[ Add a primary screenshot or a logo here. The first image of the post will be promoted seen in the add-on list in the UI.]
[ Replace with your description.]
Screenshots
[ Upload other screenshots if necessary or remove the section.]
Changelog
Version 0.2
- added RadiatorControl_Card
- fixed missing Rollershutter label
Version 0.1
- initial release
Resources
uid: main_widget_Floor_Card
tags: []
props:
parameters:
- description: A text prop
label: Prop 1
required: false
type: TEXT
- context: item
description: An item to control
label: Item
required: false
type: TEXT
parameterGroups: []
component: f7-block
visible: '=!vars.objVar ? false : !(vars.objVar.selectSection=="SECTION2") || vars.objVar.room ? false : true'
style:
flex: 1 1 auto
overflow: scroll
margin-top: 1em
margin-bottom: -1em
slots:
default:
- component: oh-repeater
fetchMetadata: semantics,metadata,widgetOrder
for: roomItem
sourceType: itemsInGroup
groupItem: =vars.objVar.floor
filter: (loop.roomItem.metadata) && (loop.roomItem.metadata.semantics.value).includes("Room")
slots:
default:
- component: f7-block
flex-direction: row
margin-left: 2.5rem
slots:
default:
- component: Label
text: =loop.roomItem.label
style:
font-size: 20px
font-weight: 600
margin-left: 35px
margin-top: 0px
line-height: 1.1
- component: Label
text: =loop.roomItem.name
style:
color: var(--f7-list-item-footer-text-color)
font-size: 18px
font-weight: 400
margin-left: 35px
margin-top: 0px
line-height: 1.2
fetchMetadata: semantics,metadata,listWidget
fragment: true
for: equipmentItem
itemTags: Lightbulb
sourceType: itemsWithTags
filter: loop.equipmentItem.metadata.semantics.config.hasLocation == loop.roomItem.name
slots:
default:
- component: widget:main_widget_Light_Card
equipmentItem: =loop.equipmentItem.name
fragment: true
for: radiatorItem
itemTags: RadiatorControl
filter: loop.radiatorItem.metadata.semantics.config.hasLocation == loop.roomItem.name
slots:
default:
- component: widget:main_widget_HVAC
Setpoint: =loop.radiatorItem.name
fragment: true
for: shutterItem
itemTags: Blinds
filter: loop.shutterItem.metadata.semantics.config.hasLocation == loop.roomItem.name
slots:
default:
- component: widget:main_widget_Rollershutter_Card
RollerItem: =loop.shutterItem.name
Title: =loop.shutterItem.label
for: radiatorItem
slots:
default:
- component: widget:main_widget_RadiatorControl_Card
groupItem: =loop.radiatorItem.name
Title: =loop.radiatorItem.label
