Hello!
I installed openhabian (OH3) on a RaspberryPi3. I installed the KNX binding (via UI) and did my KNX configuration in the UI also. Everything worked fine (Bridge ok, Dimmers ok, lights ok). Things (are my KNX actors, channels and items (the lights). But for some reason it just stopped working and I get a “Status: UNINITIALIZED HANDLER_CONFIGURATION_PENDING” error on an actor (thing). I lost all other actors-things(knx) with exeption of the dimmeractor (thing). The bridge is still ok, the dimmers are still working. All other lights stopped working and the one actor that’s still there stopped working and got the error.
I redid all the configuration again (in the UI) but after a couple of days the same story. I can’t get any wiser on simular messages in the forum (still OH2). Is there a limitation on channels for a thing (too much lights on one actor)?
Here some screenshots and the generated code from the UI.
UID: knx:device:91e5418b85
label: KNXSwitchActuator1
thingTypeUID: knx:device
configuration:
pingInterval: 600
address: 1.1.27
readInterval: 0
fetch: false
bridgeUID: knx:ip:01c4f261aa
channels:
- id: chnKeukenLicht
channelTypeUID: knx:switch
label: ChannelKeukenLicht
description: null
configuration:
ga: 0/0/12+<0/2/12 - id: chnKeukeneilandLicht
label: ChannelKeukeneilandLicht
description: null
configuration:
ga: 0/0/13+<0/2/13 - id: chnKeukenAlleLichten
label: ChannelKeukenAlleLichten
description: null
configuration: {} - id: chnAlleLichten
label: ChannelAlleLichten
description: null
configuration: {} - id: chnSpeelhoekLicht
label: ChannelSpeelhoekLicht
description: null
configuration:
ga: 0/0/7+<0/2/7 - id: chnWasplaatsLicht
label: ChannelWasplaatsLicht
description: null
configuration:
ga: 0/0/6+<0/2/6 - id: chnWCLicht
label: ChannelWCLicht
description: null
configuration:
ga: 0/0/5+<0/2/5 - id: chnInkomhalLicht
label: ChannelInkomhalLicht
description: null
configuration:
ga: 0/0/1+<0/2/1 - id: chnTraphalLicht
label: ChannelTraphalLicht
description: null
configuration:
ga: 0/0/3+<0/2/3 - id: chnBergingLicht
label: ChannelBergingLicht
description: null
configuration:
ga: 0/0/14+<0/2/14 - id: chnGarageLicht
label: ChannelGarageLicht
description: null
configuration:
ga: 0/0/15+<0/2/15 - id: chnLivingStopcontactTV
label: ChannelLivingStopcontactTV
description: “”
configuration:
ga: 0/0/11+<0/2/11 - id: chnLivingStopcontactLED
label: ChannelLivingStopcontactLED
description: “”
configuration:
ga: 0/0/10+<0/2/10
Is it better to leave the UI and go for the code option? But can I still use the other things like scripts etc. via the UI? And where do I have to place those config files?
Hope someone could help me, because I got lost now ![]()
Thanks!
Pieter
