parsed=preauthkey=tskey-xxxxxxxxxxxxxxxxx
++ cut -d= -f1
++ echo preauthkey=tskey-xxxxxxxxxxxxxxxxx
+ param=preauthkey
+ [[ -v preauthkey ]]
+ echo '#preauthkey=tskey-xxxxxxxxxxxxxxxxx'
+ eval preauthkey=tskey-xxxxxxxxxxxxxxxxx
++ preauthkey=tskey-xxxxxxxxxxxxxxxxx
+ read -r line
+ echo ''
+ read -r line
+ [[ # vim: filetype=sh =~ ^(#)?[a-zA-Z] ]]
+ echo '# vim: filetype=sh'
+ read -r line
+ config_ipv6
+ local aptConf=/etc/apt/apt.conf.d/S90force-ipv4
+ local sysctlConf=/etc/sysctl.d/99-sysctl.conf
+ [[ enable == \d\i\s\a\b\l\e ]]
+ [[ enable == \e\n\a\b\l\e ]]
+ grep -qs '^[[:space:]]*# Disable all IPv6 functionality' /etc/sysctl.d/99-sysctl.conf
+ [[ -n '' ]]
+ apt_update
+ PID_APT=21359
+ whiptail_check
++ command -v whiptail
+ [[ -x /usr/bin/whiptail ]]
+ load_create_config
+ local 'questionText=\nWelcome to openHABian!\n\nPlease provide the name of your Linux user i.e. the account you normally log in with.\n\nTypical user names are '\''pi'\'' or '\''ubuntu'\''.'
+ local input
+ [[ -f /etc/openhabian.conf ]]
+ apt-get update
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-02-18_15:53:07_CET [openHABian] Loading configuration file '\''/etc/openhabian.conf'\''... '
2021-02-18_15:53:07_CET [openHABian] Loading configuration file '/etc/openhabian.conf'... ++ getent group openhabian
+ [[ ! -n openhabian:x:1001:openhabian,frontail ]]
+ id -u openhabian
+ source /etc/openhabian.conf
++ hostname=openhabian
++ username=openhabian
++ userpw=openhabian
++ timezone=Europe/Berlin
++ locales='en_US.UTF-8 de_DE.UTF-8'
++ system_default_locale=en_US.UTF-8
++ wifi_ssid=
++ wifi_psk=
++ wifi_country=
++ ipv6=enable
++ repositoryurl=https://github.com/openhab/openhabian.git
++ clonebranch=openHAB3
++ debugmode=maximum
++ hwarch=amd64
++ java_opt=Zulu11-64
++ frontailtheme=light
++ zraminstall=enable
++ hotspot=enable
++ storageconfig=openhab-dir
++ storagedir=/storage
++ storagetapes=15
++ storagecapacity=10240
+ echo OK
OK
+ openhabian_console_check
+ [[ -z 1 ]]
++ tput cols
+ [[ 246 -ge 120 ]]
+ return 0
+ openhabian_update_check
+ [[ -z 1 ]]
+ local branch
+ local introText
+ local unsupportedHWText
+ local unsupportedOSText
+ branch=openHAB3
+ introText='Additions, improvements or fixes were added to the openHABian configuration tool. Would you like to update now and benefit from them? The update will not automatically apply changes to your system.\n\nUpdating is recommended.'
+ unsupportedHWText='You are running on old hardware that is no longer officially supported.\nopenHABian may still work with this or not.\nWe recommend that you replace your hardware with a current SBC such as a RPi4/2GB.\nDo you really want to c ontinue using openHABian on this system?'
+ unsupportedOSText='You are running an old Linux release that is no longer officially supported.\nWe recommend upgrading to the most current stable release of your distribution (or current Long Term Support version for distributions that offer L TS).\nDo you really want to continue using openHABian on this system?'
++ timestamp
++ date +%F_%T_%Z
++ get_git_revision
++ local branch
++ local latestTag
++ local revCount
++ local shorthash
+++ git -C /opt/openhabian rev-parse --abbrev-ref HEAD
++ branch=openHAB3
+++ git -C /opt/openhabian describe --tags --abbrev=0
++ latestTag=patchday-20210119
+++ wc -l
+++ git -C /opt/openhabian log --oneline
++ revCount=1149
+++ git -C /opt/openhabian log --pretty=format:%h -n 1
++ shorthash=04378b8
++ echo '[openHAB3]patchday-20210119-1149(04378b8)'
+ echo '2021-02-18_15:53:07_CET [openHABian] openHABian configuration tool version: [openHAB3]patchday-20210119-1149(04378b8)'
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-02-18_15:53:07_CET [openHABian] Checking for changes in origin branch openHAB3... '
2021-02-18_15:53:07_CET [openHABian] Checking for changes in origin branch openHAB3... + is_pine64
++ uname -r
+ [[ 4.19.0-14-amd64 =~ pine64-longsleep ]]
+ return 1
+ is_jessie
+ [[ buster == \j\e\s\s\i\e ]]
++ cat /etc/os-release
+ [[ PRETTY_NAME="Debian GNU/Linux 10 (buster)"
NAME="Debian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/" =~ jessie ]]
+ return 1
+ is_xenial
+ [[ buster == \x\e\n\i\a\l ]]
VERSION_ID="10"
ID=debian
BUG_REPORT_URL="https://bugs.debian.org/" =~ xenial ]]
+ return 1
+ git -C /opt/openhabian config user.email openhabian@openHABian
+ git -C /opt/openhabian config user.name openhabian
+ git -C /opt/openhabian fetch --quiet origin
++ git -C /opt/openhabian rev-parse openHAB3
++ git -C /opt/openhabian rev-parse '@{u}'
+ [[ 04378b84f5c023624404ff67709e0e510d505e1e == 04378b84f5c023624404ff67709e0e510d505e1e ]]
+ echo OK
OK
+ openhabian_announcements
+ [[ -z 1 ]]
+ local newsFile
+ local readNews
+ newsFile=/opt/openhabian/NEWS.md
+ readNews=/opt/openhabian/docs/LASTNEWS.md
+ cmp --silent /opt/openhabian/NEWS.md /opt/openhabian/docs/LASTNEWS.md
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-02-18_15:53:08_CET [openHABian] Switching to branch openHAB3... '
2021-02-18_15:53:08_CET [openHABian] Switching to branch openHAB3... + git -C /opt/openhabian checkout --quiet openHAB3
+ echo OK
OK
+ show_main_menu
+ local choice
+ local version
+++ get_git_revision
+++ local branch
+++ local latestTag
+++ local revCount
+++ local shorthash
++++ git -C /opt/openhabian rev-parse --abbrev-ref HEAD
+++ branch=openHAB3
++++ git -C /opt/openhabian describe --tags --abbrev=0
+++ latestTag=patchday-20210119
++++ wc -l
++++ git -C /opt/openhabian log --oneline
+++ revCount=1149
++++ git -C /opt/openhabian log --pretty=format:%h -n 1
+++ shorthash=04378b8
+++ echo '[openHAB3]patchday-20210119-1149(04378b8)'
++ whiptail --title 'Welcome to the openHABian Configuration Tool [openHAB3]patchday-20210119-1149(04378b8)' --menu 'Setup Options' 18 116 11 --cancel-button Exit --ok-button Execute '00 | About openHABian' 'Information about the openHABian proje ct and this tool' '' '' '01 | Select Branch' 'Select the openHABian config tool version ("branch") to run' '02 | Upgrade System' 'Upgrade all installed software packages (incl. openHAB) to their latest version' '03 | Install openHAB' 'Install or upgrade to openHAB release 3' '' '' '10 | Apply Improvements' 'Apply the latest improvements to the basic openHABian setup ►' '20 | Optional Components' 'Choose from a set of optional software components ►' '30 | System Settings' 'A range of syst em and hardware related configuration steps ►' '40 | openHAB Related' 'Switch the installed openHAB version or apply tweaks ►' '50 | Backup/Restore' 'Manage backups and restore your system ►'
+ choice='10 | Apply Improvements'
+ RET=0
+ '[' 0 -eq 1 ']'
+ '[' 0 -eq 255 ']'
+ [[ 10 | Apply Improvements == '' ]]
+ [[ 10 | Apply Improvements == \0\0* ]]
+ [[ 10 | Apply Improvements == \0\1* ]]
+ [[ 10 | Apply Improvements == \0\2* ]]
+ [[ 10 | Apply Improvements == \0\3* ]]
+ [[ 10 | Apply Improvements == \1\0* ]]
+++ local branch
+++ local latestTag
+++ local revCount
+++ local shorthash
+++ branch=openHAB3
++++ wc -l
+++ revCount=1149
++ whiptail --title 'Welcome to the openHABian Configuration Tool [openHAB3]patchday-20210119-1149(04378b8)' --menu 'Apply Improvements' 13 116 6 --cancel-button Back --ok-button Execute '11 | Packages' 'Install needed and recommended system pack ages' '12 | Bash&Vim Settings' 'Update customized openHABian settings for bash, vim and nano' '13 | System Tweaks' 'Add /srv mounts and update settings typical for openHAB' '14 | Fix Permissions' 'Update file permissions of commonly used files an d folders' '15 | FireMotD' 'Upgrade the program behind the system overview on SSH login' '16 | Samba' 'Install the Samba file sharing service and set up openHAB shares'
+ choice2='11 | Packages'
+ '[' 0 -eq 1 ']'
+ '[' 1 -eq 255 ']'
+ wait_for_apt_to_finish_update
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-02-18_15:53:14_CET [openHABian] Updating Linux package information... '
2021-02-18_15:53:14_CET [openHABian] Updating Linux package information... + [[ -z 21359 ]]
+ tail --pid=21359 -f /dev/null
+ echo OK
OK
+ case "$choice2" in
+ basic_packages
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-02-18_15:53:14_CET [openHABian] Installing basic can'\''t-be-wrong packages (screen, vim, ...)... '
2021-02-18_15:53:14_CET [openHABian] Installing basic can't-be-wrong packages (screen, vim, ...)... ++ command -v raspi-config
+ [[ -x '' ]]
+ cond_redirect apt-get install --yes screen vim nano mc vfu bash-completion htop curl wget multitail git util-linux bzip2 zip unzip xz-utils software-properties-common man-db whiptail acl usbutils dirmngr arping
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ apt-get install --yes screen vim nano mc vfu bash-completion htop curl wget multitail git util-linux bzip2 zip unzip xz-utils software-properties-common man-db whiptail acl usbutils dirmngr arping \033[39;49;00m'
+ apt-get install --yes screen vim nano mc vfu bash-completion htop curl wget multitail git util-linux bzip2 zip unzip xz-utils software-properties-common man-db whiptail acl usbutils dirmngr arping
Reading package lists... Done
Building dependency tree
acl is already the newest version (2.2.53-4).
arping is already the newest version (2.19-6).
bash-completion is already the newest version (1:2.8-6).
bzip2 is already the newest version (1.0.6-9.2~deb10u1).
curl is already the newest version (7.64.0-4+deb10u1).
git is already the newest version (1:2.20.1-2+deb10u3).
dirmngr is already the newest version (2.2.12-1+deb10u1).
htop is already the newest version (2.2.0-1+b1).
man-db is already the newest version (2.8.5-2).
mc is already the newest version (3:4.8.22-1).
multitail is already the newest version (6.4.2-3+b1).
nano is already the newest version (3.2-3).
whiptail is already the newest version (0.52.20-8).
screen is already the newest version (4.6.2-3).
software-properties-common is already the newest version (0.96.20.2-2).
unzip is already the newest version (6.0-23+deb10u2).
usbutils is already the newest version (1:010-3).
util-linux is already the newest version (2.33.1-0.1).
vfu is already the newest version (4.16+repack-1+b1).
vim is already the newest version (2:8.1.0875-5).
wget is already the newest version (1.20.1-1.1).
xz-utils is already the newest version (5.2.4-1).
zip is already the newest version (3.0-11+b1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
+ return 0
+ echo OK
OK
+ needed_packages
+ local 'bluetoothPackages=bluez python3-dev libbluetooth-dev raspberrypi-sys-mods pi-bluetooth'
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-02-18_15:53:15_CET [openHABian] Installing additional needed packages... '
2021-02-18_15:53:15_CET [openHABian] Installing additional needed packages... + cond_redirect apt-get install --yes apt-transport-https bc sysstat jq moreutils avahi-daemon python3 python3-pip python3-wheel python3-setuptools avahi-autoipd fontco nfig
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ apt-get install --yes apt-transport-https bc sysstat jq moreutils avahi-daemon python3 python3-pip python3-wheel python3-setuptools avahi-autoipd fontconfig \033[39;49;00m'
+ apt-get install --yes apt-transport-https bc sysstat jq moreutils avahi-daemon python3 python3-pip python3-wheel python3-setuptools avahi-autoipd fontconfig
apt-transport-https is already the newest version (1.8.2.2).
avahi-autoipd is already the newest version (0.7-4+b1).
avahi-daemon is already the newest version (0.7-4+b1).
bc is already the newest version (1.07.1-2+b1).
fontconfig is already the newest version (2.13.1-2).
jq is already the newest version (1.5+dfsg-2+b1).
moreutils is already the newest version (0.62-1).
python3-pip is already the newest version (18.1-5).
python3-setuptools is already the newest version (40.8.0-1).
python3 is already the newest version (3.7.3-1).
sysstat is already the newest version (12.0.3-2).
python3-wheel is already the newest version (0.32.3-2).
+ return 0
+ echo OK
OK
+ is_pizerow
+ [[ pi4 == \p\i\0\w ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]0[cC][0-9a-fA-F]$' /proc/cpuinfo
+ return 1
+ is_pithree
+ [[ pi4 == \p\i\3 ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]0[8dDeE][0-9a-fA-F]$' /proc/cpuinfo
+ return 1
+ is_pithreeplus
+ [[ pi4 == \p\i\3\+ ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]0[dDeE][0-9a-fA-F]$' /proc/cpuinfo
+ return 1
+ is_pifour
+ [[ pi4 == \p\i\4 ]]
+ return 0
+ [[ -z '' ]]
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-02-18_15:53:16_CET [openHABian] Installing pigpio package... '
2021-02-18_15:53:16_CET [openHABian] Installing pigpio package... + cond_redirect apt-get install --yes pigpio
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ apt-get install --yes pigpio \033[39;49;00m'
+ apt-get install --yes pigpio
Package pigpio is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'pigpio' has no installation candidate
+ return 100
+ echo FAILED
FAILED
+ return 1
+ '[' 1 -ne 0 ']'
+ whiptail --msgbox 'There was an error or interruption during the execution of:\n "10 | Apply Improvements"\n\nPlease try again. If the error persists, please read /opt/openhabian/docs/openhabian-DEBUG.md or https://github.com/openhab/openhabia n/blob/master/docs/openhabian-DEBUG.md how to proceed.' 14 80
+ return 0
+ true
+ show_main_menu
+ local choice
+ local version
+++ local branch
+++ local latestTag
+++ local revCount
+++ local shorthash
+++ branch=openHAB3
++++ wc -l
+++ revCount=1149
+ choice=
+ RET=1
+ '[' 1 -eq 1 ']'
+ return 255
+ system_check_default_password
+ is_pi
+ is_pifour
+ return 0
+ return 0
+ local algo
+ local defaultPassword
+ local defaultUser
+ local generatedPassword
+ local introText
+ local originalPassword
+ local salt
+ is_pi
+ is_pifour
+ return 0
+ return 0
+ id -u pi
+ is_pi
+ is_pifour
+ return 0
+ return 0
+ defaultUser=openhabian
+ defaultPassword=openhabian
++ cut -d: -f2
++ grep -w openhabian /etc/shadow
+ originalPassword='#####removed#####
++ cut '-d$' -f2
++ echo '#####removed#####'
+ algo=6
+ introText='The default password was detected on your system! That is a serious security concern. Bad guys or malicious programs in your subnet are able to gain root access!\n\nPlease set a strong password by typing the command '\''passwd openha bian'\''!'
++ cut '-d$' -f3
+ salt=kgf0Rmy5
+ export algo defaultPassword salt
++ perl -le 'print crypt("$ENV{defaultPassword}","\$$ENV{algo}\$$ENV{salt}\$")'
+ generatedPassword='#####removed#####'
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-02-18_15:53:20_CET [openHABian] Checking for default openHABian username:password combination... '
2021-02-18_15:53:20_CET [openHABian] Checking for default openHABian username:password combination... ++ id -u openhabian
+ [[ -n 1001 ]]
+ [[ #####removed##### == #####removed##### ]]
+ echo OK
OK
++ timestamp
++ date +%F_%T_%Z
+ echo -e '2021-02-18_15:53:20_CET [openHABian] We hope you got what you came for! See you again soon ;)'
+ cd /root
[15:53:20] root@openhab:
Steps taken to get this error:
-) start “openhabian-config” on command line
-) Navigate to “Apply Improvements”
-) Choose “Packages”
-) After the error was displayed, select “ok” and exit the tool
