Looks good. I like the bottom navbar itself - but I think the color does not really fit in @Dimitris design pattern. Dimitri could you give us a color scheme for the bottom navbar?
Perhaps we should make relevant color parts customizable by props…
This does not seem to be a problem to me, as we can inject room or floor names into the widget.
I will try to create a poc…
Great idea
Should look like this:
uid: main_widget
tags: []
props:
parameters:
- default: black
description: Set default color for Text
label: Text color
required: false
type: TEXT
- default: RGB(96, 96, 96)
label: Bottom-Navbar-Color
required: false
type: TEXT
- default: Somewhere
description: Name for your weather location
label: Weather Location
required: false
type: TEXT
- context: item
description: Name of scenes group item
label: Scenes Group
required: false
type: TEXT
- context: item
description: Name of security group item
label: Security Group
required: false
type: TEXT
- context: item
description: Security Mode Item
label: Security Mode
required: true
type: TEXT
parameterGroups: []
timestamp: Sep 22, 2022, 3:58:17 PM
component: f7-block
style:
display: flex
flex-direction: column
height: calc(100vh - var(--f7-toolbar-height) - var(--f7-safe-area-bottom) - var(--f7-safe-area-top))
justify-content: space-between
margin: 0
padding: 0
widht: 100vh
slots:
default:
- component: f7-block
style:
flex: 0 0 auto
overflow: scroll
slots:
default:
- component: f7-segmented
style:
flex: 1 1 auto
slots:
default:
- component: oh-repeater
for: baseMenu
fragment: true
in:
- name: Home
- name: Floors
- name: Rooms
map: loop.baseMenu.name
sourceType: array
slots:
default:
- component: oh-button
action: variable
actionVariable: objVar
actionVariableValue:
selectSection: ="SECTION" + loop.baseMenu_idx
large: true
style:
color: '=vars.objVar.selectSection=="SECTION" + loop.baseMenu_idx ? textColor : "#8C8C8C"'
font-size: 28px
font-weight: 200
text-decoration: underline
text-decoration-color: '=vars.objVar.selectSection=="SECTION" + loop.baseMenu_idx ? "#F8BB00" : "transparent"'
text-underline-offset: 4px
text: =loop.baseMenu
- component: f7-row
style:
align-items: center
display: flex
flex-direction: row
flex-wrap: nowrap
height: 2em
width: 100%
visible: false
slots:
default:
action: variable
actionVariable: buttonIndexHome
actionVariableValue: =(vars.buttonIndexHome || 0) - 1
iconF7: chevron_left
style:
color: "#F8BB00"
flex: 0 0 auto
height: 2em
for: menuArray
fragment: true
sourceType: itemsWithTags
itemTags: Floor
fetchMetadata: widgetOrder
map: loop.menuArray_source
slots:
default:
- component: f7-row
style:
display: flex
height: 2em
justify-content: center
overflow: hidden
slots:
default:
for: menuButtonHome
fragment: true
in: =loop.menuArray
filter: loop.menuArray_idx == 0
map: ((loop.menuButtonHome.metadata && loop.menuButtonHome.metadata.widgetOrder && loop.menuButtonHome.metadata.widgetOrder.value) || 0).toString().padStart(3,'0') + '&' + loop.menuButtonHome_idx
slots:
default:
action: variable
actionVariable: floor
actionVariableValue: =loop.menuArray[loop.menuButtonHome_source.sort()[loop.menuButtonHome_idx].split('&')[1]].name
style:
flex: 0 0 auto
height: 2em
order: =(((vars.buttonIndexHome || 0) % loop.menuButtonHome_source.length) + loop.menuButtonHome_source.length + loop.menuButtonHome_idx) % loop.menuButtonHome_source.length
text: =loop.menuArray[loop.menuButtonHome_source.sort()[loop.menuButtonHome_idx].split('&')[1]].label
action: variable
actionVariableValue: =(vars.buttonIndexHome || 0) + 1
iconF7: chevron_right
style:
color: "#F8BB00"
flex: 0 0 auto
height: 2em
- component: f7-row
style:
align-items: center
display: flex
flex-direction: row
flex-wrap: nowrap
height: 2em
width: 100%
visible: '=vars.objVar ? (vars.objVar.selectSection=="SECTION1") ? true : false : false'
slots:
default:
action: variable
actionVariable: buttonIndexFloor
actionVariableValue: =(vars.buttonIndexFloor || 0) - 1
style:
color: "#F8BB00"
flex: 0 0 auto
height: 2em
for: menuArray
fragment: true
itemTags: Floor
slots:
default:
- component: f7-row
style:
display: flex
height: 2em
overflow: hidden
slots:
default:
for: menuButtonFloor
fragment: true
in: =loop.menuArray
map: ((loop.menuButtonFloor.metadata && loop.menuButtonFloor.metadata.widgetOrder && loop.menuButtonFloor.metadata.widgetOrder.value) || 0).toString().padStart(3,'0') + '&' + loop.menuButtonFloor_idx
slots:
default:
action: variable
actionVariableValue: =loop.menuArray[loop.menuButtonFloor_source.sort()[loop.menuButtonFloor_idx].split('&')[1]].name
style:
flex: 0 0 auto
height: 2em
order: =(((vars.buttonIndexFloor || 0) % loop.menuButtonFloor_source.length) + loop.menuButtonFloor_source.length + loop.menuButtonFloor_idx) % loop.menuButtonFloor_source.length
color: '=vars.floor ==(loop.menuArray[loop.menuButtonFloor_source.sort()[loop.menuButtonFloor_idx].split("&")[1]].name) ? textColor : "#8C8C8C"'
text-decoration-color: '=vars.floor ==(loop.menuArray[loop.menuButtonFloor_source.sort()[loop.menuButtonFloor_idx].split("&")[1]].name) ? "#F8BB00" : "transparent"'
text: =loop.menuArray[loop.menuButtonFloor_source.sort()[loop.menuButtonFloor_idx].split('&')[1]].label
action: variable
actionVariableValue: =(vars.buttonIndexFloor || 0) + 1
style:
color: "#F8BB00"
flex: 0 0 auto
height: 2em
- component: f7-row
style:
align-items: center
display: flex
flex-direction: row
flex-wrap: nowrap
height: 2em
width: 100%
visible: '=vars.objVar ? (vars.objVar.selectSection=="SECTION2") ? true : false : false'
slots:
default:
action: variable
actionVariable: buttonIndexRoom
actionVariableValue: =(vars.buttonIndexRoom || 0) - 1
style:
color: "#F8BB00"
flex: 0 0 auto
height: 2em
for: menuArrayRoom
fragment: true
itemTags: =vars.floor
map: loop.menuArrayRoom_source
slots:
default:
- component: f7-row
style:
display: flex
height: 2em
overflow: hidden
slots:
default:
for: menuButtonRoom
fragment: true
in: =loop.menuArrayRoom
filter: loop.menuArrayRoom_idx == 0
map: ((loop.menuButtonRoom.metadata && loop.menuButtonRoom.metadata.widgetOrder && loop.menuButtonRoom.metadata.widgetOrder.value) || 0).toString().padStart(3,'0') + '&' + loop.menuButtonRoom_idx
slots:
default:
action: variable
actionVariable: room
actionVariableValue: =loop.menuArrayRoom[loop.menuButtonRoom_source.sort()[loop.menuButtonRoom_idx].split('&')[1]].name
style:
flex: 0 0 auto
height: 2em
order: =(((vars.buttonIndexRoom || 0) % loop.menuButtonRoom_source.length) + loop.menuButtonRoom_source.length + loop.menuButtonRoom_idx) % loop.menuButtonRoom_source.length
color: '=vars.room ==(loop.menuArrayRoom[loop.menuButtonRoom_source.sort()[loop.menuButtonRoom_idx].split("&")[1]].name) ? textColor : "#8C8C8C"'
text-decoration-color: '=vars.room ==(loop.menuArrayRoom[loop.menuButtonRoom_source.sort()[loop.menuButtonRoom_idx].split("&")[1]].name) ? "#F8BB00" : "transparent"'
text: =loop.menuArrayRoom[loop.menuButtonRoom_source.sort()[loop.menuButtonRoom_idx].split('&')[1]].label
action: variable
actionVariableValue: =(vars.buttonIndexRoom || 0) + 1
style:
color: "#F8BB00"
flex: 0 0 auto
height: 2em
style:
flex: 1 1 auto
overflow: scroll
margin-top: -1em
margin-bottom: -1em
slots:
default:
- component: widget:main_widget_Weather_Card
bigCard: true
dateFormat: true
itemPrefix: OneCallAPIweatherandforecast_
locationTitle: =props.locationTitle
sunIndicator: true
visible: '=(!vars.objVar || ((vars.objVar.selectSection=="SECTION0") && !vars.objVar.selectThing)) ? true : false'
fetchMetadata: semantics,metadata,listWidget
for: sceneItem
groupItem: =props.scenesGroup
sourceType: itemsInGroup
slots:
default:
- component: widget:main_widget_Scene_Card
scene: =loop.sceneItem.name
sceneName: =loop.sceneItem.label
visible: '=vars.objVar ? ((vars.objVar.selectSection + vars.objVar.selectThing)=="SECTION0Scenes") ? true : false : false'
filter: loop.equipmentItem.metadata.semantics.config.hasLocation == vars.room
for: equipmentItem
itemTags: Blinds
slots:
default:
filter: '(loop.shutterItem.type=="Rollershutter") ? true : false'
for: shutterItem
groupItem: =loop.equipmentItem.name
slots:
default:
- component: widget:main_widget_Rollershutter_Card
RollerItem: =loop.shutterItem.name
visible: '=vars.objVar.selectThing=="Rollers" ? true : false'
for: equipmentItem
itemTags: Lightbulb
slots:
default:
- component: widget:main_widget_Light_Card
equipmentItem: =loop.equipmentItem.name
visible: '=vars.objVar.selectThing=="Lights" ? true : false'
for: equipmentItem
itemTags: RadiatorControl
slots:
default:
for: tempItem
slots:
default:
- component: widget:Temp_Control
style:
flex: 1 1 auto
overflow-y: auto
position: relative
visible: '=vars.objVar.selectThing=="Climate" ? true : false'
widgettrend: =loop.tempItem.name
- component: widget:main_widget_Security_Card
securityGroup: =props.securityGroup
securityMode: =props.securityMode
visible: '=vars.objVar ? ((vars.objVar.selectSection + vars.objVar.selectThing)=="SECTION0Security") ? true : false : false'
- component: Label
style:
flex: 1 1 auto
overflow-y: auto
position: relative
text: =vars.objVar.selectSection + vars.floor
visible: "=vars.objVar ? true : false"
style:
flex: 0 0 auto
overflow: scroll
margin-bottom: -2em
visible: '=vars.objVar ? (vars.objVar.selectSection=="SECTION0") ? true : false : false'
slots:
default:
class:
- segmented-strong
style:
--f7-segmented-strong-between-buttons: 0px
--f7-segmented-strong-bg-color: transparent
--f7-segmented-strong-button-font-weight: 300
--f7-segmented-strong-button-hover-bg-color: rgba(255, 255, 255, 0.15)
--f7-segmented-strong-padding: 0px
slots:
default:
action: variable
selectSection: =vars.objVar.selectSection
selectThing: Security
class:
- padding-top-half
- display-flex
- flex-direction-column
fill: '=vars.objVar.selectThing=="Security" ? true : false'
icon-f7: shield_fill
iconColor: green
iconSize: 20
style:
--f7-button-bg-color: '=vars.objVar.selectThing=="Security" ? "#F8BB00" : "transparent"'
--f7-button-border-radius: 15px
--f7-button-hover-bg-color: '=vars.objVar.selectThing=="Security" ? "F8BB00" : "transparent"'
--f7-button-padding-horizontal: 0px
--f7-button-padding-vertical: 0px
--f7-button-text-color: '=vars.objVar.selectThing=="Security" ? "#6A6A6A" : "#8C8C8C"'
font-size: 12px
height: auto
text: Security
action: variable
selectThing: Scenes
class:
- padding-top-half
- display-flex
fill: '=vars.objVar.selectThing=="Scenes" ? true : false'
icon-f7: rectangle_on_rectangle_angled
iconColor: textColor
iconSize: 20
style:
--f7-button-bg-color: '=vars.objVar.selectThing=="Scenes" ? "#F8BB00" : "transparent"'
--f7-button-hover-bg-color: '=vars.objVar.selectThing=="Scenes" ? "F8BB00" : "transparent"'
--f7-button-text-color: '=vars.objVar.selectThing=="Scenes" ? "#6A6A6A" : "#8C8C8C"'
font-size: 12px
height: auto
text: Scenes
action: variable
selectThing: Weather
class:
- padding-top-half
- display-flex
fill: '=vars.objVar.selectThing=="Weather" ? true : false'
icon-f7: cloud
iconSize: 20
style:
--f7-button-bg-color: '=vars.objVar.selectThing=="Weather" ? "#F8BB00" : "transparent"'
--f7-button-hover-bg-color: '=vars.objVar.selectThing=="Weather" ? "F8BB00" : "transparent"'
--f7-button-text-color: '=vars.objVar.selectThing=="Weather" ? "#6A6A6A" : "#8C8C8C"'
font-size: 12px
height: auto
text: Weather
action: variable
selectThing: HVAC
class:
- padding-top-half
- display-flex
fill: '=vars.objVar.selectThing=="HVAC" ? true : false'
icon-f7: flame
iconSize: 20
style:
--f7-button-bg-color: '=vars.objVar.selectThing=="HVAC" ? "#F8BB00" : "transparent"'
--f7-button-hover-bg-color: '=vars.objVar.selectThing=="HVAC" ? "F8BB00" : "transparent"'
--f7-button-text-color: '=vars.objVar.selectThing=="HVAC" ? "#6A6A6A" : "#8C8C8C"'
font-size: 12px
height: auto
text: HVAC
style:
flex: 0 0 auto
overflow: scroll
margin-bottom: -2em
background: =props.bnavColor
border-radius: 0px 0px 10px 10px
visible: '=vars.objVar ? (vars.objVar.selectSection=="SECTION0") ? false : true : false'
slots:
default:
class:
- segmented-strong
style:
slots:
default:
action: variable
selectThing: Lights
class:
- padding-top-half
- display-flex
fill: '=vars.objVar.selectThing=="Lights" ? true : false'
icon-f7: lightbulb
iconColor: '=vars.objVar.selectThing=="Lights" ? "black" : "white"'
iconSize: 20
style:
--f7-button-bg-color: transparent
--f7-button-hover-bg-color: '=vars.objVar.selectThing=="Lights" ? "F8BB00" : "transparent"'
--f7-button-text-color: '=vars.objVar.selectThing=="Lights" ? "black" : "white"'
font-size: 12px
height: auto
text: Lights
action: variable
selectThing: Climate
class:
- padding-top-half
- display-flex
fill: '=vars.objVar.selectThing=="Climate" ? true : false'
icon-f7: snow
iconColor: '=vars.objVar.selectThing=="Climate" ? "black" : "white"'
iconSize: 20
style:
--f7-button-hover-bg-color: '=vars.objVar.selectThing=="Climate" ? "F8BB00" : "transparent"'
--f7-button-text-color: '=vars.objVar.selectThing=="Climate" ? "black" : "white"'
font-size: 12px
height: auto
text: Climate
action: variable
selectThing: Rollers
class:
- padding-top-half
- display-flex
fill: '=vars.objVar.selectThing=="Rollers" ? true : false'
icon-f7: archivebox
iconColor: '=vars.objVar.selectThing=="Rollers" ? "black" : "white"'
iconSize: 20
style:
--f7-button-hover-bg-color: '=vars.objVar.selectThing=="Rollers" ? "F8BB00" : "transparent"'
--f7-button-text-color: '=vars.objVar.selectThing=="Rollers" ? "black" : "white"'
font-size: 12px
height: auto
text: Rollers
action: variable
selectThing: Energy
class:
- padding-top-half
- display-flex
fill: '=vars.objVar.selectThing=="Energy" ? true : false'
icon-f7: bolt
iconColor: '=vars.objVar.selectThing=="Energy" ? "black" : "white"'
iconSize: 20
style:
--f7-button-hover-bg-color: '=vars.objVar.selectThing=="Energy" ? "F8BB00" : "transparent"'
--f7-button-text-color: '=vars.objVar.selectThing=="Energy" ? "black" : "white"'
font-size: 12px
height: auto
text: Energy
Tomorrow i will have many graphical things to work with.
Theming was already one of them and now nic you helped me with another skill
@hmerk yes these colors are not dimitri’s guideline, but colors are “5 seconds code”
That was not my comment
Ops sorry, i’m replying from mobile and i’m becoming crazy
Hello @Team. Can anyone make some screenshots from the AS-IS working layout? It’s time for a detailed recap, especially for nav bar and tabs. My view is that we have to agree on structure, color scheme and layout prior to continue with widgets. Thank you all
@Dimitris here you are … Screenshots from my iPhone8 :
These screenshots do not include the widgets modified by @rubenfuser
Hey @hmerk,
one question about your model - what did you tag so that more than one light widget is shown in your “Arbeitszimmer”-Room? The first post says that it should be grouped in a non semantic group.
But what is a non semantic group? How to create one?
Could you perhaps provide a screenshot of yours? I’ll then try and edit the wiki / add the screenshots there too
I have more than one equipment of type Lightbulb in my office. One is the dummy colored light and one is my real ceilinglight. So nothing special.
A non semantic group is simply a group item with no selected class and/or propertys.
It will not directly be shown in the modell.
I have changed the margin to
margin-bottom: -4.5em
for the buttom tabs, so I got rid of the waste space completely. Now have to check on other devices…
@hmerk. Thank you Sir. What a progress!
My notes: -Whatever you can adjust, will be perfect. I know, you are developers and always in love with coding and not with the appearance as me, but, pls try to fine-tune it!
Question. The energy tab filters which widgets? Also you have exclude the “all” from tabs. Correct?
Energy tab is only a placeholder for now, and there was never an “All” tab.
This is just exchanging to lines in code, so really simple.
Further comments :
EDIT: on my iPhone12 mini it needs
stylesheet: >
.block:first-child{
margin-top: 15px;
in the page config, otherwise the menu is to high and not accessible…
EDIT2 : Grr, now the bottom tab is to low on iPhone8, need to reduce from -4.5em to -4em
Again, congratulations to all of you. For the first time in my life I see the kindness and power of a community.
For a reason, i want to send a BIG thank you to @JustinG, our Team’s calm strength and @hmerk, the peaceful Machine Gun.
@JustinG Now I need a clever hint from your side.
Looking at @Dimitris comparison, we should change the text color for selected menu item to black.
This is the style we are using, but I do not get it :
style:
color: '=(!vars.objVar) ? "gray" : (vars.objVar.selectSection==("SECTION" + loop.baseMenu_idx)) ? textColor : "gray"'
font-size: 24px
font-weight: 200
text-decoration-color: '=(!vars.objVar) ? "transparent" : (vars.objVar.selectSection=="SECTION" + loop.baseMenu_idx) ? "#F8BB00" : "transparent"'
Any idea ???
hmmm. I don´t get it right. selected should be white and unselected gray or am I wrong?
Energy is for energy devices in the room.
Smartplugs for example, and energy/power consumption.
This was my idea.
