- Platform information:
openhabian 3.3 on a pi4
My logfiles are not updated since Nov4. Item value analyzing stopped Nov26.
How can I figure out, what is going wrong?
openHABian or just a basic Linux installation?
Are there any full file systems?
When’s the last time you rebooted? I assume the problem persists past a reboot?
The complete system was reinstalled after a crash at Nov4. So probably, the logs never worked well.
Rebooting did not help.
Here is the short log output:
2022-11-04 11:28:50.084 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to ‘Europe/Berlin’.
2022-11-04 11:28:50.166 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to ‘53.52618288850293,9.606197476387026’.
2022-11-04 11:28:50.170 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to ‘de_DE’.
2022-11-04 11:29:10.573 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2022-11-04 11:29:15.124 [INFO ] [org.openhab.ui.internal.UIService ] - Started UI on port 8080
2022-11-04 11:29:16.576 [INFO ] [ab.ui.habpanel.internal.HABPanelTile] - Started HABPanel at /habpanel
2022-11-04 11:29:18.870 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to ‘localhost’ with clientid 015deb65-55df-4f47-b0aa-eb810cb74598
2022-11-04 11:29:20.948 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2022-11-04 12:04:36.437 [WARN ] [org.jline ] - The Parser of class org.apache.karaf.shell.impl.console.ConsoleSessionImpl$$Lambda$1551/0x89fca028 does not support the CompletingParsedLine interface. Completion with escaped or quoted words won’t work correctly.
2022-11-04 12:04:57.264 [WARN ] [org.jline ] - The Parser of class org.apache.karaf.shell.impl.console.ConsoleSessionImpl$$Lambda$1551/0x89fca028 does not support the CompletingParsedLine interface. Completion with escaped or quoted words won’t work correctly.
2022-11-04 12:05:12.529 [WARN ] [org.jline ] - The Parser of class org.apache.karaf.shell.impl.console.ConsoleSessionImpl$$Lambda$1551/0x89fca028 does not support the CompletingParsedLine interface. Completion with escaped or quoted words won’t work correctly.
2022-11-04 12:06:05.137 [INFO ] [ab.ui.habpanel.internal.HABPanelTile] - Stopped HABPanel
2022-11-04 12:06:05.172 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2022-11-04 12:06:05.248 [INFO ] [org.openhab.ui.internal.UIService ] - Stopped UI
2022-11-04 11:30:17.317 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘knx:ip:KNX-IP’ changed from UNKNOWN to ONLINE
2022-11-04 11:30:17.323 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘knx:device:KNX-IP:Merten4xBinaryHeuboden’ changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2022-11-04 11:30:17.325 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘knx:device:KNX-IP:KNX-Allgemein’ changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2022-11-04 11:30:17.327 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘knx:device:KNX-IP:Hager4xAusTXA204AHeuboden’ changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2022-11-04 11:43:57.862 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘TasmotaSt1_AnAusSt1’ received command ON
2022-11-04 11:43:57.906 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘TasmotaSt1_AnAusSt1’ predicted to become ON
2022-11-04 11:43:57.933 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘TasmotaSt1_AnAusSt1’ changed from NULL to ON
2022-11-04 11:44:34.358 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘TasmotaSt2_AnAusSt2’ received command ON
2022-11-04 11:44:34.377 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘TasmotaSt2_AnAusSt2’ predicted to become ON
2022-11-04 11:44:34.396 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘TasmotaSt2_AnAusSt2’ changed from NULL to ON
2022-11-04 11:45:46.061 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘TasmotaSt2_AnAusSt2’ received command OFF
2022-11-04 11:45:46.070 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘TasmotaSt2_AnAusSt2’ predicted to become OFF
2022-11-04 11:45:46.080 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘TasmotaSt2_AnAusSt2’ changed from ON to OFF
2022-11-04 12:06:04.544 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘mqtt:topic:mosquitto_on_pi:Steckdose1’ changed from ONLINE to UNINITIALIZED
2022-11-04 12:06:04.562 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘mqtt:topic:mosquitto_on_pi:Steckdose1’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2022-11-04 12:06:04.564 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘mqtt:topic:Steckdose2’ changed from ONLINE to UNINITIALIZED
2022-11-04 12:06:04.574 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘mqtt:topic:Steckdose2’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2022-11-04 12:06:04.576 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘mqtt:topic:mosquitto_on_pi:StromZ’ changed from OFFLINE to UNINITIALIZED
2022-11-04 12:06:04.590 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘mqtt:topic:mosquitto_on_pi:StromZ’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2022-11-04 12:06:04.623 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘mqtt:broker:mosquitto_on_pi’ changed from ONLINE to UNINITIALIZED
2022-11-04 12:06:04.697 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘mqtt:broker:mosquitto_on_pi’ changed from UNINITIALIZED to OFFLINE (COMMUNICATION_ERROR): Client sent DISCONNECT
2022-11-04 12:06:04.703 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘mqtt:broker:mosquitto_on_pi’ changed from OFFLINE (COMMUNICATION_ERROR): Client sent DISCONNECT to OFFLINE
2022-11-04 12:06:04.722 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘mqtt:broker:mosquitto_on_pi’ changed from OFFLINE to UNINITIALIZED (HANDLER_MISSING_ERROR)
2022-11-04 12:06:04.839 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘knx:device:KNX-IP:KNX-Allgemein’ changed from ONLINE to UNINITIALIZED
2022-11-04 12:06:04.849 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘knx:device:KNX-IP:KNX-Allgemein’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2022-11-04 12:06:04.851 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘knx:device:KNX-IP:Hager4xAusTXA204AHeuboden’ changed from ONLINE to UNINITIALIZED
2022-11-04 12:06:04.860 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘knx:device:KNX-IP:Hager4xAusTXA204AHeuboden’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2022-11-04 12:06:04.862 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘knx:device:KNX-IP:Merten4xBinaryHeuboden’ changed from ONLINE to UNINITIALIZED
2022-11-04 12:06:04.871 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘knx:device:KNX-IP:Merten4xBinaryHeuboden’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2022-11-04 12:06:04.873 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘knx:ip:KNX-IP’ changed from ONLINE to UNINITIALIZED
2022-11-04 12:06:04.895 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘knx:ip:KNX-IP’ changed from UNINITIALIZED to OFFLINE
2022-11-04 12:06:04.898 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘knx:ip:KNX-IP’ changed from OFFLINE to UNINITIALIZED (HANDLER_MISSING_ERROR)
Have a look at My logs broke today, not sure why - #2 by Udo_Hartmann to see if those instructions help. Directory where these files are located is /var/lib/openhab/etc on a linux installation.
@Wolfgang_S: the mentioned files seem to be ok.
