OH3 - Karaf console: How to escape strings?
Wanting to try out my new HmIP-WRCD I tried to send commands to the corresponding string item from the karaf console and didn’t get it to work because characters are stripped away from the command:
  • openhab:send Item_Name “{DDBC=WHITE,DDTC=BLACK,DDI=1,DDA=CENTER,DDS=Zeile1,DDID=1}”
    • New String (per log): DDBC=WHITE DDTC=BLACK DDI=1 DDA=CENTER DDS=Zeile1 DDID=1
  • openhab:send Item_Name {DDBC=WHITE,DDTC=BLACK,DDI=1,DDA=CENTER,DDS=Zeile1,DDID=1}
    • New String (per log): [DDBC=WHITE, DDTC=BLACK, DDI=1, DDA=CENTER, DDS=Zeile1, DDID=1]
    • New String (per log): {DDBC=WHITE,DDTC=BLACK,DDI=1,DDA=CENTER,DDS=Zeile,DDID=1}
    • New String (per log): {DDBC=WHITE,DDTC=BLACK,DDI=1,DDA=CENTER,DDS=Zeile1,DDID=1}
    • But it still doesn’t work.
Sending with a rule works just fine:
  • sendCommand(“{DDBC=WHITE,DDTC=BLACK,DDI=1,DDA=CENTER,DDS=Zeile1,DDID=1}”)
So something in karaf seems to be causing me trouble here, probably some escape string stuff. Is there any documentation how to correctly escape strings for the send command? I could not find any :frowning:
Karaf documentation is here.
Thanks, but I couldn’t find it in that documentation either.
Some more experimenting led me to try single quotes instead of double quotes and that finally worked:
openhab:send Item_Name ‘{DDBC=WHITE,DDTC=BLACK,DDI=1,DDA=CENTER,DDS=Zeile1,DDID=1}’
