Hi, I am testing an Openhab3 installation on linux. Before using it as daily driver, I would like to check if everythin is initializating fine. This WARN occurs while starting openhab 3:
2021-01-15 11:12:07.892 [WARN ] [rnal.handler.GenericMQTTThingHandler] - Channel configuration error
java.lang.IllegalArgumentException: The transformation pattern must consist of the type and the pattern separated by a colon
at org.openhab.binding.mqtt.generic.ChannelStateTransformation.<init>(ChannelStateTransformation.java:50) ~[bundleFile:?]
at org.openhab.binding.mqtt.generic.internal.handler.GenericMQTTThingHandler.lambda$7(GenericMQTTThingHandler.java:131) ~[bundleFile:?]
at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:195) ~[?:?]
at java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:177) ~[?:?]
at java.util.Spliterators$ArraySpliterator.forEachRemaining(Spliterators.java:948) ~[?:?]
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:484) ~[?:?]
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474) ~[?:?]
at java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:150) ~[?:?]
at java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:173) ~[?:?]
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:?]
at java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:497) ~[?:?]
at org.openhab.binding.mqtt.generic.internal.handler.GenericMQTTThingHandler.createChannelState(GenericMQTTThingHandler.java:132) ~[bundleFile:?]
at org.openhab.binding.mqtt.generic.internal.handler.GenericMQTTThingHandler.initialize(GenericMQTTThingHandler.java:165) [bundleFile:?]
at jdk.internal.reflect.GeneratedMethodAccessor47.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
Is that a general warning for a transformation binding? I can’t see any reference to a particular channel in these messages.
I use JSONPATH and REGEX filters in my channels, and copied them 1:1 from my daily used OH2.5.11 to the OH3 test installation.
Thank’s for your help
