[OH3] Main UI Examples
Can You share the yaml from your widgets ?
// Artur
My new Dashboard :upside_down_face:
Made a widget with animated icons and quick access switches by swiping left…
I got the idea for widgets here:
And the widget code itself is a hodgepodge of pieces of community member codes and examples from the documentation… since I don’t understand it very well myself.
I don’t know if the widget code is written correctly or not, but it works and does what I wanted.
Maybe someone will see parts of their code)…
In this example, the fan icon is animated… I made animated icons for heating and cooling using this template…
You can also make animated icons for air conditioner operating modes, for example…
Any changes, corrections, improvements, modifications are welcome…
122333
uid: ROOM_card_KITCHEN
tags: []
props:
  parameters:
    - label: Header
      required: false
      type: TEXT
    - description: Icon on top of the card (oh:iconName or iconName, f7:iconName,
        iconify:iconSet:iconName)
      label: Icon
      required: false
      type: TEXT
    - description: Page which will be opened as popup
      label: Page ID
      required: false
    - context: item
      description: select group for status lights
      label: Item
      required: false
      type: TEXT
    - context: item
      description: select item for temperature
      label: Item
      required: false
      type: TEXT
    - context: item
      description: select item for humidity
      label: Item
      required: false
      type: TEXT
    - context: item
      description: select item for door state(s)
      label: Item
      required: false
      type: TEXT
    - context: item
      description: select item for door lock(s)
      label: Item
      required: false
      type: TEXT
    - context: item
      description: select item for windows(s)
      label: Item
      required: false
      type: TEXT
    - context: item
      description: select item for numbers of windows
      label: Item
      required: false
      type: TEXT
    - context: item
      description: select item for fan
      label: Item
      required: false
      type: TEXT
    - context: item
      label: Item to Switch
      required: false
      type: TEXT
timestamp: May 5, 2025, 4:51:54 PM
component: f7-card
  style:
    background: transparent
    background-color: "=(Number(items[props.status].state) > 0) ? 'rgba(255, 152, 0, 0.1)' : ''"
    class:
      - padding: 0px
    height: 125px
    margin-left: 5px
    margin-right: 5px
    noShadow: false
slots:
  default:
    - component: f7-card-content
        class:
          - display-flex
          - flex-direction-column
          - justify-content-flex-start
          - align-items-center
        style:
          height: 125px
          overflow: hidden
          padding: 0px 0px 0px 0px
      slots:
        default:
          - component: f7-row
              style:
                width: 100%
            slots:
              default:
                - component: f7-swiper
                    params:
                      initialSlide: 0
                      scrollbar:
                        el: .scrollbar-container
                        hide: true
                      slidesPerView: 1
                      spaceBetween: 10
                    style:
                      height: 125px
                      overflow: visible
                      width: 100%
                  slots:
                    default:
                      - component: f7-swiper-slide
                          style:
                            height: 100%
                            width: 100%
                        slots:
                          default:
                            - component: f7-block
                                style:
                                  display: flex
                                  flex-direction: row
                                  left: 0px
                                  position: absolute
                                  top: -14px
                              slots:
                                default:
                                  - component: f7-chip
                                      style:
                                        --f7-chip-bg-color: "=(Number(items[props.status].state) > 0) ? 'rgba(255, 152,
                                          0, 0.3)' : (themeOptions.dark ===
                                          'dark') ? 'rgba(255, 255, 255, 0.1)' :
                                          'rgba(0, 0, 0, 0.1)'"
                                        --f7-chip-height: 60px
                                        --f7-chip-padding-horizontal: 0px
                                        left: -20px
                                        top: -9px
                                    slots:
                                      media:
                                        - component: oh-icon
                                            height: 38px
                                            icon: '=props.icon ? props.icon : ""'
                                            style:
                                              color: "=(Number(items[props.status].state) > 0) ? 'orange' : (themeOptions.dark
                                                === 'dark') ? 'grey' : 'grey'"
                                  - component: Label
                                      style:
                                        color: "=(themeOptions.dark  === 'dark') ? 'white' : 'black'"
                                        font-size: 18px
                                        font-weight: 600
                                        margin-left: -10px
                                        margin-top: 4px
                                      text: "=props.text_header ? props.text_header : 'Кухня'"
                                style:
                                  left: -3px
                                  position: absolute
                                  top: 59px
                                  width: 60%
                              slots:
                                default:
                                  - component: f7-row
                                      style:
                                        align-items: center
                                        display: flex
                                        height: 0
                                        justify-content: flex-start
                                        padding-top: 0px
                                        position: absolute
                                        width: 100%
                                    slots:
                                      default:
                                            height: 24px
                                            icon: "=(Number(items[props.status].state) > 0) ? 'iconify:mdi:lightbulb-group'
                                              : 'iconify:mdi:lightbulb-group'"
                                            style:
                                              padding-right: 0px
                                        - component: Label
                                            style:
                                              font-size: 11px
                                              padding-bottom: 10px
                                              padding-right: 0px
                                            text: "=(Number(items[props.status].state) > 0) ? items[props.status].state :
                                style:
                                  left: 34px
                                  position: absolute
                                  top: 59px
                              slots:
                                default:
                                  - component: f7-row
                                      style:
                                        align-items: center
                                        display: flex
                                        height: 0
                                        padding-top: 0px
                                        position: absolute
                                        width: 100%
                                      stylesheet: |
                                        @keyframes spin {
                                          from {transform:rotate(0deg);}
                                          to {transform:rotate(360deg);}
                                        } svg{
                                          animation-name: spin;
                                          animation-duration: 0.8s;
                                          animation-timing-function: linear;
                                          animation-iteration-count: infinite;
                                    slots:
                                      default:
                                            height: 24px
                                            icon: iconify:material-symbols:mode-fan
                                            style:
                                              color: "= (items[props.fan].state === 'OFF') ? 'grey' : (themeOptions.dark ===
                                                'dark') ? 'rgba(0, 150, 255, 1)'
                                                : 'rgba(0, 150, 255, 1)'"
                                              display: '= (items[props.fan].state === "ON") ? "inherit" : "none"'
                                  - component: f7-row
                                      style:
                                        align-items: center
                                        display: flex
                                        height: 0
                                        padding-top: 0px
                                        position: absolute
                                        width: 100%
                                    slots:
                                      default:
                                            height: 24px
                                            style:
                                              display: '= (items[props.fan].state === "OFF") ? "inherit" : "none"'
                                style:
                                  left: 68px
                                  position: absolute
                                  top: 59px
                                  width: 100%
                              slots:
                                default:
                                  - component: f7-row
                                      style:
                                        align-items: center
                                        display: flex
                                        height: 0
                                        padding-top: 0px
                                        position: absolute
                                        width: 100%
                                    slots:
                                      default:
                                            style:
                                              --f7-chip-bg-color: rgba(255, 255, 255, 0)
                                            text: "=items[props.door_state].state === 'OPEN' ? '' : ''"
                                            visible: "=props.door_state ? true : false"
                                          slots:
                                            media:
                                                  icon: "=items[props.door_state].state === 'OPEN' ? 'door-open' : 'door-closed'"
                                                  style:
                                                    filter: "='brightness(' + (themeOptions.dark === 'dark' ? '1' : '0.4') + ')'"
                                                    height: 18px
                                            style:
                                            text: "=items[props.windows_numbers].state > 0 ?
                                            visible: "=items[props.windows].state >= 0 ? true : false"
                                          slots:
                                            media:
                                                  icon: "=items[props.windows].state > 0 ? 'window-open' : 'window-closed'"
                                                  style:
                                                    height: 18px
                                            iconColor: "=themeOptions.dark === 'dark' ? 'white' : 'black'"
                                            iconF7: "=items[props.door_lock].state === 'OPEN' ? 'lock_open' : 'lock'"
                                            iconSize: 18
                                            style:
                                            text: "=items[props.door_lock].state === 'OPEN' ? '' : ''"
                                            visible: "=props.door_lock ? true : false"
                                style:
                                  left: -6px
                                  position: absolute
                                  top: 92px
                                  width: 80%
                              slots:
                                default:
                                  - component: f7-row
                                      style:
                                        align-items: center
                                        display: flex
                                        height: 0
                                        padding-top: 0px
                                        position: absolute
                                        width: 100%
                                    slots:
                                      default:
                                            height: 18px
                                            icon: iconify:mingcute:thermometer-fill
                                            style:
                                              padding-left: 5px
                                            visible: "=props.temp ? true : false"
                                        - component: Label
                                            style:
                                              font-size: 12px
                                              padding-right: 0px
                                            text: =items[props.temp].state + "°"
                                            height: 18px
                                            icon: iconify:mdi:drop
                                            style:
                                              padding-left: 5px
                                            visible: "=props.humidity ? true : false"
                                        - component: Label
                                            style:
                                              font-size: 12px
                                              padding-left: 0px
                                            text: =items[props.humidity].state + "%"
                                            color: "=(items.Presence.state) === 'ON' ? 'rgb(0, 255, 0, 1)' :
                                              'grey' : 'grey'"
                                            height: 18px
                                            icon: "=(Number(items[props.status].state) > 0) ? 'iconify:mdi:television-play'
                                              : 'iconify:mdi:television-play'"
                                            style:
                                              padding-left: 10px
                            - component: oh-link
                                action: popup
                                actionModal: = 'page:' + props.page
                                style:
                                  height: 125px
                                  left: 0px
                                  position: absolute
                                  top: 0px
                                  width: 100%
                          style:
                            height: 100%
                            width: 100%
                        slots:
                          default:
                                style:
                                  left: 0px
                                  position: absolute
                                  top: -11px
                                  width: 100%
                              slots:
                                default:
                                  - component: f7-row
                                      class:
                                        - text-align-center
                                    slots:
                                      default:
                                        - component: f7-col
                                            style:
                                              background: rgba(233, 196, 106, 0)
                                          slots:
                                            default:
                                                  action: toggle
                                                  actionCommand: ON
                                                  actionCommandAlt: OFF
                                                  actionItem: WallSwitchKitchen_WallSwitchKitchen
                                                slots:
                                                  default:
                                                        color: "=(items.WallSwitchKitchen_WallSwitchKitchen.state === 'ON') ? 'orange' :
                                                          'dark') ? 'grey' :
                                                          'grey'"
                                                        height: 35px
                                                        icon: "=(items.WallSwitchKitchen_WallSwitchKitchen.state === 'ON') ?
                                                          'iconify:mdi:chandeli\
                                                          er' :
                                                          er'"
                                        - component: f7-col
                                            style:
                                          slots:
                                            default:
                                                  action: toggle
                                                  actionCommand: ON
                                                  actionItem: vutyazka_kuhnya__
                                                slots:
                                                  default:
                                                        color: "=(items.vutyazka_kuhnya__.state === 'ON') ? 'orange' :
                                                          'dark') ? 'grey' :
                                                          'grey'"
                                                        height: 35px
                                                        icon: "=(items.vutyazka_kuhnya__.state === 'ON') ?
                                                          'iconify:material-symbols:mod\
                                                          e-fan' :
                                                          'iconify:material-sym\
                                                          bols:mode-fan'"
                                        - component: f7-col
                                            style:
                                            visible: false
                                          slots:
                                            default:
                                                  action: toggle
                                                  actionCommand: ON
                                                slots:
                                                  default:
                                                          'dark') ? 'grey' :
                                                          'grey'"
                                                        height: 35px
                                                          er' :
                                                          er'"
                                  - component: f7-row
                                      class:
                                        - text-align-center
                                    slots:
                                      default:
                                        - component: f7-col
                                            style:
                                          slots:
                                            default:
                                                  action: toggle
                                                  actionCommand: ON
                                                  actionItem: =props.switchItem
                                                  style:
                                                    color: "=themeOptions.dark === 'dark' ? 'orange' : 'black'"
                                                    opacity: 0.9
                                                slots:
                                                  default:
                                                          'dark') ? 'grey' :
                                                          'grey'"
                                                        height: 35px
                                                          'iconify:mdi:televisi\
                                                          on-play'"
                                        - component: f7-col
                                            style:
                                            visible: false
                                          slots:
                                            default:
                                                  action: toggle
                                                  actionCommand: ON
                                                  style:
                                                    opacity: 0.9
                                                slots:
                                                  default:
                                                          'dark') ? 'grey' :
                                                          'grey'"
                                                        height: 35px
                                                          on-play'"
                                        - component: f7-col
                                            style:
                                            visible: '= (items[props.fan].state === "ON") ? "false" : "false"'
                                          slots:
                                            default:
                                                  action: toggle
                                                  actionCommand: ON
                                                  style:
                                                    opacity: 0.9
                                                slots:
                                                  default:
                                                          'grey'"
                                                        height: 35px
                                                        icon: "=(Number(items[props.status].state) > 0) ? 'iconify:mdi:laptop' :
                                                          'iconify:mdi:laptop'"
                                  - component: f7-row
                                      class:
                                        - text-align-center
                                    slots:
                                      default:
                                        - component: f7-col
                                            style:
                                          slots:
                                            default:
                                                  action: toggle
                                                  actionCommand: ON
                                                  actionItem: WS8212_HSB_WS8212
                                                slots:
                                                  default:
                                                        color: "=(items.WS8212_1_sw_ws8212.state === 'ON') ? 'orange' :
                                                          'dark') ? 'grey' :
                                                          'grey'"
                                                        height: 35px
                                                        icon: "=(items.WS8212_1_sw_ws8212.state === 'ON') ? 'iconify:mdi:lamps' :
                                                          'iconify:mdi:lamps'"
                                        - component: f7-col
                                            style:
                                            visible: '= (items[props.fan].state === "ON") ? "true" : "false"'
                                          slots:
                                            default:
                                                  action: toggle
                                                  actionCommand: ON
                                                slots:
                                                  default:
                                                          'grey'"
                                                        height: 20px
                                                        icon: "=(Number(items[props.status].state) > 0) ? 'iconify:mdi:power-socket-eu'
                                                          'iconify:mdi:power-so\
                                                          cket-eu'"
                                        - component: f7-col
                                            style:
                                          slots:
                                            default:
                                                  action: toggle
                                                  actionCommand: ON
                                                slots:
                                                  default:
                                                          'grey'"
                                                        height: 35px
                                                          'iconify:mdi:lightbul\
                                                          b-group'"
