after migration to OH3 I followed the needed steps to get the influx DB uip and running. All my values are stored, but I have two issues:
First I get an error I do not know from what it is caused:
2021-01-05 09:50:39.796 [ERROR] [org.influxdb.impl.BatchProcessor ] - Batch could not be sent. Data will be lost
org.influxdb.InfluxDBIOException: java.net.SocketTimeoutException: timeout
at org.influxdb.impl.InfluxDBImpl.execute(InfluxDBImpl.java:831) ~[bundleFile:?]
at org.influxdb.impl.InfluxDBImpl.write(InfluxDBImpl.java:460) ~[bundleFile:?]
at org.influxdb.impl.OneShotBatchWriter.write(OneShotBatchWriter.java:22) ~[bundleFile:?]
at org.influxdb.impl.BatchProcessor.write(BatchProcessor.java:340) [bundleFile:?]
at org.influxdb.impl.BatchProcessor$1.run(BatchProcessor.java:287) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
Caused by: java.net.SocketTimeoutException: timeout
at okio.Okio$4.newTimeoutException(Okio.java:232) ~[bundleFile:?]
at okio.AsyncTimeout.exit(AsyncTimeout.java:286) ~[bundleFile:?]
at okio.AsyncTimeout$2.read(AsyncTimeout.java:241) ~[bundleFile:?]
at okio.RealBufferedSource.indexOf(RealBufferedSource.java:358) ~[bundleFile:?]
at okio.RealBufferedSource.readUtf8LineStrict(RealBufferedSource.java:230) ~[bundleFile:?]
at okhttp3.internal.http1.Http1ExchangeCodec.readHeaderLine(Http1ExchangeCodec.java:242) ~[bundleFile:?]
at okhttp3.internal.http1.Http1ExchangeCodec.readResponseHeaders(Http1ExchangeCodec.java:213) ~[bundleFile:?]
at okhttp3.internal.connection.Exchange.readResponseHeaders(Exchange.java:115) ~[bundleFile:?]
at okhttp3.internal.http.CallServerInterceptor.intercept(CallServerInterceptor.java:94) ~[bundleFile:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:142) ~[bundleFile:?]
at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:43) ~[bundleFile:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:117) ~[bundleFile:?]
at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:94) ~[bundleFile:?]
at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.java:93) ~[bundleFile:?]
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:88) ~[bundleFile:?]
at org.influxdb.impl.BasicAuthInterceptor.intercept(BasicAuthInterceptor.java:22) ~[bundleFile:?]
at org.influxdb.impl.GzipRequestInterceptor.intercept(GzipRequestInterceptor.java:42) ~[bundleFile:?]
at okhttp3.logging.HttpLoggingInterceptor.intercept(HttpLoggingInterceptor.java:152) ~[bundleFile:?]
at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:229) ~[bundleFile:?]
at okhttp3.RealCall.execute(RealCall.java:81) ~[bundleFile:?]
at retrofit2.OkHttpCall.execute(OkHttpCall.java:188) ~[bundleFile:?]
at org.influxdb.impl.InfluxDBImpl.execute(InfluxDBImpl.java:819) ~[bundleFile:?]
… 10 more
Caused by: java.net.SocketException: Socket closed
at java.net.SocketInputStream.read(SocketInputStream.java:183) ~[?:?]
at java.net.SocketInputStream.read(SocketInputStream.java:140) ~[?:?]
at okio.Okio$2.read(Okio.java:140) ~[bundleFile:?]
at okio.AsyncTimeout$2.read(AsyncTimeout.java:237) ~[bundleFile:?]
… 10 more
And second when I restart my openhab the persistance service is not “restoreOnStartup” while it is configured on influxdb.persist
I have the exact same issue. restoreOnStartup is fixable by using the 3.1 snapshot version of the InbluxDB addon. I downloaded the 3.1 addons from the website and copied the .kar file in the Openhab addons folder. Then reinstalled the 3.1 version of the influxdb service from mainUI.
Sorry. I didn’t have the direct download link of the addon since the official download site doesn’t serve the snapshot version anymore.
The issue I still have, is that the connection is dropped. On my system, it starts with:
2021-01-07 13:03:06.552 [WARN ] [okhttp3.OkHttpClient ] - A connection to http://127.0.0.1:8086/ was leaked. Did you forget to close a response body? To see where this was allocated, set the OkHttpClient logger level to FINE: Logger.getLogger(OkHttpClient.class.getName()).setLevel(Level.FINE);
2021-01-07 13:44:52.712 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'PowerConsumptionPerDay-2' failed: null in PowerConsumptionPerDay
2021-01-07 13:44:52.724 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'PowerConsumptionPerDay-2' failed: null in PowerConsumptionPerDay
2021-01-07 13:44:52.728 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'PowerProductionPerDay-2' failed: java.net.ProtocolException: Unexpected status line: TP/1.1 400 Bad Request in PowerProductionPerDay
2021-01-07 13:44:52.734 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'PowerProductionPerDay-2' failed: null in PowerProductionPerDay
2021-01-07 13:44:52.821 [ERROR] [org.influxdb.impl.BatchProcessor ] - Batch could not be sent. Data will be lost
org.influxdb.InfluxDBIOException: java.net.ProtocolException: Unexpected status line: n&consistency=one HTTP/1.1
Caused by: java.net.ProtocolException: Unexpected status line: n&consistency=one HTTP/1.1
at okhttp3.internal.http.StatusLine.parse(StatusLine.java:69) ~[bundleFile:?]
... 10 more
2021-01-07 13:44:53.646 [ERROR] [org.influxdb.impl.BatchProcessor ] - Batch could not be sent. Data will be lost
org.influxdb.InfluxDBIOException: java.net.ProtocolException: Unexpected status line: xMjc4MiE=
Caused by: java.net.ProtocolException: Unexpected status line: xMjc4MiE=
... 10 more
After the on device (rpi3) migration from OH2.5.12 to OH3.1.0M3 my log file is getting flooded with entries like this:
2021-04-10 08:37:04.065 [WARN ] [okhttp3.OkHttpClient ] - A connection to http://192.168.10.111:8086/ was leaked. Did you forget to close a response body? To see where this was allocated, set the OkHttpClient logger level to FINE: Logger.getLogger(OkHttpClient.class.getName()).setLevel(Level.FINE);
192.168.10.111 is the IP of my InfluxDB Docker instance which is used to persist OH items.
