2020-12-26 20:47:52.657 [DEBUG] [pdb.internal.MapDbPersistenceService] - Stored 'WBeleuchtungSwitchActive' with state 'ON' as '{"name":"WBeleuchtungSwitchActive","state":"org.openhab.core.library.types.OnOffType@@@ON","timestamp":"Dec 26, 2020, 8:47:52 PM"}' in MapDB database
but after restart the stored item values are not restored, so the item values is “null”
Hi, i have the same Problem for restore item states after reboot/restart OpenHab.
Also with only the default installed persistence rrd4j the System doesn’t not Restore any Items states.
i solved my issue.
My problem was the the ZRAM in openhabian. After a deactivaiting and a subsequently activating of ZRAM in openhabian-config I solved it.
Because with debugging i found out does after restart the mapdb always are empty
I saw the last days some Topics regarding the ZRAM, so it looks like at first Run after a new installation it works not correct.
Thanks for the hint, this also help by my Problem with the restore item state. After “Uninstall ZRAM” and than “User ZRAM”, the item state is persistens across reboot!!
