Hi all,
I have this jython rule file:
this class manage lights
from core.rules import rule
from core.triggers import ItemStateChangeTrigger, when
from core import utils
from core import osgi
from core.jsr223.scope import events
from core.actions import ScriptExecution
from java.time import ZonedDateTime
@rule(name="Timered Lights")
class TimerLight(object):
def __init__(self):
self.relays_map = {
'timer1_i': ['timer1_r', 5],
'LC71A_antibagno_i': ['LC71A_antibagno_r', 10]
self.triggers = [ItemStateChangeTrigger(item_name=key).trigger for key in self.relays_map.keys()]
self.timers = {key: None for key in self.relays_map.keys()}
self.log.info("Timer init done")
def timer_start(self, switch_name):
timer = self.timers[switch_name]
interval = ZonedDateTime.now().plusSeconds(self.relays_map[switch_name][1])
relay_item = utils.validate_item(self.relays_map[switch_name][0])
self.log.info("Timing switch {}, timer: {}".format(switch_name, timer))
if timer is None:
self.timers[switch_name] = ScriptExecution.createTimer(interval, lambda: events.sendCommand(relay_item, "OFF"))
else:
timer.reschedule(interval)
self.log.info("Exec time: {}".format(timer.getExecutionTime()))
def execute(self, module, inputs):
switch_name = inputs['event'].getItemName()
if relay_item is not None:
current_state = relay_item.getState().toString()
if current_state == "OFF":
events.sendCommand(relay_item, "ON")
self.timer_start(switch_name)
elif current_state == "ON":
if timer is not None:
timer.cancel()
@rule(name="Sensored Lights")
class SensoredLight(object):
def __init__(self):
self.triggers = [
ItemStateChangeTrigger(item_name='timer2_i').trigger
ruleUID = [rule for rule in rules.getAll() if rule.name == "Timered Lights"][0].UID
ruleEngine = osgi.get_service("org.openhab.core.automation.RuleManager")
self.log.info(dir(ruleEngine))
I would like to access timer object (eventually by a method) present in TimerLight instance from SensoredLight instance.
I tried to explore osgi packages without success and also tried a very inefficient way with gc.get_objects() but is not implemented in Jython.
Any suggestions?
Thanks a lot.
