Hi, I have a fan control (convector) over z-wave and have mode item (off/cooling/heating) then another item to control the fan power.
I want to display the fan power widget in the locations tab only when the fan state is ON. I tried setting the visibility in “default list item widget” to zwavethingname_thermostatmode != “Off”, but that doesn’t work.
And the zwavethingname_thermostatmode literally has the values Off/Heating/Cooling/Fan_only.
I’m struggling with the visibility expression here as well.
I have power metering wall plugs but only want to see them in the location card when they are actually ON.
So first I tried
=items["eg_wz_tisch2"].state != "Off"
where eg_wz_tisch2 is the item of the actual switch to no avail.
