Hi. This looks great. But how can I change the direction for ex. the battery. When I discharge the battery, the house uses its energy, the arrow point to the opposit and the dot along the line runs the opposit direction. Is there an easy fix in the code to switch it around per unit?
Hi Joakim, I do not have a battery but did some tests anyway. The arrows direction on the house block will not change at all (but I think you where not pointing on this.).
The direction of the arrow and flow animation for battery will change according to “Item Battery Load/Decharge (first)” value. If value is positive then arrow points up and animation flows towards the house - so positive values on itemBattery represent battery discharge. Negative values - no surprise… - are representing charging of Battery and result in arrow pointing down. I did see though that the animation path did not switch visability correctly. Both path remained visible. I will change and post an update on this.
Hi here an updated version v2 …
Changes to v1 :
- Animations (except for Battery) are now changing in size and speed, depending on their representing value. Search for “.state)” in the code to see how its done.
- Border width of the blocks set to 2px
- Battery animation. Charging animation visible if ItemBattery is negative. Decharging (towards house) visible if ItemBattery is positive. Search for “(@props.itemBattery) < 0)” and “(@props.itemBattery) > 0)” in the code to find how/where this is done.
uid: Energy_Summary_eho_v2
tags:
- energy
- energy summary
- solar
props:
parameters:
- description: Widget Title
label: Widget Title
required: false
type: TEXT
- description: Grid Title
label: Grid Title
required: false
type: TEXT
- description: Background Color of Grid Title
label: Grid Title Background Color
required: false
type: TEXT
- context: item
description: Consumption From Grid
label: Consumption From Grid Item
required: true
type: TEXT
- context: item
description: Production to Grid
label: Production to Grid Item
required: false
type: TEXT
- description: Color of Grid block (default= teal)
label: Color of Grid block
required: false
- description: Background Color of Grid block
label: Background Color Grid
required: false
- description: Solar Title
label: Solar Title
required: false
type: TEXT
- description: Solar Title Background Color
label: Solar Title Background Color
required: false
type: TEXT
- context: item
description: Item Solar Production (first)
label: Solar Production Item (first)
required: false
type: TEXT
- context: item
description: Item Solar Production (second)
label: Solar Production Item (second)
required: false
type: TEXT
- context: item
description: Item Solar Production (third)
label: Solar Production Item (third)
required: false
type: TEXT
- description: Color of Solar block (default= orange)
label: Color of Solar block
required: false
- description: Background Color Solar of Solar block
label: Background Color Solar
required: false
- description: Home Title
label: Home Title
required: false
type: TEXT
- description: Home Title Background Color
label: Home Title Background Color
required: false
type: TEXT
- context: item
description: Home Consumption (first)
label: Home Consumption Item (first)
required: true
type: TEXT
- context: item
description: Home Consumption (second)
label: Home Consumption Item (second)
required: false
type: TEXT
- context: item
description: Home Consumption (third)
label: Home Consumption Item (third)
required: false
type: TEXT
- description: Color of Home block (default= gray)
label: Color of Home block
required: false
- description: Background Color of Home block
label: Background Color Home
required: false
- description: Self Consumption Title
label: Self Consumption Title
required: false
type: TEXT
- description: Self Consumption Title Background Color
label: Self Consumption Title Background Color
required: false
type: TEXT
- context: item
description: Home Self Consumption in percent
label: Home Self Consumption in percent
required: true
type: TEXT
- description: Color of Self Consumption block (default= teal)
label: Color of Self Consumption block
required: false
- description: Background Color Home Self Consumption
label: Background Color Home Self Consumption
required: false
- description: Battery Title
label: Battery Title
required: false
type: TEXT
- description: Battery Title Background Color
label: Battery Title Background Color
required: false
type: TEXT
- context: item
description: Battery Load/Decharge Item (first)
label: Item Battery Load/Decharge (first)
required: false
type: TEXT
- context: item
description: Battery Load/Decharge Item (second)
label: Item Battery Load/Decharge (second)
required: false
type: TEXT
- context: item
description: Battery Load/Decharge Item (third)
label: Item Battery Load/Decharge (third)
required: false
type: TEXT
- description: Color of Battery block (default= green)
label: Color of Battery block
required: false
- description: Background Color Battery
label: Background Color Battery
required: false
- description: Car Title
label: Car Title
required: false
type: TEXT
- description: Car Title Background Color
label: Car Title Background Color
required: false
type: TEXT
- context: item
description: Car Load Item (first)
label: Item Car Load (first)
required: false
type: TEXT
- context: item
description: Car Load Item (second)
label: Item Car Load (second)
required: false
type: TEXT
- context: item
description: Car Load Item (third)
label: Item Car Load (third)
required: false
type: TEXT
- description: Color of Car block (default= lightblue)
label: Color of Car block
required: false
- description: Background Color Car
label: Background Color Car
required: false
- description: Water Title
label: Water Title
required: false
type: TEXT
- description: Background Color of Water Title
label: Water Title Background Color
required: false
type: TEXT
- context: item
description: Water Load Item (first)
label: Item Water Load (first)
required: false
type: TEXT
- context: item
description: Water Load Item (second)
label: Item Water Load (second)
required: false
type: TEXT
- context: item
description: Water Load Item (third)
label: Item Water Load (third)
required: false
type: TEXT
- description: Color of Water block (default= blue)
label: Color of Water block
required: false
- description: Background Color Water
label: Background Color Water
required: false
- description: Non Fossil Title
label: Non Fossil Title
required: false
type: TEXT
- description: Non Fossil Title Background Color
label: Non Fossil Title Background Color
required: false
type: TEXT
- context: item
description: Non Fossil Value Item
label: Non Fossile Item
required: false
type: TEXT
- description: Color of Non Fossil block (default= darkred)
label: Color Non Fossil
required: false
- description: Background Color Non Fossil
label: Background Color Non Fossil
required: false
- description: Icon Dimension in px (default 100px, stay within 80 and 120px for best results)
label: Icon Dimension
required: false
- description: Border Radius in px (default 0px, significant changes between 40 and 70px)
label: Border Radius
required: false
parameterGroups: []
timestamp: Dec 13, 2023, 11:42:02 AM
component: f7-card
title: = props.title
slots:
content:
- component: f7-block
style:
margin: 0
padding: 0
slots:
default:
style:
--f7-block-font-size: 12px
--f7-theme-color: var(--f7-text-color)
display: flex
justify-content: space-between
margin: 0
padding: 0
slots:
default:
- component: f7-col
style:
align-items: center
display: flex
flex-direction: column
slots:
default:
- component: Label
style:
background: "=(props.titleNonFossilBgColor) ? props.titleNonFossilBgColor : 'transparent'"
text: "=(props.itemNonFossil) ? ((props.titleNonFossil) ? props.titleNonFossil : 'Non-Fossil') : ''"
bgColor: =(props.backColorNonFossil)
style:
align-items: center
border: "=(props.ColorNonFossil) ? (props.ColorNonFossil) + ' 2px solid' : 'darkred 2px solid'"
border-radius: "=(props.borderRadius) ? Number.parseInt(props.borderRadius) + 'px' : '0px'"
border-width: 2px
display: flex
height: "=(props.iconDimension) ? Number.parseInt(props.iconDimension) + 'px' : '100px'"
justify-content: center
width: "=(props.iconDimension) ? Number.parseInt(props.iconDimension) + 'px' : '100px'"
visible: "=(props.itemNonFossil) ? true : false"
slots:
default:
- component: oh-icon
color: "=(props.ColorNonFossil) ? (props.ColorNonFossil) : 'darkred"
height: 20px
icon: "=(props.itemNonFossil) ? 'if:mdi:heater' : ''"
- component: Label
style:
font-size: 12px
white-space: nowrap
text: = @props.itemNonFossil
style:
align-items: center
border: 1px solid transparent
display: flex
height: 22px
margin: 0
padding: 0
width: 1px
bgColor: =(props.backColorGrid)
style:
align-items: center
border: "=(props.ColorGrid) ? (props.ColorGrid) + ' 2px solid' : 'teal 2px solid'"
border-width: 2px
display: flex
margin-top: "=(props.itemNonFossil) ? '0px' : (((props.itemSolar) || (props.itemCar)) ? '140px' : '0px')"
slots:
default:
color: "=(props.ColorGrid) ? (props.ColorGrid) : 'teal'"
height: 20px
icon: if:mdi:transmission-tower
- component: oh-link
iconColor: purple
iconF7: "=(props.itemProductionToGrid) ? 'arrow_left' : ''"
iconSize: 12px
style:
font-size: 12px
white-space: nowrap
text: =@props.itemProductionToGrid
visible: "=(props.itemProductionToGrid) ? true : false"
iconColor: blue
iconF7: "=(props.itemConsumptionFromGrid) ? 'arrow_right' : ''"
iconSize: 12px
style:
font-size: 12px
white-space: nowrap
text: = @props.itemConsumptionFromGrid
visible: "=(props.itemConsumptionFromGrid) ? true : false"
- component: Label
style:
background: "=(props.titleGridBgColor) ? props.titleGridBgColor : 'transparent'"
text: "=(props.titleGrid) ? props.titleGrid : 'Grid'"
- component: f7-col
style:
align-items: center
display: flex
flex-grow: 1
slots:
default:
- component: Label
style:
background: "=(props.titleSolarBgColor) ? props.titleSolarBgColor : 'transparent'"
text: "=(props.itemSolar) ? ((props.titleSolar) ? props.titleSolar : 'Solar') : ''"
bgColor: =(props.backColorSolar)
style:
align-items: center
border: "=(props.ColorSolar) ? (props.ColorSolar) + ' 2px solid' : 'orange 2px solid'"
border-width: 2px
display: flex
visible: "=(props.itemSolar) ? true : false"
slots:
default:
color: "=(props.ColorSolar) ? (props.ColorSolar) : 'orange'"
height: 20px
icon: if:mdi:solar-power-variant
iconColor: blue
iconF7: "=(props.itemProductionToGrid) ? 'arrow_down' : ''"
iconSize: 12px
style:
font-size: 12px
white-space: nowrap
text: = @props.itemSolar
- component: Label
style:
font-size: 12px
white-space: nowrap
text: = @props.itemSolar2
visible: "=(props.itemSolar2) ? true : false"
- component: Label
style:
font-size: 12px
white-space: nowrap
text: = @props.itemSolar3
visible: "=(props.itemSolar3) ? true : false"
style:
display: flex
height: "=(props.itemSolar) ? '145px' : (((props.itemNonFossil) || (props.itemCar)) ? '320px' : '145px')"
margin: 0
padding: 0
width: 100%
visible: true
slots:
default:
- component: f7-row
preserveAspectRatio: xMidYMid slice
style:
height: auto
tag: svg
viewBox: "=((props.itemNonFossil) || (props.itemSolar) || (props.itemCar)) ? '0 0 100 100' : '0 8 100 100'"
xmlns: http://www.w3.org/2000/svg
slots:
default:
- component: f7-row
d: M53,0 v15 c0,27 10,36 30,36 h20
fill: none
stroke: "=(props.ColorSolar) ? (props.ColorSolar) : 'orange'"
stroke-width: 1
tag: path
vector-effect: non-scaling-stroke
visible: "=((props.itemSolar) && (Number.parseFloat(@props.itemSolar) > 0)) ? true : false"
- component: f7-row
fill: "=(props.ColorSolar) ? (props.ColorSolar) : 'orange'"
r: =2 + (Number.parseFloat(items[props.itemSolar].state)/2000)
style:
stroke-width: 4
tag: circle
slots:
default:
- component: f7-row
calcMode: linear
dur: =2 + 3000/(Number.parseFloat(items[props.itemSolar].state) +500)
repeatCount: indefinite
tag: animateMotion
slots:
default:
- component: f7-row
tag: mpath
xlink:href: "#path1"
- component: f7-row
d: M47,0 v15 c0,27 -10,36 -30,36 h-20
fill: none
stroke: purple
stroke-width: 1
tag: path
visible: "=((props.itemSolar) && (Number.parseFloat(@props.itemProductionToGrid) > 0)) ? true : false"
- component: f7-row
fill: purple
r: =2 + (Number.parseFloat(items[props.itemProductionToGrid].state)/2000)
strokeWidth: 10
tag: circle
vectorEffect: non-scaling-stroke
slots:
default:
- component: f7-row
calcMode: linear
dur: =2 + 3000/(Number.parseFloat(items[props.itemProductionToGrid].state) +500)
tag: animateMotion
slots:
default:
- component: f7-row
tag: mpath
xlink:href: "#path2"
- component: f7-row
d: M0,54 H100
fill: none
stroke: "=(props.ColorGrid) ? (props.ColorGrid) : 'teal'"
stroke-width: 1
tag: path
visible: "=(Number.parseFloat(@props.itemConsumptionFromGrid) > 0) ? true : false"
- component: f7-row
fill: "=(props.ColorGrid) ? (props.ColorGrid) : 'teal'"
r: =2 + (Number.parseFloat(items[props.itemConsumptionFromGrid].state)/2000)
strokeWidth: 10
tag: circle
slots:
default:
- component: f7-row
calcMode: linear
dur: =1 + 3000/(Number.parseFloat(items[props.itemConsumptionFromGrid].state) +500)
tag: animateMotion
slots:
default:
- component: f7-row
tag: mpath
xlink:href: "#path3"
- component: f7-row
d: M50,0 v100
fill: none
stroke: "=(props.ColorBattery) ? (props.ColorBattery) : 'green'"
stroke-width: 1
tag: path
visible: "=((props.itemBattery) && (props.itemSolar) && (Number.parseFloat(@props.itemBattery) < 0)) ? true : false"
- component: f7-row
fill: "=(props.ColorBattery) ? (props.ColorBattery) : 'green'"
r: 2
style:
stroke-width: 4
tag: circle
slots:
default:
- component: f7-row
calcMode: linear
dur: 5s
tag: animateMotion
slots:
default:
- component: f7-row
tag: mpath
xlink:href: "#path4"
- component: f7-row
d: M53,100 v-15 c0,-27 10,-32 30,-32 h20
fill: none
stroke-width: 1
tag: path
visible: "=((props.itemBattery) && (Number.parseFloat(@props.itemBattery) > 0)) ? true : false"
- component: f7-row
r: 2
style:
stroke-width: 4
tag: circle
slots:
default:
- component: f7-row
calcMode: linear
dur: 5s
tag: animateMotion
slots:
default:
- component: f7-row
tag: mpath
xlink:href: "#path5"
- component: oh-gauge
bgColor: =(props.backColorSelfConsumption)
borderBgColor: "=(props.ColorSelfConsumption) ? (props.ColorSelfConsumption) : 'teal'"
borderColor: "=(props.ColorSelfConsumption) ? (props.ColorSelfConsumption) : 'teal'"
borderWidth: 2
labelFontSize: 12
labelText: "=(props.itemSelfConsumption) ? ((props.titleSelfConsumption) ? props.titleSelfConsumption : 'SC') : ''"
labelTextColor: black
size: "=(props.iconDimension) ? (Number.parseInt(props.iconDimension) / 1.65) : '50'"
style:
margin-top: -100px
z-index: 100
type: circle
value: = @props.itemSelfConsumption
valueFontSize: 12
valueFontWeight: 400
valueText: = @props.itemSelfConsumption
bgColor: =(props.backColorBattery)
style:
align-items: center
border: "=(props.ColorBattery) ? (props.ColorBattery) + ' 2px solid' : 'green 2px solid'"
border-width: 2px
display: flex
margin-top: 46px
visible: "=(props.itemBattery) ? true : false"
slots:
default:
color: "=(props.ColorBattery) ? (props.ColorBattery) : 'green'"
height: 20px
icon: if:mdi:battery-charging
iconColor: "=(props.itemBattery) ? ((Number.parseFloat(@props.itemBattery) < 0) ? 'purple' : 'blue') : ''"
iconF7: "=(props.itemBattery) ? ((Number.parseFloat(@props.itemBattery) < 0) ? 'arrow_down' : 'arrow_up') : ''"
iconSize: 12px
style:
font-size: 12px
white-space: nowrap
text: = @props.itemBattery
- component: Label
style:
font-size: 12px
white-space: nowrap
text: = @props.itemBattery2
visible: "=(props.itemBattery2) ? true : false"
- component: Label
style:
font-size: 12px
white-space: nowrap
text: = @props.itemBattery3
visible: "=(props.itemBattery3) ? true : false"
- component: Label
style:
background: "=(props.titleBatteryBgColor) ? props.titleBatteryBgColor : 'transparent'"
text: "=(props.itemBattery) ? ((props.titleBattery) ? props.titleBattery : 'Battery') : ''"
- component: f7-col
style:
align-items: center
display: flex
slots:
default:
- component: Label
style:
background: "=(props.titleCarBgColor) ? props.titleCarBgColor : 'transparent'"
text: "=(props.itemCar) ? ((props.titleCar) ? props.titleCar : 'Car') : ''"
bgColor: =(props.backColorCar)
style:
align-items: center
border: "=(props.ColorCar) ? (props.ColorCar) + ' 2px solid' : 'lightblue 2px solid'"
border-width: 2px
display: flex
margin-top: 0px
visible: "=(props.itemCar) ? true : false"
slots:
default:
color: "=(props.ColorCar) ? (props.ColorCar) : 'lightblue'"
height: 20px
icon: if:mdi:car
style:
font-size: 12px
white-space: nowrap
text: =@props.itemCar
- component: Label
style:
font-size: 12px
white-space: nowrap
text: = @props.itemCar2
visible: "=(props.itemCar2) ? true : false"
- component: Label
style:
font-size: 12px
white-space: nowrap
text: = @props.itemCar3
visible: "=(props.itemCar3) ? true : false"
style:
align-items: center
border: "=(props.ColorCar) ? (props.ColorCar) + ' 1px solid' : 'lightblue 1px solid'"
display: flex
height: 22px
margin: 0
padding: 0
width: 1px
bgColor: =(props.backColorHome)
style:
align-items: center
border: "=(props.ColorHome) ? (props.ColorHome) + ' 2px solid' : 'gray 2px solid'"
border-width: 2px
display: flex
margin-top: "=(props.itemCar) ? '0px' : (((props.itemSolar) || (props.itemNonFossil)) ? '140px' : '0px')"
slots:
default:
color: "=(props.ColorHome) ? (props.ColorHome) : 'gray'"
height: 20px
icon: if:mdi:home
style:
font-size: 12px
white-space: nowrap
text: =@props.itemHomeConsumption
iconColor: blue
iconF7: "=(props.itemHomeConsumption2) ? 'arrow_right' : ''"
iconSize: 12px
style:
font-size: 12px
white-space: nowrap
text: =@props.itemHomeConsumption2
visible: "=(props.itemHomeConsumption2) ? true : false"
iconColor: purple
iconF7: "=(props.itemHomeConsumption3) ? 'arrow_left' : ''"
iconSize: 12px
style:
font-size: 12px
white-space: nowrap
text: =@props.itemHomeConsumption3
visible: "=(props.itemHomeConsumption3) ? true : false"
- component: Label
style:
background: "=(props.titleHomeBgColor) ? props.titleHomeBgColor : 'transparent'"
text: "=(props.titleHome) ? props.titleHome : 'Home'"
bgColor: =(props.backColorWater)
style:
align-items: center
border: "=(props.ColorWater) ? (props.ColorWater) + ' 1px solid' : 'blue 1px solid'"
display: flex
height: 5px
margin: 0
padding: 0
width: 1px
visible: "=(props.itemWater) ? true : false"
style:
align-items: center
border: "=(props.ColorWater) ? (props.ColorWater) + ' 2px solid' : 'blue 2px solid'"
border-width: 2px
display: flex
margin-top: 0px
slots:
default:
color: "=(props.ColorWater) ? (props.ColorWater) : 'blue'"
height: 20px
icon: if:mdi:water-thermometer
iconColor: darkred
iconF7: "=(props.itemWater) ? ((Number.parseFloat(@props.itemWater) > 5) ? 'flame_fill' : '') : ''"
iconSize: 12px
style:
font-size: 12px
white-space: nowrap
text: "=((Number.parseFloat(@props.itemWater) > 0) ? @props.itemWater : '')"
- component: Label
style:
font-size: 12px
white-space: nowrap
text: = @props.itemWater2
visible: "=(props.itemWater2) ? true : false"
- component: Label
style:
font-size: 12px
white-space: nowrap
text: = @props.itemWater3
visible: "=(props.itemWater3) ? true : false"
- component: Label
style:
background: "=(props.titleWaterBgColor) ? props.titleWaterBgColor : 'transparent'"
text: "=(props.itemWater) ? ((props.titleWater) ? props.titleWater : 'Water') : ''"
I found I needed to redraw to be able to see it visually. Changed the >< and the icon was reversed
