- Platform information:
- Hardware: Ubuntu 20.04 Hyperview VM
- OS: Ubuntu 20.04 Hyperview VM
- Java Runtime Environment: zulu 11
- openHAB version: 3.0.0-S1952
Hi guys
I’m sorry if this is not the right section…but I didn’t find one most suitable.
After installing OH3 snapshot i have the following errors in log files
2020-10-04 07:09:58.039 [ERROR] [rnal.ChannelStateDescriptionProvider] - Dynamic state description matches original state description. DynamicStateDescriptionProvider implementations must never return the original state description. class org.openhab.binding.mqtt.generic.MqttChannelStateDescriptionProvider has to be fixed.
and the second one is related to influxdb persistence:
2020-10-04 07:11:15.382 [ERROR] [org.influxdb.impl.BatchProcessor ] - Batch could not be sent. Data will be lost
org.influxdb.InfluxDBIOException: java.net.SocketTimeoutException: timeout
at org.influxdb.impl.InfluxDBImpl.execute(InfluxDBImpl.java:831) ~[bundleFile:?]
at org.influxdb.impl.InfluxDBImpl.write(InfluxDBImpl.java:460) ~[bundleFile:?]
at org.influxdb.impl.OneShotBatchWriter.write(OneShotBatchWriter.java:22) ~[bundleFile:?]
at org.influxdb.impl.BatchProcessor.write(BatchProcessor.java:340) [bundleFile:?]
at org.influxdb.impl.BatchProcessor$1.run(BatchProcessor.java:287) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
Caused by: java.net.SocketTimeoutException: timeout
at okio.Okio$4.newTimeoutException(Okio.java:232) ~[bundleFile:?]
at okio.AsyncTimeout.exit(AsyncTimeout.java:286) ~[bundleFile:?]
at okio.AsyncTimeout$2.read(AsyncTimeout.java:241) ~[bundleFile:?]
at okio.RealBufferedSource.indexOf(RealBufferedSource.java:358) ~[bundleFile:?]
at okio.RealBufferedSource.readUtf8LineStrict(RealBufferedSource.java:230) ~[bundleFile:?]
at okhttp3.internal.http1.Http1ExchangeCodec.readHeaderLine(Http1ExchangeCodec.java:242) ~[bundleFile:?]
at okhttp3.internal.http1.Http1ExchangeCodec.readResponseHeaders(Http1ExchangeCodec.java:213) ~[bundleFile:?]
at okhttp3.internal.connection.Exchange.readResponseHeaders(Exchange.java:115) ~[bundleFile:?]
at okhttp3.internal.http.CallServerInterceptor.intercept(CallServerInterceptor.java:94) ~[bundleFile:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:142) ~[bundleFile:?]
at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:43) ~[bundleFile:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:117) ~[bundleFile:?]
at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:94) ~[bundleFile:?]
at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.java:93) ~[bundleFile:?]
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:88) ~[bundleFile:?]
at org.influxdb.impl.BasicAuthInterceptor.intercept(BasicAuthInterceptor.java:22) ~[bundleFile:?]
at org.influxdb.impl.GzipRequestInterceptor.intercept(GzipRequestInterceptor.java:42) ~[bundleFile:?]
at okhttp3.logging.HttpLoggingInterceptor.intercept(HttpLoggingInterceptor.java:152) ~[bundleFile:?]
at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:229) ~[bundleFile:?]
at okhttp3.RealCall.execute(RealCall.java:81) ~[bundleFile:?]
at retrofit2.OkHttpCall.execute(OkHttpCall.java:188) ~[bundleFile:?]
at org.influxdb.impl.InfluxDBImpl.execute(InfluxDBImpl.java:819) ~[bundleFile:?]
... 10 more
Caused by: java.net.SocketException: Socket closed
at java.net.SocketInputStream.read(SocketInputStream.java:183) ~[?:?]
at java.net.SocketInputStream.read(SocketInputStream.java:140) ~[?:?]
at okio.Okio$2.read(Okio.java:140) ~[bundleFile:?]
at okio.AsyncTimeout$2.read(AsyncTimeout.java:237) ~[bundleFile:?]
... 10 more
... 10 more
... 10 more
How I can solve this issues ?
thanks in adavnce for your support.
Regards
