Is there a clean way to move an op3 installation with all settings to raspian? The backup function is not working.
I don’t understand what has to be copied. Which folder and file ind which directory. Is there an overview? I don’t want to create everything new (~400 items.)
The backup function should work so you need to further explore that problem. What is not working? How is it not working? How do you know it’s not working? How are you calling it?
HI,
I have tried the backup function 3 times. And it just did not work. Under Windows it zips differently either, like under Raspbian. Under Raspbian, the recovery function (as reported in other posts) says it can’t unzip the zip file because of a “backslash” problem.
The problem with zipping under windows and unzipping under Linux is a known problem. And can be quickly researched.
I suppose the way between windows and Linux has not been tested.
For this reason, it would be good to know which files and directories to copy where.
Well, you can open the zip file on Windows. So look in it and see what there and you’ll have a much more comprehensive and complete answer to your question than we could provide here on a forum post.
Other things you can do:
unzip it on Windows and use 7zip or some other tool that will generate compatible zip files
unzip it on Windows, transfer the files and folders themselves, then rezip it on Linux
unzip i on Windows, transfer the files and folders themselves, then place them into the ultimate destination which should be apparent based on the directories. The stuff under conf goes to /etc/openhab and the stuff under userdata goes to /var/lib/openhab
Not working, No things, No items after restart on Raspbian
Proposal 2:
also not working, looks good for unzipping, but then i get the message: “Backup was not created by openhabscripts, please resort to manual restore…”
Then all I can really suggest is that you didn’t actually put the files in the right locations or there is something wrong with the files. Logs will tell you if there is something wrong with the files.
