Hi all,
I’m on openHabian 3.1.0 on a raspberry Pi4 Model B.
One morning my webpage wouldn’t load, I just got a blank page. (it automagically solved itself the next day). Restarting the OH service from shell ( sudo systemctl restart openhab ) I got a message “The unit file, source configuration file or drop-ins of openhab.service changed on disk. Run ‘systemctl daemon-reload’ to reload units.”
While investigating, I stumbled on the following message on startup:
Blockquote
2021-09-18 08:26:22.527 [WARN ] [org.apache.felix.fileinstall ] - C:\openhab-3.1.0/addons does not exist, please create it.
2021-09-18 08:26:22.544 [WARN ] [org.apache.felix.fileinstall ] - Root path does not exist: /var/lib/openhab/C:\openhab-3.1.0/addons
2021-09-18 08:26:22.553 [WARN ] [org.apache.felix.fileinstall ] - C:\Users\Steven\DOWNLO~1\OPENHA~1.0/addons does not exist, please create it.
2021-09-18 08:26:22.555 [WARN ] [org.apache.felix.fileinstall ] - Root path does not exist: /var/lib/openhab/C:\Users\Steven\DOWNLO~1\OPENHA~1.0/addons
2021-09-18 08:26:30.570 [WARN ] [.core.internal.i18n.I18nProviderImpl] - Region (“BE”) is invalid. Skip it.
Since I’m running on a Rpi4, it’s strange to see a pointer to C:\openhab…
I found the origin to be /var/lib/openhab/etc/openHAB-wrapper.conf and the first line reads “openHAB-wrapper.conf for Windows Service Installation”.
It doesn’t seem to exist on raspberry clean install, so is it safe to delete this file?
Thank you,
Steven.
